Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 35 Guests are viewing this topic.
stivep
some of you have problem with properly   posting on this forum.Here is first instruction.
PLACING THE NEXT LINE OF TEXT DIRECTLY BELOW the first one :
in the picture  below there  is an instruction how to  place comment where  every line is directly below the previous one.
It allows you also to make length of the line of text  short.
example:
if you wrote 3 words and you want to advance to the next line below:
press and hold SHIFT button on the Keyboard and  press ENTER.
Your cursor will be advanced to the  line below.
Wesley
stivep
FORMATTING THE TEXT
If you COPY  PASTE  the text you need to format it  so no additional  characters of HTML will  show after you  finished posting.
By holding left button of your mouse  and sliding it over the chosen text
-you need tho highlight that part of text
And that press  the button remove formatting
Wesley
stivep
some of you have problem with properly   posting on this forum.Here is instruction.
How to  make QUOTED TEXT:
the desired part  of  your text needs to be highlighted
and than you press QUOTE button
after that the text will look like this:
Quotethis is example of quoted text
Wesley
stivep
Some of you have problem with properly   posting on this forum.Here is instruction.
How to QUOTE  text of another  person from the forum.
After you are logged  in to the forum you will see on the  right
upper corner of forum page word Quote.
Click on it and than  the screen changes to the one shown below.
You can  cut some part of text from the quote
You can also  write below the quote your own response.
Wesley
stivep
 If your text  has empty lines  on the top and below and takes to much space
You can:
-place your mouse cursor in front of the line from the left hand side
- click on it to see the cursor is blinking.
- press on the keyboard  backspace button
and you will see that entire text from below   will move  UP
Wesley
