Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Quote from: innovation_station on March 25, 2007, 04:36:01 PM
ok just built the square coil and tested it and as i thought i ght much better results on the pluse test i reached 5.31 volts and it lasted much longer but i could only get the voltage as low as .40 i used 4 gage stranded car audio power wire and the same fine gage wire with about 200 winds only 1 coil
Very interesting. I never thought about stripping some of the audio to get the fine wire? But mine is not individually insulated though. So your windings cannot touch?
--giantkiller.
innovation_station
Mannix
Quote from: Motorcoach1 on March 25, 2007, 03:28:16 PM
Hello TPU researchers : HERES MY THEORY IN HOW THIS WORKS.  Years ago i experimented with the Cook Battery ( patent was given in 1871 ) in looking  at SM coil design intrigued me. Looking at the primary side of the coil _ you have a copper winding in a ring laced with a steel helix winding.        The coil windings are 90 degree wrapped around this primary winding ... This winging is very important for the Tpu to function .... when the Mofset is fired from the Capacitor ,,the Field MF collapse must be strong enough to charge the 2nd capacitor. IN charging and discharging  the caps this starts a cascade effect. now whats so cool about this is we start a stair step effect in the coil ( one of natures secretes ) This makes the electrons flow at high rates in the copper ring coil producing a small electrical field (primary)> the next level we put in another ring of steel wrapped in a ring fashion on the top and bottom of the primary ring with the coils on it. thus producing a (onion)MF.. copper  wire is then wraped 90 degrees to the primary ring _ this is the secondary elictrical out put (high voltage...@ high frequency.. DANGER THIS WILL HURT YOU !!!!)...... To start the TPU a magnet is waves through the onion MF this pulls the feild 180 degrees ...when the feild springs back the colapse takes place chargeing one or both of the capcitors and the cascade takes place and stairstepping goes in to action. I write this in memory of Jim Sullivian RCA 1957  my mentor and friend from many years ago.  The future in in bits and pices of our minds , only evil and greed will misspend our childrens future. I strongly feel if we take the steps now we can change this. new technoligy will have jobs in the future as time changes . mmmmm wonder why Nippers head is 180 degrees  ;D
I like your explanation
Motorcoach1
An electric current flows thru the wire producing a magnetic field. Then the electric current goes around the circuit and flows thru the wire again producing more magnetic field. The back EMF stops the flow of current. Then the magnetic field collapses driving the electric current backwards thru the second coil going around the circuit again and again. Once again the magnetic fields builds up. The back EMF stops the flow of current, then reverses it. And we start all over again. The electricity is used over and over. The more it is used, the stronger it gets. It only stops when the circuit is broken.
innovation_station
