Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Quote from: mflynn44 on January 31, 2007, 06:31:02 PM
The website referenced above has a lot of information regarding collecting radiant energy. Actually, he provides a good description of how the TPU should work; it's just a matter of changing a few connections on our present TPUs.
Michael Flynn
Thank you for posting that! I quoted the most important part. Moab followed the GK4 instructions and made slight modification and way better results! That fits in with the quote. Simple little changes of some kind of coil looping of inter folding. This monster is gonna grow. It all happens after the kicks.
Again, Thanks Mike.
--giantkiller. Progress is one step at a time. In case anybody is confused? The quotes are out of the Bible. Sorry if it sounded like I make this up.
mflynn44
Yes GK, one step at a time. It looks as if we might try connecting our control coils bucking in pairs and the iron collector coil (dissimilar metals important) in series with the control coils to generate power (not just voltage) in the collector.
Moab
Quote from: giantkiller on January 31, 2007, 06:58:10 PM
Michael Flynn
Again, Thanks Mike.
Simple little changes!!
no one can believe how true that statement really is. It takes many hours of small changes.One thing at a time.Try this try that. its maddening sometimes.Heres a tip for you pulsers Use an AM radio and tune it to near the infrequencies you are pulsing your coils at when you get the right kind of kicks and the coils are open you will know it.
When i stated earlier in this thread that a light bulb test didn't work out, I was thinking of a light bulb that would stay light. Mine just burned out. as it turns out these caps i am using are storing energy, Just not the kind of electricity that a common light bulb will work well with. In my case the bulb glowed a brilliant blue/white for a second and burned out. Not a success? YES it was. it proved to me that even though i had no usable currant before i hooked up caps that what little i did have could be stored in a cap and discharged.
When you read "KICKS". think of a sloshing motion in a wire.one direction is the pulse you put into it and the reverse is the radiant energy taking the place of your DC pulse when it is not present. When your DC pulse is introduced the KICK happens the kick is the RE we all strive to achieve. it is what you will here on your radio when your close.and it is what is stored in my caps,  once you find it other things become obvious to you.
Frequencies are the key to the kicks. Your coils are different than mine, and so to will be your freq. This is not a one freq fits all undertaking.THIS is important.don't bother with two or three at a time stick to one until you have kicks on your scope or a squealing on your am radio if you don't have a scope. when you have kicks move on to the next freq and try. I only had to make two the third IS resonance.you wont mistake it when you stumble upon it.
As GK said small changes.What may seem like no change at all. And keep after it you will find your kicks. Time to put the search for kicks behind me and move on. Ill post when i have more. I hope my poor analogies have helped someone obtain a goal      Thank you all for your help. And the good reading.     MOAB
giantkiller
Quote from: mflynn44 on January 31, 2007, 07:37:17 PM
And that is where Otto and I have gone. The tesla 390721 transformer is the key of 30awg CU. And my FE 22 turn loops with 5ohms 10 watt are not a dead short! Figure that out! That gives opposing fields of n-n at 12 and 6 o'clock and s-s at 3 9 o'clock. I posted a avi of that action. I will post it again. avi is slo-mo. I am working on a static model for future postings.
--giantkiller.
giantkiller
Powerful! And the 'Scream team' moves on.
There is also another anomymous member on the team who is achieving things that will harm the non believers. I've seen it and it is amazing! Puff -n- holler, smoke -n- mirrors? Without kicks you won't understand. It has all been spelled out.
--giantkiller. Rock -n- roll!
