Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
This is a quote from another site so it can be shared as much as possible...
Anybody want 'New'?
Posts start on 20070204
http://www.overunity.com/index.php/topic,1872.msg22841.html#msg22841
http://www.overunity.com/index.php/topic,1872.msg22844.html#msg22844
http://www.overunity.com/index.php/topic,1872.msg23001.html#msg23001
http://www.overunity.com/index.php/topic,1872.msg24037.html#msg24037
I have hooked in the stungun to trigger the 20" easyflow cable 6" loop. That experiment took down my cable box, wireless router, reset and shutdown the workstation. I felt the tingle that Tesla talked about. I posted this before with the GK4 on 20070113. Again the TPUs have their feedbacks wrapped around the rings. The large TPUs have their feedbacks inside the rings. At some point SM converted from spark gap to solid state. One could also make a very small spark gap from a small rubber tube with a short nail stuffed in each end. Why is this neccessary? Smack the copper! This was a clue prior(the back side of the SM17). That was a failsafe? Don't be stupid! A stungun type circuit(Boost) is the secret for the trigger. Otto's, 390721 bucking coil,  jumpering makes kicks without the smacking circuit. But with the kick pulse fed with a boost circuit you get a raise in the potential level.
I have results. I received headaches and others have burned themselves. I have posted. And this is nothing more than you all know as of now. SM had described things to keep the greedy off course and at the same time everything he said has 2 meanings. Have a clue. The guy is a genuis in puzzles.
Posters have slammed Steven Mark, Mannix and others. Not only have you wronged others but largely your own selves to a dire degree.
Check out who else has kicks. Doesn't it make you wonder why? Aren't these important?
Looks like he who posts the best diatribe owns the subject? The TPU feedback operation was my explanation on 20070204. The TPU is also a closed loop stungun. I had posts deleted on the other sites. I have received numerous design answers offsite from Mannix & SM and others who I work in labs with. I am the poster for these actions.
Secret club? I am sure somebody will raise their torch and pitchfork to burn out the infidel. But I have figured out the clues given and the pattern of how these are posted. Alot of people don't like games. I enjoy the 'cat and mouse' game. I visualize just like Tesla. I get an idea and throw stuff together. I am on 5 different paths right now with this technology. And the things that work are on my bench. Why don't I share? I have. I am on a roll to catch up with the flood on solutions that have become apparent to me after I built each step. You've all seen the pictures of Tesla in the huge spark field? He is sitting inside a huge stungun. Have a clue. Has anybody found UEC or the patents? Have a clue.
I was mocked for posting production plans of the SM17. I guess you won't work for me.
I have learned a massive knowledge and experience from all the sites and close relations with a certain few. And a great thanks to you all. The last 6 months in these sites has given me the knowledge to match up with where I dreamed my life would be.
This post has all the TPU triggering functionality necessary for operation.
--giantkiller. 'I know Kung Fu'. No shit...
Grumpy
GK - you are starting to sound mentally unstable.  I recommend a stout alcoholic beverage.
You will not copy the TPU unless SM himself tells you how and he's not doing that.  So don't go thinking you figured it out and duiplicated it or any crap like that - regardless of what you come up with.  Look at all of the changes in direction and various explanations that have come from SM.  Throwing greedy people off?  No.  Only those who would copy the device.   No one but Mannix persued this device for ten years or so.
Three collectors, but no explanation why. Kicks mixing, earth's magnetic field, flipping device over, rotating compass, etc.
Who ever said that each TPU works the same way?  Perhaps some versions only collect and the others generate.
You are going in several directions at the same time - at one point the device is described as a generator and at other times it is only a collector.  I wish SM would make up his mind.
Re-read SM's comments on Tao's thoughts and you will see that the damn collectors go on the outside.  Also, no mention of feedback in that message - no three collectors - no rotating field - no precise frequency control - no three frequencies - no tubes - none of that BS.  Just pulse the damn wire and make sure it stops before it reaches the end. (Speed of propagation, pulse rise time, etc.)
        -Frank Edwards
FatBird
GK, Thank you for shariing your StunGun & other ideas with us.
Because I value your expertise & opinions, may I ask a couple of questions:
1.  In your opinion is the 7.3 Hertz frequency still necessary for a functioning TPU?
2.  Is a rotating field necessary for a TPU to work?
Thank you.
Moab
Fatbird.
A SWAG.
1 yes a harmonic of 7.83
2 rotation is a byproduct
It's like saying is heat requiard to make light. It is not. A firefly makes light without getting hot.
Go GK go! thanks for shareing!! moab
giantkiller
I built the charge chamber out of a piece of yellow rubber tubing and 2 huge nails.
I succeeded in removing the stungun circuit from the casing safely. I can put it back together again should I decide to do so.
Now,
You can see in the picture that the rubber chamber is aglow. I moved the device away from my pc desktop. With the nail/conduction points closer together than any other circuit parts the charge is in the tube instead of outside. Another safety point. And it is also quieter. I really don't want it exposed anyway. I am chasing the effect in the loop of easyflow audio cable that was attached during the previous test. I will put that back in. Now this is best part. My next step is to attach one of the 555s of my controller circuit to the trigger and fire that at? (you gotta guess the frequency). Oops, times up. 7.8hz. Surprise! I will try a whole wide band of freqs while I am here anyway. Right? No telling what happens when Frankenstein blinks the first time, eh?
And the good news is I can grab the charge chamber with no shock and again there is no heat.
The power draw is +14 amp spikes. I got to change power supplies or get an automotive battery.
Another path I am going on is to fire GK4 with the circuit. And that is if the 30awg controls don't offer too much resistance. I can see why SM said lamp wire. I have GK5 which is totally lamp wire, hexfilar controllers / feedbacks with easyflow collectors. The stun gun circuit wants a dead short to the spark gap.
The next step is gonna be fun.
I hope the picture is clear enough.
--giantkiller. It's been another great week. I hope everybody else had one too.
