Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
kolbacict
You upset me ... All money, money.   It turns out that without financing a perpetual motion machine  can't build ? It turns out that hicks,beggar,голодранцев like me have no chance?  :'(
Needless to try?  :(
stivep
Quote from: kolbacict on May 13, 2021, 03:00:01 AM
Absolutely not true.
1. You perfectly understand English.
2. you perfectly  manage Russian.
3. you are bright active  and  learning.
4.  no money is needed  to wind Tesla coil.
5. don't look to build perpetual motion machine  as it gives you no gain.
   It is like spending 1 dollar to get 1 dollar back.
6. The only option is to do what Kapanadze did.  He received energy in form of surface wave  and converted it to
   energy he could use and present to the public- the electrical form of energy measured in  Power/h = voltage x current  in Delta T( the time frame )
7.  the cost of making it, is for Russians is close to  0 as they   can always get wire, and Plastic  tubing for  former of coil.( каркас катушки)
8. The top capacitor can be made from  any aluminum  tubing (e.g for cooling systems)
9. Mast https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/dlattach/attach/179153/image//
   ( the pipe allowing  top capacitor to be  adjustably elevated can be  telescopic  mast  from old russian   R-118, R-137 or R-140 )
    However that pipe doesn't have to exist at all.
     https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg552209/#msg552209
    all you need is to be able to  move it up  or down in line with coil vertical orientation.
summary :
It is not important Dear kolbacict to have any equipment at all.
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/dlattach/attach/176581/image//
here is  everything that is needed to try A to B energy transfer.
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg552083/#msg552083
with all information about coil frequency and  former diameter .
I'm not smart  I'm just  narrowly fallowing certain direction  in  science. :)
I collect  every information  from youtube or internet
Our Ilya is more  interested in  wide area of  physics...   great  but  that is why Russia  is in deep s..t.
Great  physicists  are only good for academy, that pays for  them being there.
Others must be narrow  good  self-persistent, like most of us the Americans.
But everyone can do it ...
-The only difference  is that   some of them need it badly to become independent  wealthy or  business oriented.
I  DON'T NEED all of  it -  AND I  HAVE IT .. so YOU CAN too.
You Can
Yes You Can
(Barack Obama quote )
Wesley
stivep
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg546541/#msg546541
Here is tuning circuit  For transmitter if you want to match impedance of  generator  to the  primary winding of Tesla coil  .
But that applies only if you want to transmit energy from point A to point B in  the distance.
If you intend to match to  surface wave known as Zenneck Wave in the Air earth interface  than you use exactly the same transmatch .
transmatch ( antenna tuner) is - the  impedance matching coil as it is shown  on the picture.
Than by  lowering and elevating of the  Top capacitor  you are tuning to   energy that is in this interface in TM mode.
The receiving will be possible when  Brewster Angle is achieved.
That energy than can be used the same  way as your  electrical energy from the outlet.
In this picture:
You have original schematic of the structure from Dr James Corum  patent .
You see sections of the coils switched by the  switch to  tune it.
Any big device is bit only because  kW's or MW's of power are intended to be Transmitted or Received.
So the device  can be small.
It is  first required  from  the experimenter to  learn how to  send energy from  point A to point B over the distance not less than 21m
However frequency  is important
So  the best frequency to try is  52MHz, or 1.8MHz assigned  for free use  by anyone  who is Ham.
________________________________________________________
However  that would be only the training of your skills.
The fun starts when we going closer to Schumann Resonances  higher harmonics.
Presently the Viziv tower in Milford Texas operates on 20kHz and implementing  18kHz
The lower you go the better chances to get more of the power  from the interface.
As i said, this energy exists in the interface  in TM mode . transverse magnetic mode.
https://www.testandmeasurementtips.com/basics-of-tem-te-and-tm-propagation/
However we need to  understand that interface differs  from  traditional waveguide
We are dealing  with  2D  (Two dimensional ) interface air/earth.
the behavior  wave in this  interface differs from  behavior  of  electromagnetic wave in Free Space
http://physics.sfsu.edu/~lea/courses/grad/waveguid.pdf
mainly because inverse square law works little different   in the interface .
Suffice it to say  all of that complicated to many  physics  in reality  turns to be just
explanation to very simple Tesla coil  made for few dollars by uneducated  experimenter.
that is why Kapanadze was able to  make it work.
However  Kapanadze device  is much more advanced than   tower of Dr Corum   and my own mini-tower.
Wesley
stivep
This is continuation from :
https://overunity.com/18815/has-anyone-here-constructed-an-overunity-system-that-works/msg557628/#msg557628
So go there to see my first post  from today.
Behavior of electromagnetic wave in free space :
https://byjus.com/physics
-this link may be  not available  for EU zone so switch your VPN to  USA or Canada.
the next interesting subject  is to notice that
Once you push  transmit on your walkie-talkie,and than switch it  OFF, the electromagnetic wave will travel
in free space  to the infinity,  for billions of years (if not dissipates first)
That is why our Deep Space  Devices are able to send to us  information being outside of our solar system now.
Some may  ask what about inverse square law?
Answer: It applies in traditional way.
https://en.wikipedia.org/wiki/Inverse-square_law
Behavior of electromagnetic wave in waveguide or in the interface :
When TX- transmitter is ON  the energy goes into the interface or waveguide and travels in within its boundary.
When transmitter is OFF than there is no energy transmitted nor  present in waveguide or interface
So how can  my device work  if there is no transmitter present  and I'm using  interface .
The space between  ionosphere and earth  is called the waveguide.
ionosphere   earth waveguide
Energy in form of electromagnetic wave is constantly present  there  at frequencies of Schumann resonance
https://en.wikipedia.org/wiki/Schumann_resonances
Lightning is seen as major  contributor for this energy.
Wesley
stivep
continuation from previous  post :
Air/Earth  space has spherical structure with earth  sphere  being inside of ionosphere
- that structure is a spherical  waveguide with two boundaries  earth and ionosphere.
however  it behaves  in similar  to circular wave guide manner.
So we may say that we have random phenomena  causing   randomly distributed energy in the  earth  Ionosphere  waveguide.
However interesting is that  single  lightning is causing  avalanche of lightnings around the  earth.
the second picture is not exactly related to  text from this post but  gives you some representation of phenomena in  question
the link from below is  explaining you  more :
https://en.wikipedia.org/wiki/Earth%E2%80%93ionosphere_waveguide#:~:text=The%20Earth%E2%80%93ionosphere%20
waveguide%20refers%20to%20the%20phenomenon%20in,the%20resulting%20cavity%20behaves%20as%20a%20large%
20waveguide.
Wesley
