Low temperature catalytic thermolysis of water
Started by Sergh, May 12, 2021, 05:03:49 PM
Sergh
Low temperature catalytic thermolysis of water - production of hydrogen without electrolysis.
This work! :)
No components are noticeably consumed, only water vapor and energy.
Basic patents:
1.
https://patents.google.com/patent/SU807584A1/en?oq=SU807584A1
2.
https://patents.google.com/patent/US3963830A/en?oq=US3963830
3.
https://patents.google.com/patent/RO95468B1/en?oq=RO95468B1
100% succeeded in replicating this method, for testing.
Used equipment and materials:
1. Oil vacuum pump, creates a vacuum of up to 0.5 mm. hg or less
2. Test tube made of quartz glass with heater and thermocouple for temperature measurement.
3. Hydrogen sensor for Arduino based on MQ-8
4. Natural zeolite - clinoptilolite with ions of other elements.
The sensor unambiguously registers hydrogen.
Features:
1. The temperature of the beginning of the process is 420 - 430 degrees Celsius.
Below almost never happens. Better if the temperature reaches 500 - 520 C.
2. Vacuum. The pressure must be not higher than minus 99.5 kPa.
With a pressure of vacuum is higher minus 99 kPa, nothing happens.
3. The quality of zeolite is not critical.
It is possible to use cat litter, if it contains natural zeolite. Almost the same effect.
Even ordinary lime can be used, but the effect will be much lower.
I guess the best option would be to use a synthetic zeolite, but not tested it yet.
About zeolite:
https://www.youtube.com/watch?v=x2DSI-v9k8c
ramset
Sir
Tremendous gratitude for sharing this experiment
I will be studying this and hopefully can give it a try?
A member here wrote of a Zeolite material which
Absorbed gaseous propane and somehow converted it into liquid
Without a compressor stage ( huge benefit)
Yes I know the zeolite is used differently here , However it is curious ?
I will touch base with him soon for a refresher!
we also have another  experiment shared by member Acca which
I will also be testing !( Hho experiment
Much gratitude
Chet K
Ps
Yes I will share results here !
Thanks Grandma
kolbacict
Isn't it about that ?
So it turns out that it is possible to self-feed this installation?
By burning the produced hydrogen.
Sergh
Sergh
Quote..when a real molecule is placed between such plates, its energy levels behave in strange ways. And this latest paper demonstrates that with a photochemical rearrangement – the reaction rates change completely depending on whether or not the starting material is confined in the right sort of space, and they change exactly as the cavity is tuned more closely to the absorption taking place. In effect, the molecule is now part of a completely new system (molecule-plus-cavity), and this new system has different energy levels – and can do different chemistry.
The photochemistry shown is not exciting per se, but the fact that it can be altered just by putting the molecule in a very tiny box is exciting indeed:...
https://blogs.sciencemag.org/pipeline/archives/2012/09/14/chemistry_in_the_quantum_vacuum_no_really
