Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bolt
Well according to Mannix it does because he has closed a thread over my ONE sentence. As much as the aim is to keep politics out of this thread he decided to create a decisive blow to a simple comment. Therefore politics means a lot to mannix and is not practicing what he has preached. I know that he is the one for conveying very useful information from SM to build upon but to be honest I find this quite shocking.
bolt
GK that looks good i think your on a home run. However, your digi control is almost certainly way over the top to how SM was doing this but least gives you a stable platform to work from. One of the things i been looking at is the number of turns for the collectors. Clearly we can only deal with fractional parts of an earth wave. I post more on this shortly.
Earth wave say at 7.5 Hz = 39972327.7333 meters so what do you propose is a workable fraction to try. 3.99 meters? Perhaps 39.97 meters on a larger TPU if you have space. BTW you really should use the ferrite ring core to inject the sines into you coils.
giantkiller
Quote from: bolt on September 12, 2007, 06:04:19 PM
Over the top is true but I at least want to see where I am at when things take off. Could be the last thing I see... :o
--giantkiller.
bolt
The way SM controlled this was a free running osc tuned roughly to 7.0 to 8.0 as a sweep then it was phased locked to the actual 7.53452 once it appeared. I since found this mag freq is rather wobbly day to day.  However, you can only do this when you worked out the coils and controls otherwise force feeding is good for now. It will need to be accurate to at least 0.01 Hz. Later you need to make an AGC circuit too. If your lucky you will notice a burning smell on the coils, if unlucky.........well your mum can tell us instead. LOL
bolt
Don't forget your ferrite cores for each coil injection and you need magnets!
