Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 31 Guests are viewing this topic.
innovation_station
innovation_station
Moab
Quote from: innovation_station on April 09, 2007, 09:54:24 AM
ist is kindly asking turbo to come and  help explain for the people as i do a poor job of it but i will try soon!
ist
Ok, i will fly a holding pattern. Waiting ;)
Jdo300
Hi Otto,
I do know that it is possible to make a rotating field with only one control coil. But as far as I understand, that requires a high frequency going through it. If you use two-conductor spearker wire as the single coil and run a single frequency in one conductor, and then come back and go into the other conductor, at some frequency (probably in the MHz depending on how long the coil is), you will get a 90 degree phase shift between the signal coming in from the frequency source and the frequency coming out of the first conductor and going into the second conductor. This might produce the rotating field since there would be a 90 degree lag between the signal in the first and second conductor :-).
Just my two cents worth. Could you give us more information about your findings?
God Bless,
Jason O
otto
Hello all,
you dont need a high frequency to get a rotating field. Its only 5 - 10Hz and you can clearly see the little magnet over a collector coil spinning like a champ. Im using only a 1 turn collector and a 50 turn control coil. My test.jpg is here in this forum or at ctg labs at page 75 I think.
Of course this is achieved with pulses and they shoulde be DC.
You will soon have more informations.
Otto
