Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
DO DEFINE NUMBERS RIGHT IF FARLY DIFFICULT :
https://medium.com/predict/how-far-are-we-from-wireless-electricity-94dbd48529a4
According to Global Energy Statistics, the world's total energy consumption in 2019 was 13000 Million Ton Oil Equivalent(MTOE).
This translates to 17.3 Terawatts of power.
( clearing :
  But this statistical number is the total primary energy global consume 2019 ,also written as 583,9 Exajoule )
http://www.kylesconverter.com/energy,-work,-and-heat/tons-of-oil-equivalent-to-terawatt-hours
13 000 Million Ton Oil Equivalent =     13 000 000 000 tons oil equivalent            = 151 190 TWh
This 151 190 TWh dividing 8766 hours  gives/"translates" as worlds power/energy consume       17,25 TW ( per hour )
desert and/or space solar farming :
1. Remote Transmission of Solar EnergyAccording to Global Energy Statistics, the world's total energy consumption in 2019 was 13000 Million Ton Oil Equivalent(MTOE).
Now, if we cover an area of land equal to 350km by 350km with solar panels, it can provide more than 17.4TW of power.
               condition : during sufficient radiation and/or sufficient energy/power storage
This area is about 43000 Square miles. The Great Sahara Desert is about a 3.6million square miles of more than 12 hours of solar power per day.
related 43 000 Square miles = 122 500 Square Kilometers    another number offered (output per hour ?)
https://energypost.eu/10000-sq-km-of-solar-in-the-sahara-could-provide-all-the-worlds-energy-needs/
This means 1.2% of the desert is enough to cover the world's energy needs. And there is no way nuclear fusion or any other cleaner source of energy currently under development can compete with this.
Quote from: alan on May 25, 2021, 11:56:18 AM
Your best bet is the udt of Raymond Paul Jensen and the flux diode to give Lenz a different path and more room, aka asymmetric flux linking. He gave it away but people apparently don't want to find.And this https://patents.google.com/patent/US6707208B2/en
Raymond Paul Jensen The Unidirectional Transformer f.e. here pdf https://www.overunityresearch.com/index.php?topic=3756.0
kolbacict
Isn't Ted Annis's device about that?
p.s.  To Wesley.
В России сейчас многие думают, что их страна "пляшет под дудку" исполняет волю международного валютного фонда,и их главного оплота,США.
Что бы вы могли ответить этим людям ?  ;)
p.s.I'll add that I don't think so. :)
#276 : "..... the efficiency of transmission can be as high ...."
from power source to emission wave spectrum : efficiency ?
https://en.wikipedia.org/wiki/Project_Sanguine
Radio waves in the extremely low frequency (ELF) band of 30 to 300 Hz can penetrate to a depth of hundreds of meters, allowing them to communicate with submarines at their normal operating depth.[5]
The lower the frequency, the longer the wavelength of the radio waves, and transmitters require longer antenna structures to generate them.
ELF transmitters use huge antennas called ground dipoles consisting of tens to hundreds of kilometers of overhead cables resembling ordinary power transmission lines.
The transmission lines are grounded at the ends, and looping currents deep in the Earth form part of the antenna.
Because even these huge antennas are much smaller than the ELF wavelengths, they are extremely inefficient;
only a tiny fraction of the input power is radiated as ELF waves, with the rest dissipated as heat in antenna resistance.
At their full input power of 2.6 MW, both US ELF transmitters working together only generated about 8 watts of ELF radiation.
This weak signal was able to reach submarines over half the globe only because of the extremely low attenuation of ELF waves of 1–2 dB per 1000 kilometers.
ELF transmitters are most efficient when sited over certain low conductivity underground rock formations, which forces the currents to spread deeper through a larger volume of rock, forming a larger "antenna".[2]
The US system was located in Wisconsin and the Upper Peninsula of Michigan over the Laurentian Shield formation, for that reason.[2]
https://en.wikipedia.org/wiki/Ground_dipole
Antennas at ELF frequencies
Fortunately, the attenuation of ELF waves with distance is so low (1–2 dB per 1000 km)[5] that a few watts of radiated power is enough to communicate worldwide.[2]
:P  TWh now to see as TinyWatthour :'(  consume ,up to P(itty)Watthour ::)
I hope this here written falls under commentator "personal irony" :
https://electronics.stackexchange.com/questions/459585/tesla-coil-and-tesla-tower
So, in order to prove Tesla's claims, and operate even a tiny 1-watt flashlight bulb at hundreds/thousands KM distance, we'd need:
17KHz operating frequency (or ideally far lower.)
50MV terminal potential (or ideally far higher.)
Extensive grounding system (like BBC and VOA European megawatt towers.)
100MW power supply (or ideally far more.)method to follow the changing planetary VLF resonance modes
Wesley, from #281 and #285
122 500 sqkm to 10 000 sqkm need and improvement  this I  call : technological success !
such statements like :
has nothing to do with "efficiency" : THIS IS A WASTE OF ENERGY SYSTEM ! ( the military sector is not reknown for ecologic behaviour !)
                                                      2 600 000 Watt-in  for 8 Watt-out
                   ( american  8)  business inside ? horrible MBA-/PhD management knowledge disorder)
It should be in Your interest not only to observe the pure "transmission efficiency" but also the power-source-to-emitter efficiency !
Let us hope for the Viziv and other competitors not same bad in the ELF/Zenneck-TM level !
And to use "clean" solar energy as 2,6 MW input power source does not hide the horrible inefficiency !
simple wireless energy transmission ( over all em frequencies spectrum ) we know and use privately since more than 40 years :
IR Fernbedienung/remote control for HiFi/TV     or     70´  walkie-talkie and in kitchen : micro-wave owen
                                           Gimme/Give me  an 8 Watt-in and 2,6 MW-out idea/concept solution,politely: :-*  please  !
                                           From my knowledge-status quo possible : but only as cascading  array !
next technical evolution barrier fallen  ;D :
https://www.globenewswire.com/news-release/2021/05/24/2234708/0/en/US-Nuclear-and-Grapheton-s-New-Supercapacitors-Could-Charge-Your-Next-Electric-Vehicle-in-Seconds.html
wireless energy transmisssion : I reed ,3 decades back,about it : "Wirtschaftswoche"-Magazin
                                              magnetic induction (like today electric cars loading :
                                              wireless) Kir(chen)mes(se = Jahrmarkt) Versorgung/Distribution
let us look for - less distance- tower  improvements, less solar radiation peak dependent  :
17,4 TeraWatt / 500 KW https://web.archive.org/web/20110817174850if_/http://www.airpower.co.il/PRODUCTS.htm          x 40 sqm =
17 400 000 MW      / 0,5 MW =  34 800 000 units        x 40 sqm =
                                1 392 000 000 sqm = 139 200 ha = 1392  sqKm  area ( on water-pontoon,land ) need by
                                 compared
                       https://www.indexmundi.com/world/area.html
                     world total:  510.072 million sq km
                              land:     148.94 million sq km
                            water:     361.132 million sq km
                                                power (plants) to the people
                        less than 122 500 sqKm(350 x 350) and 10 000 sqKm ( 100 x 100 )
                        space solar,earth solar,wind,water,magnetic forces : being and staying flexible !
                     We can also divide this 17,4 TW by  world-wide (private) households number
                                 ( future : 2,5 Giga a 4 capita = 10 Billions or 10 Giga habitants)
        ! average !
                 7000 Watt or 7 KW  primary energy as electric energy per household
                                       this is the E.U. programmatic demand : in-situ generation ! in-place !
                                      Let US see it as GLOBAL ENGINEERING PROGRAM ! NO EXIT !
magnetic induction,nice written description and explained -near distance- as vid :
https://phys.libretexts.org/Courses/University_of_California_Davis/UCD%3A_Physics_7C_-_General_Physics/10%3A_Electromagnetism/10.3%3A_Magnetic_Fields/4._Magnetic_Induction
how to transmitt wireless https://www.youtube.com/watch?v=sMfAotrPEkI
transmission by Tesla coil arrangement   https://www.youtube.com/watch?v=w2bZGKNwB4Y
