Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bolt
Grumpy as i said yesterday im 99% sure they are balun mixers. You can even see the signal injection side has about 50 turns of thin copper wire and the secondary is part of the collector goes through it just once as this is the low impedance side. The wire is glued in place to stop it moving.  At the bottom of the control box are large white film caps which are the LC's to form the tank. There are two one for each coil and they are mixed the same these C's terminate each side of the control but connect to the main collector coils the wire is thicker.  On the ends of the box are black 1 watt resistor poking out these will be like source load resistors to dump some heat so the oscillators do get rather hot. If they are power mosfets there could be lots of amps involved. The control box is rather odd it doesn't look purpose made rather like a recycled thing with brackets and bits sticking. The big caps added later outside look like a bodge job to me and looks rather like my door bell box LOL
In addition in the big tpu there is little feedback control wiring going on certainly not 9  controls as seen with some tpu on here.
I have to believe that the regen receiver is very valid alternative. In addition we could even do away with the PLL by using a simple VCO.  The VCO is loosely centered around 7.5 hz and the VCO could then be controlled by simply witnessing what happens at the voltage output of the device.  Simply if its in tune then power is coming out. Notice also the large tpu has a pot next to the 2 osc switches. This may adjust the VCO or feedback loop so he can tune it in. The drawback of the regen is making the 7.5 osc needs a high Q inductor and massive caps. It will lose the sinewave purity and then we have no phase control. For stability its always much better to start high and divide down.
Grumpy
I don't recall "balun mixer" or any variation of it being posted before today.  I do recall that "mixer" has been suggested several times over the last year+.
Could be anything in the underside of that box/heatsink looking thing.
I would not place too much value in the 7.5 Hz thing.  Go back a page or two and get that PDF of SM's letter's that I posted.
        -Frank Edwards
acerzw
I found a great site about schuman frequencies, this link has receiver circuits, unsure if this is useful or not:
http://electricterra.com/ulf_schematics.htm
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
EMdevices
@ bolt
Why don't you put together a diagram for us, it's hard to follow text descriptions.Ã,  It sounds like you're very sure and just about ready to break out the soldering ironÃ,  LOL :)Ã,
@ marco
I like the previous 3 harmonic signal simulations too.Ã,  I think that's closer to the truth.Ã,  The sims I just posted here are just for educational purposesÃ,  :)Ã,  Ã,  Ã,
You know what my take is on the cannon story:Ã,  SM is trying to tell us that energy increases IF IT BUILDS UPON ITSELF.Ã,   The electrical analogy isÃ,  RESONANCE.Ã,   A signal comes around and we add to it IN PHASE, and the energy builds up.Ã,
Now, he could also be telling us the 3 is important as well.Ã,  However, how we build resonance physically speaking, can have many forms and shapes.Ã,  In the TPU I am almost 100% sure it is longitudinal standing waves, else we could do it with a stick and have a TESLA coil.Ã,   But in a circular scenario the infinite "properties" of a CIRCLE come into play.Ã,  Round and round we go.Ã,  :)
@ Grumpy
Are you having fun nowÃ,  LOL :)Ã,   Looks like you're creative mind is spinning again, and that's good.
@ all
We are revolving closer and closer to the truth.Ã,  It's good to have different angles.Ã,   You see, when we consider the implications of a theory, and how it relates to the SM clues (letters and video) we can hone in on the right theory.Ã,  I've been meaning to put together a matrix of the theories and the clues.Ã,   then in the center make notes on how that clue supports or rejects that particular theory.Ã,  I think that would be a grand project but very involved.Ã,   I've been trying to help out with simulations and theory as much as I can but it's taxing my energies.Ã,  Maybe somebody else can take on this project.
EM
acerzw
EM,
     Might I suggest a visual mind map as a better form of documentation:
http://en.wikipedia.org/wiki/Mind_Mapping
Acerzw
