Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 59 Guests are viewing this topic.
seychelles
NOT TRUE KOLBA. WATCH MY COUSIN'S VIDEO. THIS PROCESS CAN LIFT THE WATER UP
TO 33 FEET DUE TO THE WEIGHT OF WATER IN CONJUNCTION WITH GRAVITY.
VERY INTERESTING READING IN LATERAL IMAGINEERING. ALL THANKS TO LANCA.
http://www.rexresearch.com/bellocq/bellocq.htm
Thinking based Newton/Coloumb  or non-newtonian/coloumbian ? Not laws,AXIOMS ! Where begins the overbridging : in-/outer field !?
https://worldwide.espacenet.com/searchResults?AB=&AP=&CPC=H02K53%2F00&DB=EPODOC&IC=&IN=&PA=&PD=&PN=BE&PR=&ST=advanced&Submit=Search&TI=&bcId=1&locale=en_EP&page=2&return=true
        Comprire Francais ? GoTo "original document"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=50&ND=3&adjacent=true&locale=en_EP&FT=D&date=&CC=BE&NR=485056A&KC=A
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=BE&NR=485056A&KC=A&FT=D&ND=3&DB=EPODOC&locale=en_EP
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=BE&NR=438189A&KC=A&FT=D&ND=3&DB=EPODOC&locale=en_EP
Exemplar motor/generator ratio and  Je dois aussi attirer votre attention sur la façon que l'accumulateur est raccordé.
                                 vacuum https://en.wikipedia.org/wiki/Vacuum
                                 suction            https://en.wikipedia.org/wiki/Suction#:~:text=Suction%20is%20the%20force%20that,results%20in%20a%20pressure%20differential.
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=114&ND=3&adjacent=true&locale=en_EP&FT=D&date=19800531&CC=JP&NR=S5572694A&KC=A
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=138&ND=3&adjacent=true&locale=en_EP&FT=D&date=19911126&CC=JP&NR=H03265750A&KC=A
                                            vacuum cleaner device to vacuum chamber
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19991224&CC=JP&NR=H11356033A&KC=A
A small power prime mover and a large power generator are connected and installed in an air chamber to produce large practical electricity with a small power source.
When looking at the relationship between the power of a small motor (model motor) in a vacuum chamber and the power required to operate a practical 100V output generator, the relation between the two in the atmosphere is completely different.
Generate interlocking force relationships.
This relational system in the vacuum chamber can obtain 100 outputs in the relative force relational system by applying a force of 1.
In other words, the small force required to rotate the driving force can be converted into an infinitely large practical output.
It is a device that puts a small amount of electricity into a vacuum chamber and takes out a large amount of electricity to the outside of the room.
This requires theoretical investigation, but it seems that this utilization can pursue great value to save the national crisis.
              application 1998 filled
The realization of this utilization can bring out the effect of performance by installing centrifugal force, which is thought to generate the effect of the Industrial Revolution, and increasing the density of vacuum.
motor and/or generator different coils configuration  results : https://www.youtube.com/watch?v=t6bEjdH9ATw
        https://www.youtube.com/watch?v=5B58pEh8F3E
for one improvement trials :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=wolfgang+hagedorn&IN=&CPC=&IC=&Submit=Search
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3804440&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
The invention is based on the object of precisely localizing the permanent magnetic electron potentials, defining them in their proper range and their polarity, and bringing the electrons present to full use and thus improving the efficiency.
The advantages that can be achieved with the invention result directly from the double to eightfold improved efficiency, a specifically lower cost and material expenditure, a lower drive power and reduced dimensions.
Additional advantages can be seen from the applicability of commercially available coil windings, since specially shaped rotor or stator windings are not required.
Compared this coil arrangement :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20010710&CC=US&NR=6259347B1&KC=B1
This invention allows for the reduction in size of a high power transformers by a factor of 4 to 8 and a reduction in weight by a factor of 4 to 6, and an increase in power density by 5 to 10 in power. The efficiency of the transformer is improved by maximizing the heat transfer from the transformers interior and minimizing voltage breakdown.
https://www.youtube.com/watch?v=AoMJS9Kq4IY
https://youtu.be/AoMJS9Kq4IY?t=38
" Energy is related to voltage squared "
10 Volts gain is 100 times energy gain !
   From which Volt-base ?
kolbacict
QuoteNOT TRUE KOLBA. WATCH MY COUSIN'S VIDEO. THIS PROCESS CAN LIFT THE WATER UP
Here they told me that it is possible for the water to flow upwards.Due to the difference between day and night temperatures. Some of the air in the vessel will expand and contract. But it will be just a little water.
