Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
@lancaIV,
The force of a phantom magnet appears as if by magic in the horse shoe stator when Hildebrand magnetizes his magnet core iron sleeve! That quadruples the input in magnet strength. You are absolutely right!
synchro1
This fan could spin a ring with the reverse coil pole:
And the difference between:  http://www.rexresearch.com/flynn/Ppfigure3.gif
1721 grams two magnets + 1019 grams conventional = 2841 grams         related       3845 grams Parallel Path
Other view and calculation : 3845 grams - 1721 grams = 2124 grams       for 1019 grams conventional       electric C.O.P. greater 2
https://patents.google.com/patent/DE3938577A1/en
When the power supply to the primary coil 35 becomes zero, the magnetic field of the outer web 32 collapses, the strength of the magnetic field of the outer web 31 is reduced to half, and a corresponding magnetic field in turn arises in the inner web 34 , again due to the change in the magnetic fields in a voltage is induced in the secondary coils.
Electrical energy is thus generated by pulsing current surges into the primary coil 35 .
The energy balance of the converter is as follows:
Input: electrical energy Output: + permanent magnet energy
Current account:
The performance is frequency-dependent:
L = (W E + W M ) × Hz
Reziproke principle use :
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=6342746B1&KC=B1&FT=D&ND=3&date=20020129&DB=EPODOC&locale=en_EP
Original document description ,page 6 line 48-line 55
It is therefore seen that dividing the same amount of magnetic flux along two flux paths rather than along one flux path reduces the magnetic holding or coupling force on an armature by one-fourth rather than one-half as might have been expected. This unexpected magnetic holding or coupling force differential, resulting from multiple flux paths, can provide advantageous properties in linear, reciprocating, and rotary motion devices.
" ....  as might have been expected. .... " : by texte book lecture,experience,geral knowledge ?
synchro1
We can saw the coils away from the center mass of this Washtub motor and remount the magnets from the rotor to the inside rim of the ring wing.
synchro1
This design model is ideal used by Mr Electron:
