Acoustical feedback energy system
Started by aleks, December 10, 2020, 11:00:51 AM
aleks
Quote from: Paul-R on December 12, 2020, 06:26:38 PM
It will depend on phasing. Depending on the diameter of the circle and the frequency, they could cancel, partial cancel, reinforce or rip the cones to shreds.
Ah, forgot to reply to this comment. The "sinewave frequency" I'm speaking about does exactly that, affects the balance between speaker cone movement and opposition: the correct frequency puts the system into a paradoxical state at which all 6 speaker cones are opposed by soundwaves from the opposite loudspeakers. If this system is completely symmetric (a hexagon), it requires only a single sinewave signal source of correct frequency to put it into this state.
As I have not got beyond a blown fuse, I'm unable to give estimations how this system evolves over time. It's very possible it produces an oscillation naturally (moments of paradox followed by moments of relaxation).
acoustical sound feedback energy :
"hearing" a. Kraftwerk sound in that ART&KIND and EURYTHMICS "1984" and The Human League "Being Boiled"
https://www.google.com/search?client=firefox-b-d&q=eurythmics+1984+
Why is the Colosseum/Arena round,sur-rounding wave !? Soccer :home team 12th player , to 10th and less the opposite team diminuaiser
      https://www.youtube.com/watch?v=yiKFYTFJ_kw     impressive influencing the other  :o !
        by compressed force expression  8) (or only 1%,not all)
                    WE   R   the CAT,you only the MOUSE !                          (Attention : inverse Tom&Jerry  ::) )
Sincere
OCWL
NdaClouDzzz
Quote from: aleks on December 15, 2020, 02:36:29 AM
This is worth a look: https://youtu.be/rdLMtEZqGdE
aleks
Quote from: NdaClouDzzz on December 15, 2020, 05:37:28 AM
I think I always believed TPU and overunity devices were connected with air, or in-material super-sonic waves. Air/matter transmits energy via physical means, which I would say is "orthogonal" to electricity. It allows to get that electrical "squeeze" which frees a pathway to the energy from space/aether/whatever. The acoustical system presented here, if it works the way I think, is one of the most efficient and scalable ways to get that "squeeze".
´power(energy) source : all above ,actuall official above 0°K temperature=pressure=density
http://www.rexresearch.com/invnindx.htm A-Z
photonic(visual)-phononic(acoustical) feedback system ! All possible iniciation: im-pulse !( like choke) sources !
the human body : 37° C
https://peswiki.com/directory:fellows-thermoacoustic-cycle-tac-generator
future ? like solar dots http://www.rexresearch.com/sutera/sutera.htm  http://www.rexresearch.com/szili/szili.htm
MEMS-TAR pacemaker
basic permanent source     X       https://www.youtube.com/channel/UCF0Xz9h7mOde4y39ANX9DBw amplification for :
  open space-maker,up to 24/365 "earthonaut"-overall : https://www.google.com/search?client=firefox-b-d&q=dune+ desertsmen wear :
        12 Wmax per human body
                                                      http://www.rexresearch.com/cuinanoagwire/cuinanoag.html
                                Super-insulated clothing could eliminate need for indoor heating                                Tect-free living,only for bad weather protection ?
        Where possible ?!
https://www.google.com/search?client=firefox-b-d&ei=LLDYX_b2Ds72gQa585LYBA&q=rexresearch+nano+fiber+wear&oq=rexresearch+nano+fiber+wear&gs_lcp=CgZwc3ktYWIQDFDvygZYwesGYICCB2gAcAB4AIABlgGIAcoLkgEEMS4xMpgBAKABAaoBB2d3cy13aXrAAQE&sclient=psy-ab&ved=0ahUKEwj2vLyxgtDtAhVOe8AKHbm5BEsQ4dUDCAw
http://www.rexresearch.com/tarakcioglu/tarakcioglu.html
http://www.rexresearch.com/nanosilver/nanoagpat.htm
The Earth ,inner temperature ?  :  outer velocity/speed 40000 km  /24 h                    wind water solar walls-overheat  cars-overheat
Solarsystem  velocity/speed ?
cosmic energy ,stars energy,solar radiation,lunar radiation, earth radiation like Radon/Radium ,atmospheric nitrogen/hydrogen/oxygen
                 carbondioxid as industrial raw material,for refrigerant cycles Wilhelm Haeberle ,window insulation gas ,et cet. ...
Corona family viruses/viriones therapy : uv treated saltwater duche http://www.rexresearch.com/tsen-uv/tsen.htm
each human Echo Hall = memory  feed and feedback power (energy) system             deja-...... actio/reactio
search&found power(energy),angryness power (energy) about ourself= we R not 100% perfect and only 50% from men,male or female ,the specific case : transsexuals are in se.xus change ,probably in doubt/s momentum
