Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85,forget at first this relatively unimportant "friction" factor !
We are discussing the several forces,positive and negative,under given physics laws and orders conditioning !
and the physical "term : work" in real physics world application !
What I want,what You want,is also unimportant !
nix85
If we're gonna forget friction, then sure, no work needs to be done, this is Newton's first law of inertia. Bodies keep moving in straight lines unless acted upon by external force.
This brings us to inertial propulsion cause here we have an INSIDE force accelerating the system anywhere.
Speaking of inertial propulsion, i'll give you a hint electropolished steel with low viscosity grease has lowest coefficient of friction, even lower than TEFLON.
https://www.youtube.com/watch?v=wpretUMnW9g
Oh,which surprize,You are beginning to write concrete !
Question when is applying a force ( f.e mass x acceleration )   not work ?
(above Newton,here Coloumb "wattfree transformer ", displacement current circuit )
What is the " lever" as instrument for a phenomen ?
Is each rotative 360° circular process no/work ? ( Here then losts : friction force )
nix85
Sadly, you still don't write concrete, always waving around crumbling in tons of blurry and unrelated stuff (easy way out?) :)
Anyway, we cannot assume no friction, if that is what you mean you must specify it.
Newtons 3.Axioms and the 4.th :the superposition state ,"4.th law"
2.Axiom -ma = ma which unit ?  force ,energy or work representing ?
3.Axiom -F = F  force       |F| = N       |-F| = -N
Unilateral the book " pushing" is bilateral pusher/pushed object and vice-versa/reziprok  to see like a
             " Carambolage"
We are not in search for F in Newton but W in Ns and here we have the impulse or momentum to calculate
                                                I= Ft  or p = mv ( p and v with vector arrow) |p|= Ns
Fm( echanics) and Fe( lectric) to Wm(echanic) and We(lectric)
Applying a force is not in motion mechaniqs either not electric motion "work"
Only as [(-F)+(F)]t = Wtotum ,F and -F with vector arrow
-F = F  and  GRT nuclear FORCE  -e = e
Transformed "specific force" Relativity from Einstein/1.wife e= mcv2 to N.Tesla e=tcv2 to emphaized (e,-e)t= W ;D or -W per sec
Positive and/or negative | nuclear particle power |
Minkowski allgemeiner(passiv) Raum-Zeit to spezifischer ( aktiv) Raum-Zeit-Richtung
Orts-Vektor Zeit-Vektor Richtungs-Vektor, + von - zu
Is energy mortal ? Particle/wave power( in force units) and their lifetime ! Particle/wave birth ? Source/incubator ?
         Schoepferische Zerstoerung ( Schumpeter)
Sincere
OCWL
p.s.: que horror,nao : que terror ,nao mais: que desastre ,quasi : cata-stropha( das 7) : # 180 : tantos errors :-[ ;D
                           :-[  Schaden   ;D  Freude  8)  Syntax ,a bissl Sado-Maso
