Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Quote from: stivep on June 08, 2021, 03:07:22 PM
1. In physics I don't accept any  believes.- OU  doesn't exist.
2. I'm FE  Researcher  just because FE is proven  and exists.
3.  Dear nix85 You didn't answer my question about OU.
Example of misconception:
Many encyclopedias, dictionaries, and textbooks contain very clear statements about the nature of Electricity.
They say this:
- Electricity is a type of energy.
- Electric current is a flow of energy.
  Is it  true? :
   here  is  the link:  COMMON ELECTRICITY MISCONCEPTION
Wesley
And who are you to question OU or ever worse define what electricity is?
For God's sake, you don't even believe it is possible, you don't even know how to cancel Lenz, let alone what energy is, what electricity is.
Your perspective is waaay too limited to give informed opinion on these subtle subjects.
I am not giving you concrete solutions, why would i, you are the last person to deserve it with that attitude. But look at this for example, watch the whole playlist, possibly best OU playlist on youtube.
https://www.youtube.com/watch?v=MsJwRznsf4o&list=PLS6CmWwu5VGmYsgX5-2kFtPsE-iIsXj_o&index=41
In this ocean of One Substance/One Energy there are many subtle forces you are not aware of, GREAT FORCES that don't exist for you cause you don't know how to resist/extract them. In fact, there is a whole other spectrum to which gravity,antigravity,thoughts,vitality and similar exotic phenomena belong to.
Little introduction into these subtler energies http://www.villesresearch.com/ether.html
To give you a little hint of the immense knowledge you are oblivious to, i'll copy paste my comment from youtube along similar lines....
First is imagined unbound vibration of infinite frequency and amplitude, there is still not time or space.
Then this infinite vibration is bound by secondary vibrations of finite frequency and amplitude along 6 AXIS OF TIME by 60° angle between nearby axis which creates a Cosmic Forcefield and framework of 3D space.
Each time axis is oscillating in place, time moves not, fact known for centuries in occult cosmology, but each universe out of each matter-antimatter universe pair, like a diode or a sprocket wheel captures just oscillations in one direction, thus matter and antimatter times diverge, something known even to mainstream physics.
Key point of how basis for 3D space is created by creating an imaginary angle between time axis "The angle of 60 degrees could only be created by an apparent frequency shift maintaining the harmonic vibrations of the rotating field."
https://galactic.no/rune/iarapdx1.html
http://www.resona.nl/Denaerde/denaerde.html
As for gravitational bubbles, best explanation is given in Falling Bodies Theory by Lloyd Zirbes. Simple and experimentally verified theory of gravity and all forces based on a simple fact that all bodies falling in the gravitational field extract energy from the parent gravitational field along the leading edge, that is, equator, which causes them to rotate, extracted energy thus spiraling around the falling body to a certain distance (just beyond our moon in case of Earth) and returning to the poles detecting the void of neutral energy along the axis of rotation. This same gravitational bubble that sucks everything toward the planet within the bubble REPELS everything including the parent gravitational field outside it due to shearing of magnetic lines of force due to C+ speeds in the most outer layers.
Regarding the two components of the Universal Fluid, electric (male) and magnetic (female) insulated by the G-lines of TIME. Electric lines travel at what is know as "speed of light" while magnetic lines travel 16,000 miles per second faster and have proportionally lesser density. It is the same neutral energy flowing in both of them, there is no polarity on fundamental level.
And finally, what has to be understood is that this magnetic pressure we feel as gravity has superimposed over it it's polar counterpart oscillating at 1/3 higher frequency. This great force returning to space would break the whole planet apart if it's matter was not strictly kept in certain band of nuclear speed. If nucleus is accelerated beyond certain level it will become transparent to gravity and will start to resist it's polar opposite. This can be achieved by mental means as in thousands of cases of documented human levitation or by treatment by neutral ray which is the same energy trapped in all secondary forces with only difference being that that in, for example, electricity is orders of magnitude faster than that in matter. When this force is liberated by disruptive discharges or scalar interferometry all kinds of unusual phenomena can be produced like changing the weight or temperature of an object permanently, complete destruction without any remnants etc.
Also, speed of light, density of matter and rate of time flow all increase x49 for each plane (or octave) above.
nix85
Estimated energy per cubic centimeter of space.
https://overunity.com/18878/reactive-current-parallel-rcl/dlattach/attach/181834/image//
You provoke "interest"  ;)  Nice number,conditioning ?
No,here not the comparative answer http://u2.lege.net/John_Keely/keelynet.com/bedmot/bedbear.htm
        http://www.calresco.org/
        "Chaos often breeds life, when order breeds habit."
        Henry Adams (1838-1918)
but here :
https://www.sciencedirect.com/science/article/pii/S1875389212025151  tuldigung :-[ , Sh.. ortening  ::)   can(n) happen
1. Introduction
In 1911 Planck introduced his "second equation"[1] E = hν/ (ehν/kT – 1) + ½ hν (1)
This included an additional term, hν/2.
( Das Planksche Wirkungsquantum
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Plancksches_Wirkungsquantum )
When T becomes zero the exponential term becomes infinite and the first term becomes zero, but there is still a residual energy remaining in the form of the second term, which is Planck's constant times frequency.
Depending upon the value of ν, this energy could be quite high. This has been calculatwed[2] to be as high as 10 v110 J/cc.
In 1916 Walther Nernst [3] suggested that there were vast amounts of zero point energy in the universe.
In 1928 P. Dirac [4]stated that space was filled with a large number of negative spaces, and the holes in these spaces were positive electrons.
In 1947 W. E. Lamb discovered changes in the fine structure of the hydrogen atom that became known as the Lamb Shift. [5]
These changes were later shown to be due to the zero point energy (ZPE) [6].
In 1947 Hendrik Casimir [7] proposed that two closely spaced neutral conducting metal plates would exclude the wavelengths of the ZPE longer than the spacing of the plates. This would produce a weaker pressure between the plates and the stronger external pressure would produce a force on the plates.
In 1951 Dirac [8] proposed an ether of particles in an article in Nature. He stated: "With the new theory of electrodynamics we are rather forced to have an aether."   ........
Hmm, https://www.google.com/search?q=lorentz+holes&rlz=1C1AVFC_enPT930PT930&oq=lorentz+holes&aqs=chrome..69i57.5582j0j7&sourceid=chrome&ie=UTF-8
                                           and the "white holes" ? https://en.wikipedia.org/wiki/White_hole
                                           black/white holes spin
                                           Conditionized : https://de.wikipedia.org/wiki/Boltzmann-Konstante
                                           (ultra)black and (ultra)white by physics and between ?
                                           https://en.wikipedia.org/wiki/Particle_decay
                                           Electron and Positron
                                           Proton  and Anti-Proton
                                           as "long life" particles
                                           other ranking related MeV
                                           by "free particles hunting"
nix85
Tnx for the reply Lanca but please shorten those links cause you see what it does to the thread readability.
https://www.shorturl.at/
nix85
If anyone has any doubt in presence of etheric energies around us and how they can be influenced to cause among other things rain, anywhere, anywhen, in immense amounts.
https://www.youtube.com/watch?v=bwhu2G2p2sM
