Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
alan
Quote from: nix85 on June 23, 2022, 06:16:20 PM
Another old, unknown success video, this guy is apparently doubling the power
using three coils on same half core, two coils on the sides are in opposition, screams
scalar.
Subtitles - auto translate are your friend.
https://www.youtube.com/watch?v=Df48bstPN14
Yep, pic also screams VIC and Floyd Sweet.
My hypothesis:
Scalar potential of V/m on a conductor/resistor/load, electrons are pumped through it because that's what a EMF scalar potential does, the partnered coils  through mutual inductance prevent this current that is pumped through the load to be part of the circuit that generates the potential, no magnetic feedback to primary, no Lenz back-emf, so no increase of input current. aka asymmetrical regauging of the potential and 'don't destroy the dipole'.
Needs resonance to shake the electrons in the load because they're not being part of a closed current loop.  Open system.
If an electret self-oscillated, could it drive a load???
nix85
What a pile of self-contradictions.
If stivep meant it can be "concentrated" not "amplified",
he would've said so but he never did.
And even if he did it would still be wrong.
This semantic question of amplify vs concentrate has already
been addressed when i wrote
"So it is definitely possible to amplify power, you may argue if that power
is usable."
Even if it wasn't usable (which it is) it would still be an amplification
inside the RLC.
And it clearly is usable. Part of the amplified power is taken namely
280W and system is self fed, as already shown.
https://www.youtube.com/watch?v=GYWgcRB73bw
And this is one of smaller examples.
Moreover pix in last part of the post admits self-contradictorily that
"There is a lot of energy around us that Nature provides, low grade energy
which could convert to useable form with resonant LC."
Of course, there is nothing low grade about these subtle energies, their power
is literally infinite. It is limited only by how much we can resist and dissipate.
So he admits resonant LC can be used to convert what he wrongly thinks is
"low grade" ambient energy, which is nothing else but power/energy amplification.
Something he just claimed resonant RLC cannot do literally in previous post.
pix
Quote from: nix85 on June 24, 2022, 10:57:17 AM
So he admits resonant LC can be used to "convert" what he wrongly thinks is
Please understand "low grade" like in therodynamics , heat pump analogy. We convert large amounts of 10 degC ambient air into smaller amount of 50 degC air suitable for heating your home or water.
10degC air isn't very usefull for heating your house, isn't it?
By the aid of compressor and properties of refrigerant we can compress that "low grade" ambient energy into useable form.
Same thing will happen with ambient electromagnetic energy of space surrounding us.
We can tap into that energy radiation, that is "low grade", maybe volts, milivolts or microvolts in amplitude. Maybe watts or miliwatts per second.
Milivolts and miliwatts aren't very usefull for practical purposes, to power something in your home, isn't it? That's why I call this "low grade".
With resonant LC tank we could tap into that electromagnetic spectrum and convert miliwatts into Watts or more.
Something with miliwatts but at high frequency (kHZ or MHz) could be converted into Watts at Hz frequency.
Proper LC resonant circuit would do this. It acts as accumulator, "we fill with a hose a big tank equipped a large dump valve at the bottom".
Cheers,
Pix
stivep
example from classical mechanics:
actually it is like that:
you can feel 10 kg push of your  left-hand finger to the palm of your right hand.
But if you concentrate that 10 kg force on the needle pushing  the palm of your right hand,
then this needle will come out from the other side of that hand.
example from quantum physics:
if you concentrate 10 W of power on the laser beam you can burn a hole in paper sheet up to 10 m
but that depends from the frequency.
The LRC circuit in resonance can become the very narrow bandwidth (filter) , and that all 10 W energy can flow through it.
that bandwidth is the bandwidth of our open gate in resonance.
I will explain more in the next post.
if you can concentrate microwatts per square foot in area of Texas and release it through a very narrow filter
you might have pinpoint directed EMP.
Dr. Corum introduced Earth/air interface there is a the waveguide for an electromagnetic wave impacting it at complex Brewster angle.
Need to understand that all lightnings eventually strikes  the earth.
So if we have 1.4 billion flashes per year and some of that energy randomly strikes at complex Brewster angle, then we have
electromagnetic energy collectively at this waveguide known as interface.so all you need is to to tune your LRC circuit take this energy out at complex Brewster angle, using preferably Tesla coil .
-inverse square law doesn't apply to waveguides. losses in he interface below 20kHz are really  small. and that is the entire secret of Tariel Kapanadze
Wesley
forest
you can amplify energy not only power, the key is in Steven Mark comments
of course you need:
1. Energy source beside power input
2. Sound scientific theory
it was described many times in varoius threads here just connect dots
energy amplification needs resonant condition but it's resonance with medium and resonance with steps required not just electrical resonance
just tap energy of thunderbolts
