Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
innovation_station
starcruiser
@IS,
I can understand your frustration, I, like Giantkiller, have been following this saga for over a year, at first I just read and researched, then when I felt I had enough of sitting on the sidelines I jumped in, some others had to wait until they had the resources (parts or test equipment). So do no let this go by if it really interests you just start out by reading and researching and then start discussing with the rest of us. Please note that some do not read all of the SM thread which can help answer some questions and stop you from presenting something that we already have covered.
The last thing I want to do (and I am sure others as well) is to mislead anyone working on their own TPU. It should be recognized that SM has provided us insights and clues to his units actual operation, but due to other constraints he cannot outright give us the design. So as a result of this we are acting like detectives to sort it out and learn as we go.
Now in regards to your statement regarding the collectors;
The running of the power thru the core/collector is similar to the negative inductor or Genesis project (I believe you posted on this prior) which we have investigated and I have tried with no real output. It is possible that I may have constructed it in correctly but???
What I find interesting is some of SM's comments regarding neutralizing the magnetic field, this is similar to a project that JL naudlin has done back in 1997 I think it was. Which speaks to orientation of the copper wire to a magnetic field (90 degree coupling) in which the flux is neutralized, not directly acting onthe wire and yet current flows (is induced) in the wire.
Another is the thread on the Phonon which speaks to crystalline structures and HV fields. So as you can see we pull insiration from many sources to understand that which is yet unknown to us.
So as a result all of us who are working on these TPU's are trying several directions to narrow the possibilities and get us all to the promised land.
I have been reading all types of materials for inspiration and trying various experiments (as should we all) to understand the effect. I am currently pursuing the super pole magnet direction to see if the sharp field gradient will provide any results. This is why I posted something in relation to that, in order to share this knowledge with others that may already have a TPU built that can try this and see if they can get the same results.
For sure this is a project that requires more test equipment than some may have, the minimum required to work on this device is a decent Oscilloscope 30 to 50 Mhz BW, several DVM's and/or multimeter's and an inductance meter and other various tools.
If you have some insight please share it but don't expect an immediate response, it takes time for us to review, absorb and implement/experiment to validate. Beyond that we all have day jobs and we are spread out across the globe so that being said this slows our response time.
So if this post doesn't put you off (not meaning to), hang around and read the threads (here and elsewhere) and pretty soon you will be right there with us working on a TPU and who knows you may solve this puzzle!
Regards,
Carl
giantkiller
@Starcruiser,
Amen Brother,
After agonizing over a response myself, I couldn't have come with a better one.
@IS and All,
I left my initial posts intact in other threads when I first started in on this. Needless to say I misjudged the audience and look back in total embarrassment at some of the things I said. But we grow.
Fustration is not a meal we should consume or let consume us. I got past that due to investigating and achieving results. Patience is the meal before dessert.
@IS,
I know you can't chew your leg off and get away that easy. I was impressed with the coil you posted. That is enough to put you in the kicks club. It just has to be validated somehow, like a scope shot or diagram even with unknown values. But I do know this: a lot of small wire wrapped many times around a large one will achieve kicks. It is the simplest circuit. My 130v kicks produced a 2 foot magnetic ball. Now that was fun on the guitar as a pickup. If you got 1kv spikes you should be able to pull a neodynium magnet from 1 foot to the coil, easily. Or make it turn. Think cheap if you have to.
Hey, you slapped some leftovers together and got kicks! And I might add in quite a minimal timeframe. More than most of the readers and highly trained posters here! Be thankful.
So don't go away mad like others. To the victors go the spoils! There are a huge amount of applications after this next step. And anybody than can think for themselves knows it. I was told that the world will be changed 180 degrees in 2 generations from this.
Patience weedhopper.
--giantkiller.
starcruiser
@GK,
We all will get there, time is the main ingredient with a dash of patience.
Thanks for the mention BTW.
Regards,
Carl
innovation_station
