Motor search for lenz less or lenz assisted.
Started by MagnaProp, May 03, 2021, 12:24:02 AM
NdaClouDzzz
Stan Meyer's EPG also addressed the lenz issue. The following link starts at Stan's discussion: https://youtu.be/_-hY09qYfhw?t=1858
        Part Two of EPG discussion: https://youtu.be/-T20Wmjce2E?t=593
MagnaProp
Very interesting. The key appears to happen in your second link at (14:35 - 15:01). I don't understand it though. He has his magnetic gas going around in a tubular non-magnetic coil, and coils are wrapped around that. I don't really understand his explanation of why the EMF is now reduced by going away from the coil in a right angle?
Attached is my drawing of what it sounds like his set up is.
kajunbee
There's something I'm missing here myself. A permanently magnetized gas circulating in a tube. This would be the same as a coil wrapped around a toroidal permanent magnet. And then spinning the toroid inside the coil. Imagine two semi circular permanent magnets connected together with coil wound around them. Spinning the magnet inside the coil will not induce a voltage in coil will it??? My basic understanding is that the magnetic field has to change, expanding outwards/inwards) from the core. As I see it lenz law is defeated because there is no voltage induced in coil. Not much use in that is it. Maybe I'm missing something, I haven't watched all of the video.
NdaClouDzzz
I haven't put any real effort into researching any of Stan's devices, but I have no doubt of the validity of using a high voltage electric field to produce hydrogen, just as Stan clearly pointed out in his house lecture ( https://youtu.be/fxciCZHHAn4?t=1612 ). There are many ways of producing a high voltage electric field, Stan's way is just one way*. With regard to Stan's EPG, there's info everywhere. Here's one link: https://www.nikola-truck.com/epg-electric-particle-generator
See also, Chapter 2 "Gyroscopic Actions" in THE ENERGY MACHINE OF JOSEPH NEWMAN https://archive.org/details/TheEnergyMachineOfJosephNewman8thEdition/page/n11/mode/2up
*For example, see Don Smith's Ambient Energy Generator https://overunity.com/18282/a-king-21-build-discussion-investigation/msg536914/#msg536914 (Reply #57) and EFUSystem PDF https://overunity.com/18239/the-solution/msg552241/#msg552241 (Reply #64)
