Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 39 Guests are viewing this topic.
AreYouSure?
In another words,
Take the metal sphere, ship,
emit lots of waves inside the ship,
The waves will reflect inside sphere and create standing wave point inside the sphere.
That standing point is gravity source and whole sphere, ship, will try to fall to that point,
making the ship following the gravity point.
In order to move gravity point, and ship, you need 3 emitters, [3d space]
and adding different emitting power to each emitter,
you will move gravity point, standing point, [it is 3d space - point] inside the ship and ship, metal sphere will follow gravity point.
The crew must be in upper section so gravity point is always below them,
and they will always experience gravity under their feat.
Changing the position of gravity point with the 3 emitters, for even little and with that magnitude,
will affect crew and they will be disorientated, bot not physically harmed.
If the ship is sphere like, it will start to spin around,
so it is better to make it saucer like, so it can dissipate the waves in one axis of plane,
and prevent spinning.
The spinning will remain but not that much with saucer shape ship.
More and more people are starting to think and see those simple facts, ignored before.
Gravity is consequence of waves and frequency and is not fundamental force.
AreYouSure?
There is no antigravity,
gravity is consequence of waves and frequency and
has no opposite force.
Every gravity ship is creating its own gravity pool,
and because gravity pool is local and small in diameter,
it affect only ship and small area around ship which we see as glow around gravity ships.
Every gravity ship dissipate waves, under high density,
creating the light waves which we see as glow around,
in space and in atmosphere, the same glow effect.
The ship is emitting huge amount of waves inside the ship,
and some of the waves escape, emitting through the metal hull,
outside.
The gravity drive is depending on the reflection of waves inside the ship,
in order to create standing wave point inside the center of the ship.
Manipulating the center of standing wave point inside ship,
ship can be propelled towards the standing point, gravity point.
AreYouSure?
The waves itself are small and affects particles,
so the human body does not feel anything.
Particles does.
Smaller the waves, greater the power must be to produce effect.
If the waves are bigger it will tear apart any matter inside, including the crew.
And the project based on the simple bowl experiment was success.
It works just like that.
AreYouSure?
The only problem needed to be solved is to create oscillator, transistor,
of huge power which can oscillate, emit, on electron frequency or
at least close to it!
So there are little or none of those who can produce it tomorrow.
Experiments can be done and effect will emerge, as it was done,
but not even close to commercial transport which can transport living beings.
Except maybe military or other institutions with unlimited resources.
The military probably already solved this obstacle and travel around solar system as we speak.
So knowing the principle does not help to produce commercial vehicle, today!
