Low temperature catalytic thermolysis of water
Started by Sergh, May 12, 2021, 05:03:49 PM
ramset
Sergh
Thanks for reply, I was on road all day yesterday until late !
Will look for relevant quote and post here (from Herman on soft X-ray )actually he supports your comment and it might be good to define this issue you mention !
Studying your other contributions ( you truly are a wonderful resource for the Hydrogen technologies !
Many are quite interested since it seems more possibilities for open source  builders to explore with huge potential!
For perspective Sam Leach lithium nitrate at 20ppm at 500 psi in water runs ICE ...is within grasp of many experimenters !
Many areas you point to here are in same category ( we have skill set to experiment in open source community)
With gratitude
Chet
Thanks Grandma
sm0ky2
@ Serg
i believe the term 'soft x-rays', refers to the low end of the xray spectrum.
These are emitted from the ultraviolet electric plasma spectrum and beyond.
Vacuum tubes and low-pressure gas tubes were once used to create HV home-medical devices,
and traveling-therapy artists, that would wave a glowing electric tube over your body.
These are "low energy" xrays and HF light
russwr
Have you heard about the used oil furnace from 1950's that ran on water? Patent was issued to army service men in Texas for only adding water line to T fitting for used oil burner on used jeep engine oil, to get 50% increase in efficiency. That was not what was written in their application for Patent. SS coil tubing in brick insulated firepot of oil burner hooked to input common water line. Oil furnace started. Oil passes through spring operated  one way check valve. Temperature gauge monitored for temp up to 1500 degrees F. Then valve opened so as superheated steam is allowed in T fitting with oil to tiny nozzle. Nice burn flame runs constant. Then oil line shut off. Furnace still runs. Shock wave from 90 lbs pressure to zero AMBIANT in fire-pot forms Hydrogen and Oxygen torch flame that also heats heat exchanger. Normally water molecules separate at about 3000-6000 degrees which is too much energy. The vibration shock wave allows for disassociation at lower temperature. Electric motor with dual shafts ran 2 oil pumps at 90lbs. If water shut off, and cooled down, then furnace has to be restarted on oil. A much smaller unit in crate was shown to a US senator in Washington building underground parking , as an open trunk display. This was somewhat similar to the propane operated camping stove with circular pores, ignition igniter, vertical round fire brick insulated chimney, and interior SS tubing of water. When steam introduced to T fitting, the fuel used was shut down leaving burning circular torch flames. It probably used minerals free distilled water so as nozzle would not clog. (US Patent office not allow for overunity for public.- Free Energy is eliminated in issued US Patents. US- 1958, 2,863,499.
ramset
Russ
Your patent number doesn't link for me ?
One thing about lithium,
It's claimed to cut water temp for thermolysis in half ?
(At incredibly small amounts (lithium nitrate at 20ppm in water)
Would also make many issues in your water furnace
Easier to .......engineer
Respectfully
Chet K
Thanks Grandma
russwr
US patent 2863499   shows only SOME of the original data . At least you get the general  idea. Type number in CAREFULLY to study Patent issued. (oil furnace ran FULLY on water in 1950's, after starting with fuel oil, and up to proper temperature- from original manuscript submitted.)
