battery or ultra-/super-capacitor or 2-in1 as ultra-battery
Started by lancaIV, March 12, 2021, 05:17:08 PM
The storage dis-/ad-vantages and their use :
mass,force,energy,work and power  by conditionized time and or velocity and/or area/volume
DC,AC,pulsed(PWM,duty cycle,duty factor )
AC :
power triangle
complex power S
active(real,true) power P   W units
reactive power Q  VAR units
apparent power |S| VA units
power angle
power factor
S= P + jQ
Q = 0 by resistive load
      ≤ 0   capacitive load ( leading power factor )
      ≥ 0     inductive load ( lagging power factor )
How to measure right efficiency and or a " co-efficient of performance",a.analog instrument b.digimeter !?
First :
"Pulse power measurement " by Prof. Kanarev  15 000 W ~ 144 W ~ 1,44 W  by peak-average point of view
                                                       calculatoric and by experiments
15 000 W : Wh compact ?       144 W : Wh compact ?    time factor  1,44 W : Wh compact ? time period factor
                                                       real c.o.p. versus fantom/apparent c.o.p.
https://medium.com/technicity/researchers-develop-a-hybrid-supercapacitor-with-a-large-storage-capacity-7c6d87311f97
https://www.advancedsciencenews.com/researchers-develop-stable-high-energy-density-supercapacitor/
https://onlinelibrary.wiley.com/doi/10.1002/adma.202004560
                  up to     73 Wh/Kg   !
But commercial product storage capacity :
Shenzhen Yijiahong(Easehot) Technology Co Ltd
https://www.alibaba.com/product-detail/New-technology-graphene-supercapacitor-4-2v_1600122209691.html?spm=a2700.7724857.normal_offer.d_image.60147ac8pKphwX
                    Energy density:            75wh/kg
https://patentauction.com/patent.php?nb=13385
2 Practical Demands and Current Situations of Energy Storage Applications
The popularization of large scale energy storage and high power energy storage require energy system have relatively high power density and relatively high energy density, moreover, long life and low cost that are similar with mechanic system are also required.
United States Advanced Battery Consortium USABC and Department of Energy DOE have set up standard demands for hybrid vehicle auxiliary energy system that are working with power over 625W/kg lasting 10 second, with total energy of 7.5Wh/kg.
Large scale energy storage ordinarily requires that the energy storage devices should reach about 4000 times in cyclic life, the cost should be less than 500 USD per kilowatt hours in near future, reach 125-250 per kilowatt hours in far future.
hybrid solution : https://www.navysbir.com/09_1/158.htm
So it will become important to observe the development from this application
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&bcId=2&locale=en_EP&return=true&FT=D&date=20021231&CC=US&NR=6501093B1&KC=B1
citing document  institutions/companies their research results :
https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=6501093B1&KC=B1&FT=D&ND=3&date=20021231&DB=EPODOC&locale=en_EP
f.e. http://capacitorsciences.com/wp-content/uploads/2018/09/CSI-Executive-Summary.pdf
Capacitor Sciences was founded in 2014 and was acquired in 2016 by Blue Solutions, part of the Bollore Group (EPA: Bol). The Company's molecular modeling and experimental results demonstrate the materials-based performance required to produce capacitive energy storage cells with a capacity of greater than 2.5 kWh/kg, ten times the specific energy of commercially available lithium ion batteries. The Company is now scaling up the production of its metadielectric materials for device development and testing. The Company plans to enter pilot production in 2020-2021 and engage in mass-market commercialization through corporate partnerships.
Capacitor Sciences has developed novel dielectric materials for energy storage devices with energy and power densities of more than 10X of lithium ion batteries at a significantly lower price
The Economics ( 2017 !) : Market Leading Price-Performance for All Segments
The available energy storage market forecasts assume high cost per kWh and, consequently, a limited market penetration. According to Bloomberg New Energy Finance, the average price of battery packs for Electric Vehicles (EVs) is now under $200/kWh but still needs to decrease to under $100/kWh to achieve mass-market penetration.
Capacitor Sciences intends to deliver energy storage modules for product integration at $50/kWh for EVs to reach price-performance parity with internal combustion engines and for the price of stationary storage of electricity not to exceed $0.01/kWh per cycle
https://patents.justia.com/assignee/capacitor-sciences-incorporated
https://patents.justia.com/patent/10597407
The energy storage capacity U is determined by the dielectric constant κ, the area A, and the breakdown field Ebd. By appropriate engineering, a capacitor or capacitor bank may be designed to have any desired energy storage capacity U.
By way of example, and not by way of limitation, given the above ranges for the dielectric constant κ, electrode area A, and breakdown field Ebd a capacitor in accordance with aspects of the present disclosure may have an energy storage capacity U ranging from about 500 Joules to about 2×10v16 Joules.
For a dielectric constant κ ranging, e.g., from about 100 to about 1,000,000 and constant breakdown field Ebd between, e.g., about 0.1 and 0.5 V/nm, a capacitor of the type described herein may have a specific energy capacity per unit mass ranging from about 10 W·h/kg up to about 100,000 W·h/kg, though implementations are not so limited.
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.badische-zeitung.de/akku-explodiert-in-wohnhaus-vier-menschen-verletzt--201342176.html
high capacity energy storage dis-/advantages :
remembering the explosion from a Tandy disc-player capacitor explosion during experiments ( 2 x 1 x 1 cm)
and calculating with 0,02 Wh energy storage, a comparison with 1000 Wh-100 000 Wh/Kg capacitorsciences prediction ......
:o  great ( unfriendly) bumbs-potential
Quote from: lancaIV on March 15, 2021, 04:05:00 PM
https://translate.google.com/translate?sl=de&tl=en&u=https://www.faz.net/aktuell/wirtschaft/vw-baut-netz-eigener-batteriezellwerke-in-europa-auf-17245765.html
"We are reducing the cost and complexity of the battery and at the same time increasing its range and performance," said Thomas Schmall, Volkswagen's Chief Technology Officer and responsible for battery production. The new standard battery, which will be installed across all brands in up to 80 percent of all electric cars the group by 2030, will reduce costs by up to 50 percent, according to the company. "On average, we will reduce the costs for battery systems to well below 100 euros per kilowatt hour." This will make electric mobility affordable.
Battery system = battery + charger + controler
battery charge cycle number ?
f.e. 800 - 1000 charge cycles
https://www.linkedin.com/pulse/discussion-quantumscapes-battery-technology-results-tim-holme
https://www.wired.com/story/quantumscape-solid-state-battery/#:~:text=According%20to%20QuantumScape's%20data%2C%20its,which%20is%20nearly%20double%20the
https://www.shanghai-electric.com/group_en/c/2019-07-31/554147.shtml
Long life cycle, batteries still remain 80% of total charge and discharge capacity after 5,000 cycles usage
One partnership (beside other : SKI, LG Chem und CATL,Guoxuan ,QuantumScape) : https://northvolt.com/solutions/#battery-systems
Probably "Quantumscape" like EEstor "history" : https://www.wiwo.de/my/technologie/mobilitaet/elektroautos-quantumscape-ist-vw-chef-diess-auf-einen-bluff-hereingefallen/27108504.html
https://en.wikipedia.org/wiki/EEStor
dieselgate(r) bluffed by battery-gate(r)
