Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
ramset
Russ
This one should be doable?( easily tested)
However water thermolysis is above 1500 F
Actually over 2000C
1950 Military motor pool soldiers converted used oil furnace to run on water. Fire pot at 1500 degrees then allows super-heated steam from SS tubing heat exchanger to add to 90lb oil flow to tiny pin point oil nozzle.
When steam exits from 90lb high pressure to ambient zero pressure in fire pot the hydrogen and oxygen torch flame keeps heating. ""Oil valve shut off."
If water line shut down, furnace has to be restarted on oil. Much smaller  version in crate was shown to Washington senator in underground parking lot. US patent application was refused. Why can't anything be purchased.
End quote
BTW
I noticed Tommy Reed offered on some replication(s)
Me too ..
Respectfully
Chet K
Thanks Grandma
Cloxxki
1500 ºC? Then you get water splitting, right? Or ºF for pure steam?
What is the priciple that would keep it burning?
ramset
1500 F is really hot for steam
Would be interesting to direct that into a hot flame ( what happens?)
2000C is where Water disassociates into H and O molecular..
I attach a small comment below from Tom Bearden info
Lithium is said to change temperature of thermal disassociation ( thermolysis of water into H and O)
I had heard it cuts it in half ( Sam Leach water engine claims below)
Would be interesting to try a bit of lithium Nitrate ( 20 ppm)
See if water furnace gets a benefit?
Still trying to find a path towards a lithium Nitrate sample for test
Apparently it's a bit controlled ..( regulated?)
We had member who recommended just Lithium from dish soap ( one teaspoon per liter)
Would work .
Lanca
You a chemist ?
Upcycle lithium ion batteries into lithium Nitrate samples?
World will surely need lithium battery recycling markets ...
Ask some friends for help ?
Water as fuel ... Blasphemy to some ...
Watch the rockets fly with one extra oxygen H2O -H3O
Respectfully
Chet K
Thanks Grandma
Hello Chet,no,I am not chemists !
And : in R&D the most energy storage orientation is ' beyond : Lithium' !
Aluminium,Graphit/Graphene and Natrium-/Sodium ( battery,hibrid) :
https://www.google.com/search?q=BYD+sodium+battery&ie=utf-8&oe=utf-8&client=firefox-b-m
I think that by simple questions Assistant Professor/Docent (biocell and alu-battery,beside ' round-up'- pendant from Hoechst)
https://novaresearch.unl.pt/en/persons/pedro-manuel-brito-da-silva-correia
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Pedro+Brito+Correia&CPC=&IC=&Submit=Search
can give helpfull answer !
wmbr
OCWL
p.s.:
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1#
and instead 4x motors coupling 4x rotoverter
~ 1 Kg CATL 160 Wh/Kg for 40 Km drive range
with bosnian Professor concept including
    https://www.patentauction.com/patent.php?nb=15379   100 Km per Kg !?
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Andreja+Todorovic&CPC=&IC=
Robert Yost wind generator on tect car idea application including ?
But we know,R&D SciFi is everywhere ,up to 15 000 Wh/Kg :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021231&CC=US&NR=6501093B1&KC=B1#
From Alvin Marks theoretical number ? much reached by them 2023 ,citing documents :
https://worldwide.espacenet.com/publicationDetails/citingDocuments?CC=US&NR=6501093B1&KC=B1&FT=D&ND=3&date=20021231&DB=EPODOC&locale=en_EP
F.e.:
https://capacitorsciences.com/
Capacitor Sciences Inc. has a new materials technology able to produce ultra-high energy density devices that can surpass the performance of lithium ion batteries by at least 10x in every metric.
1000 Km per Kg ? Impulse ( and feedback cycle storage)motor
Porquer/rotoverter as ic gasoline combustion engine car to electric car conversion kit,1/5 the price compared a new electric car buy !
And clearly,1 Kg for the average DAILY 130 Km drive is a theoretical number,mathematical AVERAGED,the battery DoD and Cmax. and motor inrush Wp during start phase,and concentrated/compressed brake energy recuperation ...  and .. as physical barriers !
