Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Hello,
I am pursuing Uncle Fester's ckt. It is a minor change for my 8 channel motor controller. Plus I have a broken copper run on the one of the boards to fix.
I am going to take a slightly different approach with this. With a quad phase control I don't need the wire for the feedback pulse circuit to the next coil segment(I can do that later). That is where my motor control circuit will sequentially run through the controller coils one at a time. I can also vary the duty cycle and keep it less than <50 percent. And guess what? No runaway. That is your safety tip for the day. UF's ckt can't runaway either because the 4th segment has no feedback coil to trigger the 1st control coil. Pretty smart, dude!
This operation will perform the rotating field that seems to be so desired.
I have the GK4 totally stripped down (Empty terminal connections. Can't show pics, nudity not allowed) and connected per UF's schematic.
I am also going to try putting a dc bias on the collector to a enable a one way path. This is to see if the Radiant Energy can be swept in one direction instead of spattering all over the place. Just a try.
I have supplied the motor controller circuit schem. There are 8 outputs of the 74139, a 2 to 4 line decoder. Just duplicate the coil driver on the Q1A line.
The duty cycle is controlled by a 555 one shot to the enable. This new addition is not on the schematic. The one shot is triggered by the rising pulse of the main 555 astable. The max frequency for any given channel is 250khz.
The beauty of this circuit is it can drive 2 TPUs of any collector layer count and any direction. Even opposing. Hmmm?
And that's today's lesson with Mr. Wizard. I've had the flyback flu for 7 days now. Things were going slow. Maybe I can catch up.
--giantkiller. Patience is how we earn our keep.
giantkiller
Carmen sent this to me and I am posting for her here:
Kicks again!
http://www.youtube.com/watch?v=kTdUBSz-9Qo
The facts in the common conversation are amazing and very revealing.
Mr. Muller stated that:
Iron core equals current and air core equals voltage.
Small magnets equal voltage, large magnets equal current.
One side of the rotor was positive and the other was negative.
They used a clamp on ampmeter.
More magnetic shearing effect. Bedini devices do too.
More to come.
--giantkiller. http://www.mullerpower.com
supersam
hey GK,
how about the, battery to inverter, to toroid, to secondary, split!  try this half the output back to the battery to charge it,and half to a device.  maybe keeping the pendulum running in the Milkovic dual oscilating pendulum???
lol,
sam
Sauron
Quote from: starcruiser on March 30, 2007, 09:53:13 AM
I forgot to mention, use a variable resistor in the base divider circuits to tune the sensitivity of the triggers and a diode on the control coils to protect the transistors from the BEMF spikes.
hi there starcruiser,
this is the problem, we are doing this in all circuits all the time.
destroying unwanted energy.....
who knows what can be done whith them...............
Jdo300
Quote from: Sauron on March 31, 2007, 05:32:24 PMhi there starcruiser,
How about capturing the spikes and using them to recharge the pulse cap...
God Bless,
Jason O
