Selecting the right L/C ratio for tank coils
Started by Thaelin, January 27, 2021, 09:40:31 AM
Thaelin
   Since many different values of L/C can be used for the same frequency, how do you select the best pair for a given frequency?  I am working in the 20 to 80 khz area.
thay
NdaClouDzzz
I would think something along these lines:
https://youtu.be/r0Fq2BCtlOM
boguslaw: "Please explain your method of finding resonant frequency"
Armagdn03: "Two methods. One is to place the oscilloscope probe hear the coil and note when you have maximum peak to peak voltage. Two, place some sort of visual indicator in line with the resonant circuit....In this case a incandescent lamp. When the lamp is brightest you have minimum impedance within the circuit indicating resonant frequency"  http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/14511-energy-propagation?p=436362#post436362
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-6/parallel-tank-circuit-resonance/
https://youtu.be/x-1EKjOtrPM
https://youtu.be/R2y9w9cbwcg
Magluvin
Quote from: Thaelin on January 27, 2021, 09:40:31 AM
thay
Well according to Tesla, you would want your resonant freq to be low. From what I understand, 50khz and up will radiate magnetic energy that you cant get back into the system. Loss.  So large inductance and small capacitance would be a criteria to follow.
Mags
MasterPlaster
thay
It is not as precise as you think. Just tip over the box of capacitors and grab one then,  find an inductor that satisfies the equation.
As an alternative, my ex-wife used to select the capacitor by colour!
AlienGrey
It all sounds like you have all need treated or taught via the mushroom method (kept in the dark and fed bull shit)
But doing it all on a hit and miss basis like your saying your going to have poor Q factor, err so what's Q ? don't you think you had better find out ?
While your at it find the right capacitor value to match your frequency to your inductance.
SIL
