Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
dutchy1966
Bolt,
Are you trying to say that the load is not directly connected to the collector but to the little toroids in the center? For the sake of impedance matching?
Robert
bolt
I try and draw a simple circuit but will be a crappy one done quick with winblows paint. You know that a professional version TPU would most likely use a CPU running fuzzy logic. Then we can have soft start, auto tune oscillators, phase control, over current, over voltage, over heat etc and control over exactly the output voltage is providing rather then dipping on loads. So no doubt the new ones hidden in some dark places of the earth run perfectly like a modern switch mode inverter. Why not make a 100 K watt one with the collector as a copper water pipe to keep it cool.
innovation_station
anyone winding a collector pancake yet at 3.99m or 13'1" this is the center ring only 1 is needed  for the center collector other 2 rings they should be balum coils? and they should be the same base pancake tuned to the same 7.5 hz
anyhow for the center one make it buzz at 7.5  then we find second harmonic on that coil  (using a scope) and 3rd as well
after that 2econd and third go to the other coils   is this correct?
ist
starting to get a picture in my mind i only have 18 ga speeker wire right now but will give it a shoot it is easy flow as well  i can not run it tho but will build it so you can see the picture i have of it  it is much similar to this pic  when i find it i will post it
@bolt why dont we use the hot water to heat the house and water tank too  ;) i have a design for the hyper heat unit it was a portable space heater but it can now be a power supply too  ;D
tryed to find the pic i must have deleted it  so  i threw the coil back togather  real quick and took a pic of it  now no need to tell me it is wrong i know this but verry close to what we want i will be building my next 1 tonight it will be close to that but center collector will be diffrent  it will be 3 freqs not 2 as the 1 in the pic is  the center collector will have many 28ga coper turns in 3 segments  i will build this soon i cant run it tho unless some one comes up with a quick alternitive to the circuit like an class a audio amp and a laptop or somthing like that
tao
Quote from: EMdevices on September 15, 2007, 01:05:57 PM
EM
Edit:  thanks for that posting tao,   do you think these people made a typo?  " ..In
the core of this outer toroidal coil is the instrument package....
"     I think they meant to say CENTER ,not CORE.  :)
For the smaller TPU devices that are wrapped in black tape, but have no electronics in the center of the device, the control circuitry would have to be in the CORE-AREA...
I think that is what they are referring to.
bolt
Rough layout. The collector is one core of speaker wire or lamp wire not 2 and its not bifilair wound, twisted, pancaked tripled just wound and the ends go through the balun ONE turn. The balun is a ferrite ring, not plastic brass wood or a chocolate cookie. At this stage no need to worry about precise resonance can be sorted later so about 10 turns for collector is fine.
The control coils is 20 swg 100 turns for each. The crossover wiring may not be correct nor direction i think one control is wound anti clockise to the other but thats bench work.
The 1st control coil only goes to the balun 50 turns thin copper wire size TBA.  Another balun winding 50 turns same size wire goes to Sig gen box and connected to the DC to 1 Meg or much higher Class A power amps MOSFET only DC couple vital  least 3 watts.  So the balun is mixing ONE collector, One control coil and One Sig gen box.
The output coil is an overlay coil 20 swg normally hundreds of turns over the entire TPU but for testing purpose 100 turn should be good enough to sniff the collector and maybe a diode on one side might be needed i not sure it might kill it.  The output winding is floating the ends do not connect anywhere else except the load which should be a 60 watt lamp.
Don't forget the magnet or nothing will happen. Make sure you put fuses in the collector, kill switch etc. DONT touch the output wires to feel if anything coming out. LOL
