Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85,You are me destroying my freetime (Thanks God,that´s Friday :P  : It was so .....) Probably ,now: Saturdays Night Fever  ::)
" I am not judging lanca for confusing heat exchange with heat generation, many of these concepts are very confusing and mistakes happen."
Why shall I confuse "heat exchange with heat generation" ?
a heat exchanger -per se- is a ceramic(metal is ceramic) plates/tubes arrangement,electricity-free,eventually coupled with ventilator [/size]
                                          eta or efficiency : <1 or  <100%
when You look to the smartbox image below You will understand the physical process :
a heat pump circuit with heat exchanger (+ dehumidifier effect)
https://lirp.cdn-website.com/04f32754/dms3rep/multi/opt/smartbox-960w.jpg
https://patents.justia.com/patent/9664404
The first and the second heat exchanger elements 7 and 8 are included in a Carnot circuit 9, which further contains a compressor 10, an expansion device 11, an evaporator/condensor 7 and a condensor/evaporator 8. To change the direction of the heat flow through the Carnot circuit, a four-way valve 12 is fitted. To change the direction of the medium flow of the Carnot circuit through heat exchanger element 7, a four-way valve 13 is fitted, so that counterflow operation is always possible.
Such a concept I saw circa 15/20 years back for the first time ,developped by a british company named IMI, industrial prize awarded !
house central heating/cooling/air refreshing with outer flowing used warm air stream with incoming colder fresh cold air stream the heat interchange/exchange ,or reverse the stream heat exchange in summer.
And nix85,by Infinitysav their boiler we are treating the medium,an oil,with friction and ( as heat effect :volume gain) compression to get
a. a greater 1 C.O.P.  work process b. this claimed C.O.P. 80
probably comparing with C.O.P. 10 claimed "thermal friction boiler Perun "  https://www.patentauction.com/patent.php?nb=11161
Think in hand-moved air-pumps (for footballs/soccer ball inflating ) and how fast the air-tube can/is becoming warm/hot !
stivep :
I am sometimes "serious"-fool (in local behaviour : some interestant-nice-fresh girls arround ;) ) but never fooled by Infinitysav or whomelse their products !
I only write that when we see commercial heating/cooling products with conventional drives equipped it is possible to improve these by minimum more than 5 times in their process C.O.P. !
Nothing less and nothing more !
Simple question lankaIV can you find me  just one patent  of fake PhD Slobodian Andrey can you.. ?
For example I'm giving you two random  patents that have never  been approved:
https://patents.google.com/patent/US20050173996A1/en
https://patents.google.com/patent/US7095126B2/en
- just  because   perpetual motion  and OU is not patentable.
the first,as seen by number kind : utility model
the second, technical standart application : 2006 granted    ::)  " and OU is not patentable."
Jesse McQueen
https://worldwide.espacenet.com/patent/search/family/038476291/publication/US7095126B2?q=pn%3DUS7095126B
Infinitysav listening patents : https://infinitysav.com/patents/
nix85
Lanca you wrote this InfinitySav heater is not OU, do you understand that if it works as claimed it has to be OU?
nix85,use the expression free energy !
When Infinitysav by 250 VA electric input reach more than 250 W output heat : fine !
When                     250 VA                                               750 W                 : conventional heat pump average equivalent
When                     250 VA                                             1250 W                 : optimal PM-magnet drive heat pump average
When                     250 VA                                             5000 W                 : ideal T1/2 and ideal heat pump C.O.P. reached
from the old peswiki page : https://peswiki.com/directory:cavitation-heaters 50-60% over input = 160 % efficiency often claimed !
                                            8000 % ( Prof.Kanarev 3000%) is anextreme !
Probably You know this,or not : https://de.calameo.com/read/004838413975ced7310a8
stivep
Quote from: nix85 on June 11, 2021, 08:29:59 PM
What is wrong with you, stivep1, here you attack OU and anyone "believing" in it, yet your youtube channel is dedicated to promotion of OU.
WHAT IS TRUE IN  Free Energy
https://www.youtube.com/watch?v=7Ldus3AQSpE
Wesley
nix85
LOL, few posts back you were justifying term overunity, now you want me to use term free energy. No, you keep using the term OU.
And why are you now using VA unit for apparent power when we are talking about real power.
Again you are mixing apples and pears. Heat pump COP > 1 simply means it doesn't take much energy to TRANSPORT substantial amount of heat energy. If you are GENERATING heat, than according to convention COP will always be less than 1 cause there are always losses. InfinitySav device is generating heat, according to convention it is not possible to generate 251Wh of energy from 250Wh, let alone 20kWh.
