about momentum converter
Started by lancaIV, April 16, 2021, 08:52:37 AM
http://www.overunity-theory.de/Buch_gedruckt_korrigiert.pdf  W(olf) D(ieter/ietrich) Bauer
http://overunity-theory.de/
http://www.overunity-theory.de/rotator/Imris.pdf
The important point is that Imris did not notice that the Lagrangian momentum (which can contain constraints inserted) does not coincide always with the common definition of angular momentum as learned in school.
Clearly that Dr.Pavel Imris,CSc. ,
CSc. - Candidate of the Sciences (candidatus scientiarum) DrSc. - Doctor of Science (doctor scientiarum) (the titles CSc. And DrSc. Have not been awarded since July 1, 1998)
use more than only school book knowledge,an assumption !
http://www.overunity-theory.de/rotator/rotatornew.pdf
2. Experimental setup Wuerth's experiments originate from Stein's rotor setup [2] which has been published to a bigger audience by the journalist G. Hielscher [3].
https://www.yumpu.com/de/document/view/20184764/otto-stein-die-zukunft-der-technik-pdf
pro/contra theory development/results dispute https://www2.mathematik.tu-darmstadt.de/~bruhn/OverUnity.html
What you don't touch, for you lies miles away;
What you don't grasp, is wholly lost to you;
What you don't reckon, you believe not true;
What you don't weigh, that has for you no weight;
What you don't coin, you're sure is counterfeit.
( Faust, part II, act 1, by J. W. von Goethe, 1808, from the translation of George Madison Priest)
Earnest, these words are spoken by Mephistopheles
https://www2.mathematik.tu-darmstadt.de/~bruhn/KurzD_Oe_Br.htm
Dass der Wirbelring bei gewissen Bewegungsformen keine Energie verbraucht und infolge dessen sehr lange leben kann,wusste schon Helmholtz (1821-1894).
::)  ingo rechenberg evolutionsstrategie  https://link.springer.com/chapter/10.1007/978-3-662-01104-1_10
Die Evolution hat biologische Prozesse optimiert.
Die Evolution ist selbst ein biologischer Prozeß.
Folglich: Die Evolution muß sich selbst optimiert haben.
:o  " ..... haben ." Ja isse scho abgeschlosse ,die Evolution !?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850314&CC=DE&NR=3330899A1&KC=A1
[0012]
The invention is based on the knowledge that there is an analogy between electrical engineering and fluid mechanics.
[0013]
This consists in the fact that an electromagnetic field around an arbitrarily bent wire-shaped conductor and a flow field around an arbitrarily shaped vortex thread are described by the same law, Biot-Savart's law.
The quantities "increase in magnetic field strength" and "increase in speed" therefore correspond to one another.
Since magnetic field strength can be concentrated by winding a current-carrying conductor into a coil, an increase in speed can also be achieved in fluid technology by winding a vortex thread into a coil.
If you arrange several whibs rotating in the same direction so that their axes lie on a circle, they will rotate around the center of the circle as a result of mutual induction.
The induction increases with the number of vortices. The winding speed increases and the wedged threads approach the shape of closely spaced ring vortices. The velocity field that these ring vortices induce inside them creates the desired concentration effect.
Citation finis
wie wird aus einem "Wirbel-Keim" ein "Wirbel-Faden" daraus eine "Wirbel-Spule" und dann darauf ein "Wirbel-Ring" ?
KAOS-butterfly-theorem  https://en.wikipedia.org/wiki/Butterfly_effect   https://en.wikipedia.org/wiki/Chaos_theory
but : https://de.wikipedia.org/wiki/Galtonbrett    https://www.raspberrypi.org/blog/royal-society-galton-board/     and Pi
"Austrian Society for critical thinking " oder SCHOEPFERISCHE ZERSTOERUNG 2.0,frei nach Schumpeterischer WIENER SCHULE Liberalitaet
Honduras
https://www.youtube.com/watch?v=gx9yiQcGOOU
https://www.youtube.com/watch?v=VWpWcWqwlUY
Peru
https://www.youtube.com/watch?v=s6CEl08XNb8
https://www.youtube.com/watch?v=QgkQ9UVfVCY
https://andina.pe/Ingles/noticia-pioneering-technology-uses-plants-and-microorganisms-to-produce-electricity-in-peru-766265.aspx
Alternative research : https://www.youtube.com/watch?v=dK_Mue3EqCA
                                https://www.youtube.com/watch?v=SFv64v6A1kk
also from Perú we did not hear anymore about  https://www.youtube.com/watch?v=ZGD9stogxbk
        multiplicador de fuerza (torque)
        https://www.youtube.com/watch?v=VXaC3tYCuO0 Sixto Ramos
        Sixto Ramos tipe replication trial  https://www.youtube.com/watch?v=40s_3qWlz68
        comments link : 1. https://www.youtube.com/watch?v=_WPZZkGyM8I  Ucros (Columbia)
        Pakistan
        2. a.  https://www.youtube.com/watch?v=OzOhM4HsIeg&t=550s
        b.  https://www.engrnomanshahafridi.com/p/blog-page_30.html
Columbia : https://www.youtube.com/watch?v=tOSt6GQ9Rw0             Systema Q
                 https://www.youtube.com/watch?v=WkExQ4dA4dA
                 https://www.contextoganadero.com/ganaderia-sostenible/sistema-q-maquina-de-movimiento-perpetuo-hecha-en-colombia
Brazil ( remembers Torbay magnet motor)  https://www.youtube.com/watch?v=s03w_oRXlxQ
                                                              https://www.youtube.com/watch?v=WQcjIxI1wDI&t=0s
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941027&CC=DE&NR=4311631A1&KC=A1
         cw and ccw  coupling ?
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4464095A&KC=A&FT=D&ND=3&date=19840807&DB=EPODOC&locale=en_EPWith such arrangement as described above, the internal gear and the planetary gears can be rotated in opposite directions but at the same rotational speed, so that as compared with the conventional hydraulic turbine in which the internal gear is held stationary the rotational speed of the pinion shaft can be almost doubled. In contrast with the conventional turbine with a single bladed rotor which is rotatable only in one direction, turbine rotors which are rotated in the opposite directions are mounted alternately on the common shaft so that a helical flow of a fluid through them can be eliminated. Consequently highly efficient power conversion can be ensured.
when speed will become doubled = generator production maximized by ....%  ?
similar planetary gear arrangement :https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=22&ND=3&adjacent=true&locale=en_EP&FT=D&date=20020411&CC=DE&NR=19954908A1&KC=A1
efficient electric generator : Akio Hara cw/ccw coupled double rotor
                                         Tudor-Frunzi
                                         Kumar,patentauction.com
                                         Kango Iida
generator coil coating :       Yurth
efficient electric motor :     Catalan
                                       Sankar Pat
                                       Lam Dat coil wiring
                                       Imris cap-wiring
                                       Meta-C 3-phase cap-wiring
                                       Aminzko,patentauction.com
gear-motor :                    Li Yng
                                      Porquer
first application : by given numbers     2-generator a 800 W version
                                                           1600 W out by 1000 W electric (800 W nominal) in
                         first improvement
                      +  Kango Iida generator  2880 W out by  1000 W                                     in
                         second improvement
                     + Kango Iida converter     2880 W out by   500  W                                     in
                      between generator/motor
                     third improvement
                     + Li Yng gear-motor         2880 W  out by    50  W                                     in
                    option :
+ generator coil coating,motor controler,.......
what physical/technical is possible has not to be industrial important,especially if "open source" technology = private ownership-free
The high salary western industry has no chance opposed the low salary countries worldwide ! No margin-reserve in the price !
Open source technology production is only in low salary countries or under " autonomous=humanfree 3d production factory"-condition possible !
