Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
nix85
Quote from: pix on June 09, 2022, 04:49:59 AM
Stepanov et cohortes:
Our Team - Global STH Technology (sth-technology.ru)
Looks loke reactive power correction-type. On the picttures you see big inductances, a lot of capacitors, diodes. They said needs to be powered from balanced 3 phase supply or 3 phase DC/AC converter.
Funny you post that, believe it or not for last few days i have been studying
EXACTLY that. That scheme is from Alexander Mikhalych who apparently
replicated Stepanov.
Here is interview with him in Russian
https://www.youtube.com/watch?v=Uu2Rbjr80RI
He says basically the same things that are written in the article
https://jeraff.ru/en/generator-transformer-with-resonant-winding-resonance-transformer-energy-from-ether/
He is the one i referred to when i said "some pump up 5-6kW in the middle of the
circuit and take out 1/3 of that". If you read the article you will see that is exactly
what he does.
But, as i also wrote, his approach is very bulky and needs very big transformers.
Also he is talking about magnetically insulating the secondary of the left trans
and primary of the right one supposedly to remove them from the load.
As you see in the scheme he is taking part of the output parametrically
feeding the input.
Yes i see big inductances, look at that huge 3phase trans in the first photo.
Tons of big caps too. Such a bulky system.
It's a worthy example of success, but not the most efficient one. All that can
be simplified and scaled waaay down. And without the need for 3 phase
balanced supply.
kolbacict
Quote from: nix85 on June 09, 2022, 08:16:38 AM
This video is from the channel "global wave" it seems.
You ask Wesley about this organization. I don't think he has much respect for it. :)
nix85
Quote from: kolbacict on June 09, 2022, 11:25:05 AM
Wesley, you mean guy who claimed that power cannot be amplified in RLC tank,
in this very thread few pages back. Need i say more.
nix85
And another example what is possible.
https://www.youtube.com/watch?v=XClNRaFJLTM
0-4W draw from the wall, load 300W.
Google translated video description
"Overunity transformer with 600 VA power. Transformer powered by mixed dimmer x resistive - inductive loads of 500 VA., Powered by 220 V AC current rectified by 4 diode bridges. A series of halogen lamps for one load have been connected to the outputs approximately 200 VA. Two other transformers are also connected to the power strip of the transformer, one of which consists of a series of 6 and the other of a single one with power factor correction capacitor without load. In the series of 6 a load of about 100 Va was connected by means of n. 2 car lamps. Lastly, 4 10 VA lamps are connected on the same socket, each regularly lit in the test. The total load on the illustrated circuit is approximately about 300 VA with input oscillating from 0 to 4 VA."
He is talking about 7 other transformers which can't be seen in the video, one of them with power correction cap, all in series. This resonates nicely with Stepanov. Large inductance 'removing' load from the wall.
kolbacict
Quote from: nix85 on June 09, 2022, 12:14:23 PM
No, no, this is not about a specific device.
Wesley was talking about the collective of people who work on the Global Wave channel.
