Earth Is An Oil-Producing Machine — We're Not Running Out
Started by lancaIV, April 13, 2021, 06:46:09 AM
Source from petroleum/oil : !?
https://www.google.com/search?q=abiotic+oil&rlz=1C1AVFC_enPT930PT930&ei=Onx1YMn1FsqmaM-3kaAJ&oq=abiotic+oil&gs_lcp=Cgdnd3Mtd2l6EAwyAggAMgQIABAeMgQIABAeMgQIABAeMgQIABAeMgQIABAeMgQIABAeMgQIABAeMgQIABAeMgQIABAeOgcIABBHELADOgQIABATOggIABANEB4QEzoKCAAQCBANEB4QEzoECAAQDToGCAAQDRAeOggIABAIEAcQHlCKiAFY0qUBYJu6AWgBcAJ4AIABf4gBkgeSAQM0LjWYAQCgAQGqAQdnd3Mtd2l6yAEIwAEB&sclient=gws-wiz&ved=0ahUKEwjJ-sb2ivvvAhVKExoKHc9bBJQQ4dUDCA0
synthetic fuel/gas cycle
on-board or  fixed water-gas production
https://peswiki.com/directory:gun-engine
http://www.gun-engine.pl/en/index.html Water is injected 8 parts per one part fuel, along with the fuel.
https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2013095190  f.e. ratio 8:1
1. ​Field of the invention
​The invention relates to power-saving technologies, in general, to methods and plants for converting Water h20 into a hydrogen-containing gas in a combination of a catalyst medium from A series of sph2p +2 (diesel fuel, fuel oil) in a non-pre-explosive thermal flame environment at A Combustion temperature of over 500 c these methods generally relate to systems in which the production of gaseous fuel and its realization by combustion are combined into a single cycle, but may be used for storing hydrogen-containing gaseous fuel.
The method and the device implement the dependence of H20 + Sph2p +2 = h2 + c02 in a high-temperature multi-stage mode. The thermal capacity of carbon is best addressed by the water gas. The steam generation of carbon dioxide requires 8% of its own resources, the water gas consisting essentially of CO (40-60%) and H2 (30-50%).
So much less,-90% by fuel carbon content ,CO2 is produced and exhausted !
On-engine CO2-ion generator as CO2 neutralizer possible !
CO2 as carbon capture and recycling !
"Global Warming" since the 80´ :
https://www.umweltbundesamt.de/sites/default/files/styles/800w400h/public/medien/384/bilder/de_indikator_klim-02_globale-lufttemperatur_2021-02-03.png?itok=OOH9pcJW
in the End-80´ the meteorological measurement process changed from analog thermometer to electrical/digital  thermometer measurement : technical up to 2° Kelvin difference  !
                                   Scientifical  comparation not possible !
https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/Lufttemperatur
https://translate.google.com/translate?sl=de&tl=en&u=https://www.klimaphalt.de/klima-1x1.html
CO² is the main cause of global warming?
Global warming through carbon dioxide. Focus wrote about this on 02/27/2015 and took nature as the source:
https://www.focus.de/wissen/klima/klimaschutz/endet-bewiesen-forscher-messen-treibhauseffekt-durch-co2_id_4507677.html
... First measurement outside the laboratory
Scientists working with Daniel Feldman from the Lawrence Berkeley National Laboratory (US state California) emphasize that this effect has never been measured outside the laboratory. They followed the development at two stations in Oklahoma and in northern Alaska.
From 2000 to the end of 2011, these recorded the spectrum of long-wave infrared radiation and also the frequencies for various gases such as CO2, water vapor (H2O), ozone (O3) and methane (CH4). They also took into account other influences such as temperature.
Forecasts confirmed
Both series of measurements consistently showed that CO2 in the atmosphere increasingly emitted infrared energy - on average, the energy increased by 0.2 watts per square meter per decade with a clear sky. This confirms the previous forecasts.
0.2 watt / m²? Really not a misprint?
On a normal summer day the sun shines with 750 watts / m². This heat flow density can rise to 1,000 watts / m².
https://www.weltderphysik.de/gebiet/technik/energie/solarenergie/sonnenenergie/
Now is the temperature of the earth supposed to rise because this heat flow density increases by 0.2 watt / m²?
We believe the effect of urban heat islands along with thermal pollution are the bigger problems to be solved.
Unfortunately we have not yet found the scientific article in "Nature" - but stay tuned.
                    searched article,probably  ::)  :                  https://www.nature.com/articles/nature14240
alan
Alonghairwolf
I wanted to add my two cents as well. It's known by that space has a lot of hydrocarbons as well. Just floating around in huge clouds. It would make sense that planets or other celestial bodies make hydrocarbons / oil.
onepower
Cultures which utilize fossil fuels relying on a hunter-gatherer mentality will always be considered primitive. They will always be hunting for ever depleting resources to gather up and burn.
Do you still go foraging in the forests for food?, well no because it's inefficient, time consuming and primitive just like fossil fuels. Modern man farms food and efficiently produces it where needed. We can also grow our own food in a greenhouse, garden or hydroponics and there is no need to hunt and gather.
Modern man does not use a hunter-gatherer mentality.
Modern man uses energy conversion from clean, renewable resources like solar or free energy. We do not hunt and gather energy like savages the energy comes to us where it is converted, stored and utilized.
There is simply no getting around the fact that hunting for, gathering up and burning fossil fuels for energy will always be considered an inferior method utilized by primitive people who don't know any better. There is nothing modern, responsible or intelligent about it... we can do better.
AC
