Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
acerzw
I have been looking at sites with reference to schumann earth frequencies, it seems like there are several of them, I was wondering if it might be an option to tap one of the others instead, maybe one of the less powerful ones, then possibly full conversion could be reached without a melt down, less power might be a good thing if the TPU cannot handle a full conversion event.
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
bolt
There are lots of noise and harmonics down in the low Hz range but only the 7.3 mag wave has enough energy to make this work. However you must first tap into this signal. How do you think that a tiny coil about 100,000 smaller than the wave length can collect enough of this signal to make use of it?
SherlockHolmes
What say.....Watson. A number of clues seem to have led under the streetlamp. While there may be more light under the lamp, it may actually further disguise the mystery and lead away from the goal. Strange indeed!
SH
innovation_station
3.99 Meters = 13.090551181102361 Feet
hummm
and this puts us in the ball park of the earths feild?
is
so this is our collector length of wire and we need 3 of them i have seen varous ways to wind collectors the folded in half way the pancake way the open ended pancake way if it was open ended then we stop the pluse b4 the end of the wire and this will make the standing wave?  if it is like that then it is like our conrtols that are spining are cutting the standing wave or taping into it  ;) breaking the flux lines that are cancled  ha!!!
well top coil is spinning 1 dirrection bottom the opsite center is following both!! via magnetic induction no? the pluses that go into  the top are 180 deg  of the ones that go in the bottom? and that will cancel out each other  in the standing wave producing it at 90 deg
well enough is enough
square waves = teslas death ray
sine = sm tpu
make sence?
Grumpy
When you enter the world of "harmonics", the resultant wave is no longer a sine wave and I agree that sine waves can produce the desired effects.  A single sine wave can not produce these effects.  If anyone has proof that contradicts this, I'd love to see it.  Just because you put a sine wave in to something does not mean you get a sine wave out.
On a related note, transformers will not pass a square wave since it is not constantly changing.  I'm sure the "magnetic vector potential" plays an important part in this.  You put a square in and you get a pulse out - who would have thought?
Odd harmonics, which, by the way, are positive going in the spectrum domain, are combined to produce square waves.  The neat thing here is that by adding the odd harmonics, the rise/fall time of the resultant waveform is much faster than the individuals.  So, if you are looking for a fast transition, it's almost like getting something for nothing.  In theory, the odd harmonics all the way to infinity are in a square wave - this would include frequencies in the IR, UV, and all the way up to cosmic rays - neutrinos anyone?
Throw even harmonics in the mix and you get sawtooth waves.
Now, I rememebr something about one of these types of waves (square or saw) not have a DC element, think it was the square and something about the missing harmonics - I might be totally wrong.  I'll look that up when I get home to the ol' book on pulses that I have from the tube days.
Pese recently declared that FE/OU can not be achieved with SS devices.  First you have the tiny little reverse when the SS device switches, then you have bandwidth considerations to contend with.  It is interesting to note that the compounds that make-up SS devices have bandwidth limits for electrical transmission.  Even wires and cables have bandwidth limits.  Hell, even various types of glass have bandwidth limits.  Quartz, for example, is an excellent transmitter of UV.  Makes for great lenses in the UV range.  When I worked in the satellite field years ago, we performed sweeps on patch cables and a perfectly good patch cable would be rejected if it's losses were too great in our desired frequency range.  Really good cables (i.e. very linear in desired freq range) would get a special place next to the sweep generator.
Interesting to note that RE can be created with SS devices in a round-about sort of way - as GK has indicated with his experiments in this thread.  However, I don't recall seeing any SS devices in SM's rings - only coils and capacitors (and fuses) - wich leads me to think that the effects are easy to create when one knows how.
        -Frank Edwards
