Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Grumpy
harmonics in the vortex layer would maintain the alignement - that is poor terminology - they make the vortex field coherent
Didn't see anything in those letters about harmonics of 7.X Hz.
Whoa! What's this?
QuoteThe destructive heating caused by the eddy currents become the problem we face when we make a really large powerful coil.
        -Frank Edwards
bolt
harmonics mean different things to different people. There only has to be a mathematical relationship to be called a harmonic including subtraction and addition. SM also said the frequencies are related to the size of the coil. In my description thats also true. Dont forget these  are only precursor signals i made 2 and i got 3 so the right boxes been ticked here.
I wont someone now to build the bloody thing so next week i can sort out my flux capacitor LOL
turbo
Quote from: EMdevices on September 13, 2007, 04:56:04 PM
I can conclude:
1) The TPU does  NOT use  3-phase or 2-phase setups.   (good luck to Bob Boyce replication group, don't want to discourage anybody)
2) The TPU does NOT use heterodyning principle either (intentionaly but it always occurs)
EM.
well EM i liked the "jet turbine" waveforms you posted a couple of days back MUCH more then the ones you are showing here.
if we study the jet turbine we can see the 3 channel drive and the locked "harmonic" compression technology.
the compression first pushes a blade on turbine rig one, the compresses, pushes a blade on turbine rig two, compresses again and pushes a blade on turbine rig three.
it is intresting to see we do not have a bemf in the turbine.
that is why the canonn ball analogy is so important..
there are certain clues which we can use to determine and get a more clear picture of what is happening inside the tpu.
it is in his words when you pay close attention.
if we fire up control coil one, and we let it go, and fire control coil two,control coil one will produce a force against our RMF.
so it would be constantly working against our goal.
if we look at the canonn ball analogy we can extrackt some important factors.
Now, there can be a further dissipation of energy if the projectile was
carrying a charge of dynamite to explode on impact as well.
Let me expand your mind for a moment....
Suppose that the projectile which you fired was another cannon?
Now you have another cannon traveling at 1000 miles an hour...
Now, if you could fire the second cannon, the projectile coming from it
would be traveling at a velocity of 1000 miles an hour after being fired.
However, since the cannon is already traveling at a speed of 1000 miles
an hour when you fire it, the speed of the second fired projectile is essentially now 2000
miles per hour and the energy available to convert from the second
projectile, is now twice the ten available from the first projectile!
You now have energy availability of twenty to convert from the second
projectile.
Now, what if the projectile fired from the second cannon were another
cannon and you fired it.
Since the second cannon is traveling at 2000 miles per hour then the
projectile you fire from it would make 3000 miles per hour, and so on and
so on....
The energy released from the speed of multiple projectiles increases the
energy available to be dissipated upon impact many fold!
upon impact many fold! that is key,
So here he is telling us we fire up control coil one, then control coil two, and then control coil three.
the important thing here is that the projectiles keep going untill all canonns are fired and then we collect the energy upon impact.
he clearly tells us the projectiles keep moving when the next is fired,so they do not fall to the ground at least before the next one is fired since the speeds add to each other.
basicly this means we do not switch off the controls untill they are all switched on.
then we release the complete coil resulting in one big massive bemf.
this bemf does not work against us because it does not have a real direction ,the flux is around the entire torroid when the field collapses.
it's a one way ticket.
when we switch on control coil one the field will "grow" and be on 1/3rd of the torroid.
then we fire up control coil two and the field will "grow" and be on 2/3rd of the torroid.
then we fire up control coil three and the field will "grow" untill it is on 3/3 or 100% of the torroid.
this way we can create a directional pulsed rotating magnetic field without the unwanted anti force of the bemf per control coil,we collect this energy in one big bemf when the flux is around the full torroid.
The multiple frequencies traveling around the coils are of too high
a frequency to provide for any motive effort.
They are only a means to achieve an end.
The multiple frequencies begin to feed themselves and the
multiple kicks become a combined big kick.
now we need to find a way to use the right frequency "offsets" so we can squeeze or resonate in the magnetic wave,which is already present.(allow it to add and fill up the diferential holes)
so, this methode of creating a rotational magnetic field is somewhat diffrent from what we are doing, or at least what i was doing when i started to experiment with the 3 segmented coil.
That is what i make of the canonn ball analogy, if this is not the case,then we should have seen 3 seperate firing cannons and end up with 3 seperate projectiles travelling at 1000 miles each, but i do not think this is the case....
if anybody makes something diffrent about this canonn ball analogy, let's hear it so we can discuss it.
Marco.
bolt
BTW the rotation may not be real or needs to be designed. Lets imagine you sat in a river which your are pointing up stream and the river is the mag wave. Now i just stuck one oar out into the river at 90 degrees. Its starts to turn me around till im going backwards but the PLL has now stuck my other arm out to keep 90 degrees. Meanwhile i go  along the river doing circles as i keep sticking my arms out to maintain 90 degrees. The rotation will still be at  7.5 the speed of the river.
bolt
Anway if you make a powerful 7.5 Hz antenna you get a massive kick coming back at you. This is not just an idea its real and it works.  Unleash the beast and found out how to control it after.
