Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Indeed, look who's talkin'.
Yea, no need for heaters when you can make a device that directly produce electricity.
"and "bubbles" probably to see like "cell"/s  and its sub-atomar "shell in the shell"
Well, Keely's model of an molecule (probably what physics calls proton) looked like 3 shells each with two holes at the poles and turned 90° to each other covering each other's holes so that atom does not explode and the inner most shell having 3 sub-atoms in it which have the same nested structure etc all the way down to what he called Luminous Ether.
http://www.rexresearch.com/keely/keely.html
From DASHED AGAINST THE ROCK
Each molecule has three envelopes. The most external one the professor illustrated by an india-rubber ball on which he had traced a number of meridian lines.
On another ball were represented the three envelopes. The outer hemisphere of one of the envelopes is removed to show the under envelope, the outer hemisphere of which is removed in still another part of the diagram to show the inmost envelope. A third diagram was then produced to show the position of the atoms which the rotating envelopes enclose. A fourth diagram showed the lines of interference of the rotating envelopes.
There being three perfect envelopes, these of necessity must have six poles, to which add the neutral centre of the sphere itself, comprising the origin of the septenary of mysticism which is universal in nature. The fifth diagram exhibited showed the subdivision of matter into atomic, atoinolic, and atomolinic. A black disc representing a sphere shows the negative atom; two white discs also representing spheres illustrate the two positive atoms in the triad, completing the tertiary aggregation forming the molecule. Each atom is in turn composed of three atomoles ; in the negative atom are three positive atomoles, positive in the sense of activity; in the positive atom are also three atomoles, two of which are negative, i.e. passive, and one positive. The negative is always that which seeks the neutral centre ; the positive represents the active radiating energy: for instance, the sun is a medium for transmitting radiant energy of positive order, which all the planets receive negatively, i.e. it focalizes upon their neutral centres. This order extends to infinity. The final diagram presented was simply intended to further elucidate the action of the rotating envelopes, illustrating the compressing force of the rotating spheral and the protection of the neutral poles. In the rotating envelopes force acts in the opposite direction to its action in the revolution of the earth, where the centrifugal action is greatest at the equator; and the greater the speed of rotation, the greater the centre-fleeing force.
In the case of the etheric envelope, however, the greater the speed of rotation, the more powerful is the centripetal (centre -seeking) force which compresses
the atoms within ; the pressure, therefore, is greatest at the equator and gradually lessens toward the poles. If there were only one envelope, the tendency would be for the atoms to be oblate, to fly out at the poles, where the pressure is least. A beautiful provision of nature obviates this, by providing three envelopes, rotating one within
the other, like three shells ; the line of greatest internal pressure in each one of which being protected by the equatorial lines, the line of greatest pressure covering the line of least pressure on the others. Each of the three atoms is placed directly under one pole of each of the three envelopes.
If the rotating envelope of the molecule were in any way checked in its motion, the enclosed matter would immediately burst forth, producing the phenomenon of integration, releasing from its previously pent-up condition a volume of matter many times as great as that before disintegration took place. Sound-force moving at certain rates of vibration negatizes the action of the rotating envelopes, producing conditions which result in their breaking up, followed by the separation of the atoms contained in those envelopes, and also of inter-molecular substance occupying space not taken up by the atoms. By successive orders of vibration the atoms, atomoles, and atomolini are disintegrated, and so on to the luminous order, where all control ceases...
nix85
And what produces that radiation between the poles of the 3 rotating envelopes? What produces any vibration anywhere? I said before time is oscillating in place. This relates to infinite space. But where universes exist this space, or rather, consciousness becomes polarized.
As Bentov says, consciousness doesn't want to be split apart, but by desire to manifest, by power of will, this gap in the unity of mind is created, the universal egg.
There is great flow of energy between the two poles and they meet in the center producing a black-white hole. But will of God maintains the egg, not letting it collapse.
So we have a balance of what may be called love-gravity and will-antigravity.
Just another piece in the puzzle.
nix85
nix85
While you're still skeptical if OU or God forbid gravity control is even possible, this is what your government has been doing since before WW2, star trek reality, deep underground and undersea bases in constant cooperation with many ET races, human and non human, superluminal craft etc. The missing trillions.
Read chapter 10.
https://docdro.id/JEKraPV
If you read the chapter on the races, you will see it seems our black projects are mostly cooperating with races who have scorn for the humanity. Not necessarily evil, just no love for humanity.
nix85
Late Gordon Novel's friend's nephew was hiking in remote Utah desert, like 20 miles from nearest road, in 2005., suddenly he saw this 600 foot arrow come down silently, camouflaged silo-like door opened in the desert floor and arrow went down and door closed.
http://projectavalon.net/Gordon_Novel_Coast_to_Coast_AM_Jan_17_2010_Hour_2_extract.mp3
Few years after that, John Leonard Walson from UK captured these birds in orbit with his 9inch telescope.
Secret Space program is mostly run by Navy.
And here are few more testimonies from most credible researchers, we are talking man made superluminal craft for a long, long time.
https://www.youtube.com/watch?v=2EmlV8OGmJg
