Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
Quote from: nix85 on June 11, 2021, 09:27:05 PM
LOL, few posts back you were justifying term overunity, now you want me to use term free energy. No, you keep using the term OU.
And why are you now using VA unit for apparent power when we are talking about real power.
Again you are mixing apples and pears. Heat pump COP > 1 simply means it doesn't take much energy to TRANSPORT substantial amount of heat energy. If you are GENERATING heat, than according to convention COP will always be less than 1 cause there are always losses. InfinitySav device is generating heat, according to convention it is not possible to generate 251Wh of energy from 250Wh, let alone 20kWh.
I am trying to follow Your expressions,I am so polite ! ::)
We do input Volt x Ampere electrical ( evtl. variable ergo PWM)!
https://infinitysav.com/newinductionboiler/ 99% efficient boiler ! C.O.P.<1  ;)
https://infinitysav.com/induction-boiler/      98%
https://infinitysav.com/cavitator/            350-400%
This installation consumes 4 times less energy than radiator and other heating systems
https://infinitysav.com/product/boiler-isav/
At each of three edges compressed oil reaches high pressure and gets injected out of the disk through the nozzles and create jet propulsion. Once oil is injected to the deflectors inside the support panel it drains down back to the tank.
Hot oil inside the tank passes between pipes of the flow heat exchanger exchanging temperature with them.
The flow heat exchanger pipes supply cold water at the input that intake thermal energy from hot oil and withdraw warm water at the output.
The oil after having given away its thermal energy gets cooled and repeats the cycle over and over again generating more and more thermal energy.
                                                      Normal oil degenerates fast,we have to assume it is a synthetic oil !
nix85,
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19830330&CC=ZA&NR=823054B&KC=B
Hence, one can say the REACTOR TO TRANSMUTE THE MATTER is an apparatus to produce calories
For example, if 2,000 cal (two thousand kilo/calories) is introduced in the REACTOR it will be possible to multiply these calories
by 100 (a hundred),
1,000 (a thousand)
and even 100,000 (a hundred thousand)
according to what it is chosen to be used.
nix85
Quote from: stivep on June 11, 2021, 08:59:18 PM
WHAT IS TRUE IN  Free Energy
https://www.youtube.com/watch?v=7Ldus3AQSpE
Wesley
Semantics aside, the impression i get from your channel is that you believe all these devices, Kapanadze, Akula and other work. So what is your stance.
stivep
No this is lie
-this is your intentional lie.
-and that makes you a lair.
Quote from: nix85 on June 11, 2021, 08:29:59 PM
What is wrong with you, stivep1, here you attack OU and anyone "believing" in it, yet your youtube channel is dedicated to promotion of OU.
I'm promoting FE not OU.
Wesley
nix85
Quote from: lancaIV on June 11, 2021, 09:38:32 PM
You used the term before, so..
That boiler is completely different device working as name says by induction, it has nothing to do with the subject.
So, illuminate us all, how is producing 20kWh of heat using 250w input not OU? :)
Yes,I am polite and accept that photovoltaic cells their output,heat pumps their output( average),windgenerators and waterturbines their output : are OU !
All other kinds of output delivering converter ,if not by experimental teste approved,claims "probably OU or free energy" !
Fine sleep,time for dodot,good night(and later: a good Morning)
OCWL
