Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
dani1
GK, did you made a test with a photo plate?
I hope you do NOT get such results:
http://images.google.de/images?svnum=10&hl=de&lr=&q=r%C3%B6ntgen
..dani
Dingus Mungus
I wonder if there is a way to meassure if there is any A/B/G/X rays being emmited... I think you need a filiment of some sort to emmit those rays, but I guess one can never be too safe.
giantkiller
I am hooking 'My precious' back into the circuit. We took a little walk today.
I am attaching a tuning fork to it like I was instructed to do.
Testing will commence shortly.
Here goes:
At the low freqs, tuning fork no good. @ 13K tuning fork no good. But coil sings hi pitch. Coil get very warm.
I feel a slight pressure on my ear drums. Probably from the hi pitch. I get earplugs. Stick ear plugs on coil. Feel much better now. Coil lookin good!
Lay tuning fork across coil @ 13K, fork no talk. Put fork on tongue. Guess what?
I can use the scope to track harmonics and that will let me do an amperage check 'on sync' and 'off sync'.
On resonance @ 13k, Ampmeter @ PSU says 2.18a +150v p2p. -10v visible.
@ any resonance point the coil gets hot but the amps are around 2.03 - 2.06 and the volts are 130 - 190. But here is the thing when the coil is off resonance it looks more like a short and the amps go up to 2.25.
So here is my take with the sloppy pots, the coil seems to work like a normal transformer. You can hit the impedance level with the freqs. All harmonics show hi volts. On average it looks like 300 watt draw. But this device puts out kicks like a stun gun, but no sparks. Adjusting the harmonic range speeds up the kicks, naturally. But you can feel other things with your hand. Oops, that was the other day.
But on the coil @2k the coil gets the hotest. prob the 4" diam. but the amps = 1.92 which is the lowest.
No, at 500hz harmonic I get .92 amp, 140v, and a very hot coil. Ok I touched it, i'm sorry. But I left it in its cage, really. I won't do it again. But this is the best yet. Hot coil, good voltage, lowest wattage.
Could somebody please step up and back me up with their tests? Am I the only one? Ok I am going have to change my name to THX1138.
But wait, So now I do Rock and roll test:
freq a: 3.4k
freq b: 3.4k
freq c: 3.4k
130v spikes out 70usec cycle width. Produces a magnetic ball radius of 12". How do I find this out? I turn on big BOSE power tower, turn up loud,  hold axe next to coil. Now whole neighborhood know I doing freakazoid experiments. House shake big time. I adjust freqs. Hmm, me sound better than Jimi Hendrix. Could be that waves affecting my judgement.
So the Rock -n- roll test goes on for 1/2 hour. 130 volt spikes, coil warm to the touch, ooh I'm sorry, 0.61a. steady. After ready Grumpy's statement today, it made me think that I need to just pick off the kicks externally. So if you can get a nice stable stream of kicks then you have generated consistancy. And that I should be able to induct off? I bought some great 8 gauge audio cable to wrap the coil with to get a ring. ;)
An hour later and wouldn't ya know it. The Rock -n- roll continues to perform very stable.
coil is a little warm.
I have been sitting next to the circuit powered on for 2 hours and now no head pain except for the headbanging while my coil played the guitar! But the biggest news is that the screen cage works! The heck with the rest, I got safety, Jack! Thank you for the post for that.
This was with 3 seperate clocks.
But I have to change the pots out for finer control before anymore testing on this bench.
Stay tuned when next time giantkiller says 'I now put in 1 clock for parallel feed'. Oooh. The crowd roars and he takes a bow as the curtain closes.
As long as I am a one man show guess I run the show? No fun playing alone! Need friends!
--giantkiller.
Spherenot
Quote from: giantkiller on January 08, 2007, 11:28:43 PM
And how shall we stick thine ear plugs on thee coil, oh great one?
...fork no talk. Put fork on tongue. Guess what?
Fork tongue.
You slay me.  :D
giantkiller
Look ma! Baby's first words! kick,kick,kick,kick,kick,kick,kick.
Why he got your turns PA! Yep he's a real perfomer this one is...
Ya know ma? I think he just waved,waved,waved at us!
12 volts @ .61amps
50usec / div,  20v / div.
--giantkiller.
