Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Moab
Ok then, Just out of curiosity what did you discover?
Rosphere
Quote from: giantkiller on April 06, 2007, 05:32:55 PM
...(5) 23 foot lengths...
...a 1 inch height of 4 inch diameter sched 30 pvc(the thinner stuff) [0.0695" thick]...
...the 4 control coil segments of 30 turns each..
30 turns, at a bit over 2 inches per turn, makes almost 5 and a half feet for each control coil.  Where are the other 17 and a half feet?  I am so confused.
Did you mean, (2) 23 foot lengths, one uncut length wrapped around the ring-circumference and the other length wrapped around the ring-profile as 4 cut sections?
If so, I highly suggest removing three winds, (from current 30 down to 27 winds per quadrant profile-wound control coil,) without cutting the length.
Also, are you pulsing like 390,721 where N N appears to be 90 degrees apart from N1 N1?
This will be my last post for awhile.  I will be far away from the grid for many a day.  Be kind to one another.  Post no crap.  If you did, then take it down.  Later, taters!  :D
Rosphere
innovation_station
Moab
If he is pulsing a coil to make a mag field, then he is probably takeing a mesurement from the vertical coil. which would read in the MV scale. from this he can see what the resonance of the field is from the tiney currant in the vertical coil, then drive the circuit with the correct freq. More of a magfield test IMHO than an attempt to gather any power. ;)
giantkiller
Quote from: Rosphere on April 07, 2007, 08:48:41 PM
Rosphere[/b]
The control coils are 4 sections.
The bucking coils are nn ss all connected together.
