Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
innovation_station
Motorcoach1
heres a thought-  in looking back t what SM started with a flyback transformer from an old TV set. So i been studying the construction of these and see the air gap is what makes them unique as this type of transformer. The air gap is what holds the energy that boosts the power up. I believe that the 4 magnets is just a containment Field that holds the electron Field in place so there just not flying all over the place and migrating. The steel garden wire i believe is the armature of the torrid devise and the primary winding would be a large size copper wire say 12AGW and the Primary a much smaller wire say 30 AGW. the another unique thing about the fly back is in order for it to work only one coil at a time needs to be energized ( the primary or secondary), now in most flybacks thees a 3 coil - the bias coil, this coil is there to control the spike that the secondary or the Primary coil gives off when the electricity is removed and the Field collapses amid produces the EMF, This EMF energy is sucked up in the air gap and is boosting the output of the transformer. The 4 magnets hold the EMF electrons on this air gap - more electron in the air gap = more power. also the bias coil tunes the flyback -reajusting the bias using the royer circuit will boost the whole mechanism.      In the cook coil patent it shows the coils and how that operate but what it doest show (intellectual property) i believe is the switching mechanism. This circuit operates the coil output and starts the coils. In the Hubbard patents the 8 coils on the outside of the main coil is a containment Field for the electron in the air gap. i believe in the cook coil the switching patent is in a separate patent -i haven't searched for it as the technology may be moot with the newer switching devises we have today. On the primary coil were working on- the primary ring winding has 4 coils wraped 90 degrees , energizeing and denergizeing these create a EMF field that inturn keep the flow of electrons flowing around the ring. The secondary has no coils around it but in turn when the feild is colaped and the primary coil is in the off mode the secondary kicks on (spike) this energy is sucked up in the air gap as electrons to be used as electrical energy output. just something to ponder  Thanks Mike  :o
on off on off on off on off on off on off
Motorcoach1
@ Inovation : did you study the link i left on page 67 ( International rectafier ) PDF file on designing flaybacks .  A must read  here it is again  http://www.irf.com/technical-info/appnotes/an-1024.pdf   notice the section on the bias coil and take into cosideration on noise and capacitance. and why toriods are not sutable for this type transformer. .. Thanks Mike
run eddy electron run <  :o
innovation_station
Motorcoach1
@ Innovation ...no i didn't misunderstand LOL ..I feel that is a possability too- some one needs to look that direction in this reasearch , glad you are looking into it. I'm building what i call my big washer TPU 4 in in dai. 2 primarys and 2 secondarys 15mm air gap 4 small magnets in gap. going to try cycleing the primarys to flux the capacitors into life. Then try the secondarys no coils just the bias . thanks Mike
pull the leaver egor
