Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Continuing on the subject of transformers, here is something i shared before but is worth repeating this guy at Quora nicely summed up exactly what happens when secondary is loaded, what is in series what in parallel etc. This is of course not a full explanation of how transformer works, this is just some basic conventional stuff.
A transformer with open secondary is just an inductor. The concept of backEMF makes no sense here. What will happen is the current will lag the voltage by 90° in the ideal case. Power delivered to the inductor is current times voltage. Note that this averages to 0 over any whole cycle when the current and voltage are sines with 90° phase shift between them. Energy is put into the inductor during half the cycle, then given back during the other half. The average power transfer is 0. The energy that is absorbed and then given back is temporarily stored in the magnetic field of the transformer core. In reality, the inductor will not be purely inductive, but will also appear to have some resistance in series with its inductance. That resistance is the DC resistance of the wire the primary coil is made from. That resistance will dissipate power proportional to the square of the current thru it. In a "good" transformer or inductor, this resistance is small compared to the impedance due to the inductance over the frequency range the device is intended to work. Looking at the voltage and current, the current will lag the voltage a little less than 90° due to this resistance. The average of the voltage x current over a whole cycle is now a little positive, which is the energy dissipated by the resistance each cycle. Getting even closer to reality, there will also be some loss in storing then retrieving magnetic energy to/from the transformer core each cycle. This will also appear as a resistive component electrically. The resistance will appear in parallel with the primary inductance. Both together are in series with the DC resistance of the coil.
When a load is connected to the secondary, it looks a lot like the core gets more lossy to the circuit driving the primary. The primary looks more resistive (which means voltage and current are now more in-phase), which accounts for the higher power it now draws at the same voltage.
Like the core loss resistance, this additional resistance appears in parallel with the inductance of the primary, from the point of view of the circuit driving the primary. In a ideal transformer with ideal load, the secondary removes energy from the magnetic core exactly as the primary tries to put it there. The result is the primary current is now in phase with its voltage, and therefore looks purely resistive. This of course never happens exactly because there are always inevitable losses.
In the ideal case, a transformer primary looks like whatever impedance is connected to the secondary, divided by the square of the turns ratio. For example, let's say a transformer has a 1:3 turns ratio. You put 12 VAC into the primary, and ideally get 36V out of the secondary. If there is 10 Ω on the secondary, then it is delivering 36V/10Ω = 130W. This has to go into the primary, which means the primary current is 130W/12V = 10.8A, which means the primary look slike a 12V/10.8A = 1.11 Ω resistor. Note that 1.11Ω / 10Ω = 1/9, which is the square of the turns ratio.
Also...
The magnetizing current is quite small compared to the full load current of the transformer. Magnetizing current remains constant irrespective of secondary load. The magnetizing current lags the voltage by 90 degrees.
nix85
In the case you have not seen Etheric Rainmaking by James Constable
it's about time you do
https://www.youtube.com/watch?v=bwhu2G2p2sM
nix85
From NEWSPAPER "LA CROIX", one of newspapers that reported the encounter at the time. This is another in a long row of indications of a secret military in this case Russian space program. All reports in the link below.
October 21, 1954, France.
A worker from Saint-Rémy (Vosges), Mr. Ujvari, 40 years old, has just told the gendarmes of Raon-l'Etape that, last Wednesday, around 3 a.m., he was stopped on the road by a stranger of large build and average height, wearing a gray jacket, decorated on the shoulders with shiny badges.
The man spoke an unknown language. Mr. Ujvari, of Czech nationality, tried to speak Russian. His interlocutor understood it perfectly. "Where am I, he asked, in Italy, in Spain?" He then inquired about the distance separating him from the German border, and the time. The worker having told him that it was around 3:30 a.m., the man took out of his jacket a watch that marked 4 a.m.
Then the stranger gave the worker the order to move forward. Soon Ujvari saw in the middle of the road a craft in the shape of two plates reversed one against the other, from which emerged a kind of periscope.
Arrived at about thirty meters from the apparatus, which was about 1.50 high and 2.50 m. wide, the stranger tells him to move away. But, looking back from time to time, Mr. Ujvari varies could see the machine rise slowly vertically with a noise of sewing machines. Arrived at an altitude of 500 meters, it took the horizontal and disappeared in direction of the south.
Mr. Ujvari said the unknown was wearing a helmet similar to that of a motorcyclist. He had a gun in his hand.
His last word to Mr. Ujvari was "farewell" in Russian.
https://ufologie.patrickgross.org/1954/21oct1954saintremy.htm
nix85
Little more valuable info on the transformer as constant flux device, what exactly happens, in short due to counter flux developed by the secondary (lenz), overall flux in the core drops, since voltage across the primary is due to inductive reactance (V=IZ) it falls too, new created difference between the source voltage and voltage across the primary cause the rise of current until flux and voltage across the primary are restored (almost) to original value (not exactly since full load flux in the core is slightly LESS than no load flux).
https://www.myelectrical2015.com/2017/10/transformer-on-load.html
nix85
Another confirmation of secret space program... i know it is pointless to post this cause most of you could not give less fuck, but i am sure there is 1 in a thousand who will appreciate the info so here it is, this is shared by Jorge Martín Miranda on facebook. Below is image of the guards that met em and below that "abandoned" US navy installation on top of Pico del Este near which encounter happened. And then illustration made by Mr. Freddie González of the object he saw inside the camouflaged facilty
https://www.facebook.com/photo/?fbid=2361248497345626&set=a.193173027486528&_rdc=1&_rdr
https://en.wikipedia.org/wiki/Pico_del_Este_(Sierra_de_Luquillo)#/media/File:Radar_towers_-_panoramio_(1).jpg
Area 51 S-4 like Installation in El Yunque Rain Forest, Puerto Rico?
By Jorge Martín Miranda
During our presentation as a speaker in the July 1993 MUFON Symposium we included in our talk details about the existence of an alleged site similar to the S-4 facility that allegedly exists in the Area 51 section of Nellis Air Force base, in Nevada, USA. One of them was based on an experience a young couple of puertorricans had in the area of Pico del Este (the Eastern Peak), in El Yunque Rain Forest.
One night in late February 1991, young Freddie González and his wife, Nilda Cuevas, went to El Yunque rainforest. With them were Nilda's younger brother, who was just a child, and their baby.
They had arrived from New York city, where they lived, an wanted to visit the forest, so they took Freddie's mother's car and headed up into the forest along road 191. Ecstatic with the beauty of the area and its lush vegetation, they reached a point where there was a large opening between the foliage in the area.
The sun was already low in the horizon when Freddie got out of the vehicle to check it and discovered that the opening was a camouflaged gate covered by thick vegetation.
They decided to continue on through the opening, and further along the way were surprised to find themselves driving on a modern, well-paved road. It was already around 7:30 PM.
"From a certain point onward, there were blue light bulbs at the road's edge, on each side," González told us in an interview. "It was like on an airport's runway at night."
He continued his explanation. "At that point we felt a weird sensation. Nilda said that we should go back, but I kept going. The road continued going up between the mountains.
"We kept on going for 2 or more miles, and reached the end of the road. There was a big metallic gate there, and a building behind it some distance away, in the middle of a mountain. Just then, two men wearing strange uniforms showed up and stopped us. They ask who we were and what we were doing there.
"They both stood some six feet tall, dressed in tight fitting, one-piece black suits of a leather-like material, similar to a diver's wet suit. They also wore a wide, black belt. Both of them wore black gloves and black boots with what looked like metallic gold buttons on their sides. These went all the way up to their knees.
"They both also wore big, oval helmets with black visors. You could not see their faces, and I can't explain how they were able to see us as it was getting dark (see drawing). Everything they wore was completely black, except for those golden buttons."
"They ordered us to stop," González added. "Then they told us to get out of the car. Thier voices sounded electronic, muffled. But they both spoke in Spanish language. Maybe their voices sounded like that because of their helmets.
"I got out of the car, but told my wife to remain inside. They asked who we were, and requested our driving licenses and Ids. We gave this to them. They looked at them and gave them back to us.
"They then examined the car's license plate, and one of them examined the bottom part of the car with a long, metallic object like a thin tube that had a mirror on its end. He said that 'everything was O.K'. Why he did that, I truly don't know.
"Then they looked at my wife, our baby, and my brother-in-law, and asked again why we were there. I explained that we wanted to have a look at the rainforest and got lost. The two men talked between themselves in a language that sounded strange, guttural-like, and garbled. I would compare it with the Russian language... or maybe German language.
"One of them left the site and at that moment I saw a car approaching. It was a dark blue pick-up truck, and inside of it were two men dressed in one-piece blue overalls like the ones mechanics use. They were Puerto Ricans, because of their accent. They spoke Spanish, and also asked us who we were and how we had gotten there. They would not talk to the tall man dressed in black, who remained there.
"I noticed that the pick-up's door had a U.S. Navy sign on it and realized, "The Navy? Of course, Navy Roosevelt Roads Station in Ceiba! It is close to the forest!"
The men in the truck looked at my wife and the kids and whispered something to the man dressed in black..."
At that moment, there was a sudden flash of light which came from the direction where the pickup truck had come from. Freddie couldn't help but see it, and he looked in that direction, but had trouble believing what he saw.
"That light," he said, "came from inside a rectangular hollowed out area which seemed to be excavated into the side of the mountain covered by vegetation.
"That rectangular area was actually an opening with big crystal doors, and inside of it was an object similar to a flying saucer! It had a circular shape with windows all around its center (see drawing by the witness).
"I could see it clearly due to the brilliance of the light inside. Some men wearing white lab coats were doing something with the saucer, like electrical soldering, and that was what produced the flashes that called my attention.
"The craft seemed to be about some 30 feet in diameter. It was metallic and silvery. It rested on some supports.
"All of a sudden I realized that I was seeing something that, perhaps, I should not be witnessing and became scared. I looked away. The men apparently were not aware that I had seen the saucer."
One of the men in the pick-up truck told the young couple that they should not be there at that time of night "...because people get lost in the dark and disappear easily in the forest without ever being seen again."
He ordered them to follow them, that they would drive them out of the area. They also instructed them that they could not talk to anyone about what they saw and what happened there."
Afraid, they obeyed, and were escorted out of the area. Once they arrived at Route 191, they began their descent from the mountaintop. The Navy pick-up truck followed them for awhile, and then suddenly disappeared from sight.
Freddie and his wife were very nervous, fearing that because of what they saw in El Yunque the U.S. Government might come after them.
In fact, two days later, while they visited the wife's parents in the town of Canóvanas, everyone present at the place noticed a dark car with four individuals inside of it parked in front of the house. The individuals inside wore fine civilian suits, neckties and dark glasses. They seemed to be watching them. Parked next to the dark car was a military camouflaged truck.
"Someone" was letting them know that they were being watched, and it was obvious to Freddie González and his wife that the reason for that was what they had seen in El Yunque.
According to the couple, Some of the individuals entered the house and talked with them, insisting they should go back with them to El Yunque to discuss something. The couple refused to go, terrified that they might "disappear" in the forest.
Once the men realized that the couple would not go with them, they departed. After this incident, González and his wife left Puerto Rico and moved to the United States, where they still reside.
González believes that the reason they were not taken by the men was due to the children being present at the time. He wonders what would have happened if they were alone that night.
We asked him why they decided to tell us their story, and he replied, "Look, I am conscious of the importance of what we saw up there, as it has many implications. But people should know about it. We deserve to know what is happening. It is our right to know."
We agreed on this with the witness. But, who were the mysterious individuals dressed with the tightfitting black suits and helmets?
Why would they be wearing this type of suit in such a warm and humid environment like the one in El Yunque rainforest?
Were they human beings or of extraterrestrial origin?
Why did they speak at times in a strange, guttural garbled language the witnesses could not identify?
What can be said for sure is that the individuals who removed the couple from the site were driving a pick-up truck labeled as belonging to the U.S. Navy, which again, implies a connection between that US military agency and the UFO situation.
This was one of the many incidents we reported in the July 1993 MUFON Symposium in Virginia.
In recent years there has been a considerable increase in U.S. military presence in the rainforest, and many visitors have been taken out from it at gun point, even when they were not in restricted areas. This was often done in an aggressive manner and without explanation.
