Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 18 Guests are viewing this topic.
innovation_station
good stuff guys
you will make it sing now
time to build a few of my own coils  ;)  i aint talking tpu's eather ;D
l8rz
is
EMdevices
Ok guys, here's another concept that I mentioned before and it's very closely related to the mixer idea.
Directional Couplers
You see, when you introduce a signal in a circular track, it goes BOTH WAYS.  Clockwise and couter clockwise.
The interference it produces is not rotational (unless signal speeds vary CW compared to CCW) but just standing wave.
Well, with a DIRECTIONAL COUPLER,  you can send the pulse ONE DIRECTION ONLY.
Now you can realy building up a true ONE WAY TRAVELING wave, and if you pick the wavelength just right you can also get resonant build up, and then this wave will pass by and induce lots of energy, because it travels very very fast.
Here's a circuit for an RF Directional Coupler. (from http://michaelgellis.tripod.com/direct.html  )
And how to use it.
EM
P.S.  Note the two transformers are 1:1 just like in the large TPU  :)  Is that what SM is doing?
acerzw
@all
This website is a bit far out but many things we have talked about feature, so there are probably some useful ideas. Worth a good look around but here is the index of one particularly interesting document:
PROLOGUE: IS CURRENT SCIENCE INCOMPLETE?
CHAPTER 01: INTRODUCTION
CHAPTER 02: THE AETHER IS PURE, CONSCIOUS ONENESS
CHAPTER 03: THE COSMIC CONTEXT
CHAPTER 04: HARNESSING THE CONSCIOUS AETHER WITH GRAVITY AND INERTIA
CHAPTER 05: AETHER, ELECTROMAGNETISM AND FREE ENERGY
CHAPTER 06: GRAVITY, MAGNETISM AND ROTATION - THE MISSING LINK
CHAPTER 07: THE AETHER AS SPHERICAL LIGHT AND SOUND
CHAPTER 08: KEELY AND THE PHYSICS OF VIBRATION
CHAPTER 09: VORTEXES, PROPULSION AND MATTER CHANGES
CHAPTER 10: VORTEX SHIFTS OF TIME AND DIMENSIONAL LEVELS
CHAPTER 11: PROPERTIES OF THE EARTH AS A CONSCIOUSNESS UNIT
CHAPTER 12: ET WISDOM: PLANETS AS CONSCIOUSNESS UNIT FORMATIONS
CHAPTER 13: ET WISDOM: GEOMETRY, VIBRATION AND HIGHER DIMENSIONS
CHAPTER 14: VEDIC YOGA, SETH AND MULTIDIMENSIONAL COSMOLOGY
Some good stuff in here:
http://www.divinecosmos.com/index.php?option=com_content&task=category&sectionid=6&id=19&Itemid=36
Acerzw, food for thought
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
bolt
Think about the simplicity of the 1st control unit. 2 or 3 coils and tiny toroidal  balun sat on top. We are going back 15 years now to when that was made even though it was demonstrated in 97 so 92 electronics much of which was still discrete and as a working prototype almost guaranteed. There is certainly not much room in there to do more then very basic oscillation and feedback and i think it unlikely there is anything as complex as a Xtal in these devices. To me they appear to be free running. If this is true then any controlling or feedback must come from those frequencies and circuits that are already providing the basic oscillations. If harmonics are involved then they can be seen and tried later. Its very unlikely anything is switched. Switching causes spikes and spikes are nasty. The combination of taps and feedback will create the parasitic oscillations.  There could be a radio subset IC inside or PLL VCO but im very sure thats the lot.
So the first step is to get one tuned very close to the mag wave till currents and heat build up in the loop or start popping fuses. No one has even got this far yet and needs no controls to achieve this. The controls are in place to tame the device and provide the circular rotation.
There is little more to discuss other then building one. I read SM doc right through again tonight and i placed 20 out 20 ticks against my model to his notes. In addition EMdevices has witnessed this 7.5 Hz oddity on his motor experiments couple of pages back.
I will say this now this thread is now in resonating at last. If we stay tuned in to pure sine then things happen.
Just need to clear this up for grumpy first
Quote from: Grumpy on September 13, 2007, 07:41:08 PM
I don't recall "balun mixer" or any variation of it being posted before today.  I do recall that "mixer" has been suggested several times over the last year+.
Could be anything in the underside of that box/heatsink looking thing.
I would not place too much value in the 7.5 Hz thing.  Go back a page or two and get that PDF of SM's letter's that I posted.
this is my post from last week.
"Why SM may need to use balun? This could also be useful to provide the correct impedance of  the sig output to collector. The sig gen will be very low impedance and unbalanced even the mostfet PA stage is designed to run into very low impedance..few ohms. The collector coil will appear as several hundred ohms balanced. We know that a twisted pair has a 300 ohm impedance same as EDIT folded dipole (open unbalanced dipoles usually low impedance 50 or 75 ohm) and the collector coil could be as high. If the sig input is mismatched then we cannot transfer enough useful signal in to the collector. While writing this it certainly occurred to me the collector is a magnetic dipole!  LOL oh heck it gets better. The two collector coils ARE balanced and fed into the balun."
EMdevices
A visual map?    What a great idea !!!    LOL   :)   :D  :)  :D
