Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
stivep
nix85
Quoting ramset also ain't gonna help you.
Answer the questions or simply admit you're wrong.
pix
Quote from: stivep on June 23, 2022, 05:53:46 PM
so if I am not reliable than please prove me wrong
The statement is  :try our best my friend, but keep in mind:
no matter what you say about RLC power amplification that is a complete nonsense.
You will also be ask to explain what that extra amplified  power comes from?
what is that power origin?
the law of conservation of energy:
energy cannot be created nor destroyed.
Wesley
Resonant circuit do not amplify anything, it ACCUMULATES.
It is electromagnetic energy trap.
Tesla did explain it nicely.
Regarding current, in quarter wave resonator voltage additive multiplication takes place at the top terminal, current multiplication at the ground node.
Check out Corums work.
Cheers,
Pix
stivep
Quote from: pix on June 24, 2022, 04:34:11 AM
Cheers,
Pix
Correct.( it concentrates energy "flow" like an open gate)
Thank You.
Nix85 was spreading "heresy" -  profoundly at odds with what is generally accepted  by science.
Quote from: nix85 on June 23, 2022, 07:30:29 PM
Apparently you try to disprove overunity
Yes.
overunity is  never proven and rejected nonsense .
https://overunity.com/18815/has-anyone-here-constructed-an-overunity-system-that-works/msg556417/#msg556417
Wesley
pix
Quote from: stivep on June 24, 2022, 07:47:27 AM
Correct.( it concentrates energy "flow".)
Exactly! :)
Flow is a key word here.
Tesla described this as a big tank filled from the hose. Tank is equipped with a large dump valve in the bottom.
Once water level in the tank reaches a point where pressure overcomes spring force of dump valve- accumulated water in the tank is released with large flow.
Other examples:
Tesla described it also as charging capacitor from atmospheric voltage diference ( around 100V/m) and discharging capacitor through a spark gap  once reached breakdown voltage.
All kinds of magnetic compression methods, explosive and non explosive- where a weak and non usefull practically  magnetic field is compressed to a large pulse.
Ambient electromagnetic field power harvesters .
Hydro power- river flow is first accumulated in a large dams, and dumped through turbines to generate power.
Ect.
There is a lot of energy around us that Nature provides, low grade energy that we could convert to useable form by a properly converting it.
And resonant LC circuit is one of them.
Cheers,
Pix
