Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 60 Guests are viewing this topic.
stivep
Quote from: AlienGrey on March 31, 2021, 09:14:08 PM
Wesly if there is no such thing as zero point energy, then how or what did you generate in lithuainian experiment
how or where did the energy come from your group generated and how come Badini, Adrian Gustov, Akula and others
were reported as murdered over there inventions, explain that one please  :'( :'(
https://en.wikipedia.org/wiki/Zero-point_energy
zero point energy
__________________________________________________
We generated  subsequently  ~60W than ~300W than ~680W  than ~1kW at output.
I'm not sure if we could call it 1kW/h as we didn't run  it for an hour.
the energy origin was  assigned to NMR phenomena in that special  ferrite Yoke from Russian TV Rubin that was doped with
some isotopes
Another experiment I have made :
1. I Took two  half's of C  shape ferrite.
2. I winded on  first  C  some winding e.g 200 winds at  gauge  20.
3. wind on second C  the same
4. I put the C together creating closed core of rectangular shape with two separate windings . one on the left the other on the right .
5. next step is  to make sure that   both C are  vertical  but could be horizontal too. I  placed them vertical. (one on the left the other on the right .)
6. now I  separated the halves of the  ferrite  so in the middle I have a gap  like 0.7cm at upper  and lower half. ( distance is not critical the smaller the better.
7. I placed two round small flat discs of magnets at upper gap and at lower gap I might  also  use electrical tape or little  glue but  magnets must  contact the flat  square cross section of  each ferrite.
8. I placed  in both gaps in the middle  the small isotope   from  smoke detectors the  bigger  the better.
9.  I played  with polarity of magnets and distance between halves ( the smaller gap the better.)
10. small  LED can be  connected to one of windings  but   I used 10W tungsten Light bulb.
11.than I tried   to  short and open  one winding
while that  winding  is interrupted  the lightbulb connected  to another winding  will light up.
___________________________________________________
the configuration  from above will work  as well with just  one single winding  on just one C  shape half of the ferrite core.
while the second halve C shape of ferrite has no winding at all.
In this configuration I achieved steady  glow of 10W tungsten lamp.
But  I  used slightly  bigger and different isotope.
Note: If there is only one winding than there is nothing to short.
So it must be some variables for it to work..
Yes..
bombardment..
the delta T between  each  particle  ...
________________________________________________________
Another better   way is to play with beryllium  window
read what happens when alpha particle hits  beryllium plate .
https://www.scienceforums.net/topic/6237-beryllium-9-gets-hit-by-alpha/
This  thing  makes huge difference in power out. Yes..  I mean huge...
and word huge is even to small here.
SO NOW THINK.. think my friends.....
THAT THIS FERRITE FROM Russian TV Rubin HAD BERYLLIUM DOPING.....in it..but  even worse than that .. it had something else..
And that was a reason we stopped to  play with it..
But Arunas still  doesn't know why I  gave up on it.
Don't ask me more about it  I already  said to much..
This   is not  for general public  although  license  is not required for old type of  Americium  sources from old smoke detectors.
Wesley
PS: I explained Lithuania experiment many times..
The variables were given by two 1W generators.. for more information go to  T 1000 Arunas.
He is mastermind in it.. and he is on this forum.
Legal note:
I don't  recommend   to any one to use it or play with it .
I kept my post in   language that is  using words : I do,
I try, I make..
avoiding any direct form of  me suggesting  to anyone to play with it.
AlienGrey,'free energy' has nothing to do with monetary meanings !
Free energie is - in nano time units - shortly ' unbonded' energy !
From second unit view relatively fast recombination= re-bonding !
Cause this future converter works in THz level and beyond !
Free energy can be also the result from natural/enforced elementar decay !
Nuclear energy ! And in electricity/electron-gas/ion-gas/plasma is nuclear actio/reactio inside !
Sincere
OCWL
stivep
how or what did you generate in lithuainian experiment ?
how or where did the energy come from your group ?
zero point energy
some isotopes
to understand this you need to read carefully that:
https://overunity.com/18815/has-anyone-here-constructed-an-overunity-system-that-works/msg556423/#msg556423
( my post from above)
_____________________________________________________________________________________________
//....were reported as murdered over there inventions, explain that one please//  :'( :'(
As far as  murders and Putin   in this case...
Every country has enough money to test crazy ideas.
Every country has its own patent office
Every country  government  is a power of its own  on their own territory.
Most of them already have tested  some forms of FE
the Lithuania Experiment , 1kW   Out      https://youtu.be/gKkcdfSdt5Q?t=1061
the Harold COLMAN & Ronald GILLESPIE  1kW out    Power Generator http://rexresearch.com/colman/colman.htm
the  Hendershot  device .. few hundreds  W.
all of the concepts can  be look at its similarities.
-the  set of the same mechanisms is taking place there
despite  what isotope did you use  against  Beryllium window or doping or  ....
https://youtu.be/0xXZT7YQDE8?t=512
Governments don't need you to interfere  so  at first you are donor of information and experience
and the next thing is to make you silent.
Unless  "they" are to late ...
or        "they"   can't touch you as  than  information  will be released  to general public.
Wesley
partzman
If I may, I'll share a true story about a conversation I had years ago with one Bill Wampler.  Bill has now passed on but his work continues as far as I know.  I became aware of Bill thru a family relative who knew I was working on such devices but she would not even give me a number to call but rather told me that Bill would contact me if he so desired.  Two weeks or so passed and I did receive a call from Bill and we talked for over an hour about his work.
Bill made millions manufacturing desalination equipment that he supplied worldwide.  He re-invested into a small discrete and very private and secure R&D firm to research FE.  Long story short, they developed and manufactured a ~10kW black box that they gave away to poor 3rd world countries that needed electricity to purify water, etc.  I quizzed him why he didn't market the product commercially and he said the governments wouldn't allow that to happen.  During their development stages, they were raided by the ATF (because one of his employees told a friend about their work) and they confiscated all documentation and prototypes.  They fortunately kept redundant records and materials so were able to continue on after relocation.
I of course questioned him on the theory of operation and all he would give for details was the fact that it was solid state with no moving parts and needed a battery to start.  Once running, it was a stand alone generator.
I will never forget what he told me about the basics however.  He stated that energy was all around us all the time and the first problem was to figure out how to collect or cohere it!  The second problem was to figure out how to control it.  He said the second problem was the most difficult for them to solve!
Now I'm not sure Wesley, but this sure sounds like energy extraction from the aether to me!
I would also like to ask a question of anybody here,  when I energize an inductor with di/dt, exactly what is happening?  I mean, what is induction or inductance?  Hint-what is 'S' flow?
Regards,
Pm
partzman
I would also like to share a concept that would be the basis for a FE device in the attached pdf.
Regards,
Pm
