Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
stivep
Quote from: forest on June 24, 2022, 12:07:35 PM
you can amplify energy not only power, the key is in Steven Mark comments
of course you need:
1. Energy source beside power input
2. Sound scientific theory
it was described many times in varoius threads here just connect dots
energy amplification needs resonant condition but it's resonance with medium and resonance with steps required not just electrical resonance
just tap energy of thunderbolts
you're absolutely right.
Power stands for level.Energy is that what would be amplified,
but we where talking about special case of LRC circuit that can't amplify no energy nor its power level.
https://electronics.stackexchange.com/questions/239852/rlc-filter-as-amplifier
Wesley
nix85
Quote from: pix on June 24, 2022, 11:17:46 AM
Please understand "low grade" like in therodynamics , heat pump analogy. We convert large amounts of 10 degC ambient air into smaller amount of 50 degC air suitable for heating your home or water.
10degC air isn't very usefull for heating your house, isn't it?
By the aid of compressor and properties of refrigerant we can compress that "low grade" ambient energy into useable form.
Same thing will happen with ambient electromagnetic energy of space surrounding us.
We can tap into that energy radiation, that is "low grade", maybe volts, milivolts or microvolts in amplitude. Maybe watts or miliwatts per second.
Milivolts and miliwatts aren't very usefull for practical purposes, to power something in your home, isn't it? That's why I call this "low grade".
With resonant LC tank we could tap into that electromagnetic spectrum and convert miliwatts into Watts or more.
Something with miliwatts but at high frequency (kHZ or MHz) could be converted into Watts at Hz frequency.
Proper LC resonant circuit would do this. It acts as accumulator, "we fill with a hose a big tank equipped a large dump valve at the bottom".
Cheers,
Pix
Nice try, but not so fast. You proceed from presumption that ambient energy
is at low level (10° C analogy). And what made you think it is so.
There are so many streams of subtle energies passing through us in all directions,
nothing about them is "low grade", it's just that we are usually transparent to most
of them.
Take gravity, this one we feel strongly. It is literally an inward rush of energy from
space toward the center of the planet. Take a small piece of lead for example, this
piece of lead has no magnetic field that extends into space to "scoop" supposed
low grade energy, all it has is it's own volume and it ain't big, yet how long can
you keep it in your palm before your arm muscles tire. The density of this energy
is enormous and if instead of piece of lead you had a chunk of neutron star in
your hand you would know it well since it would pass through your hand as
easily as if it were not there, it's weight would  be on scale of mountains or
more, yet it's size is tiny, all it's weight can only come from the it's volume
in which it screens the gravitational inflow. And if you put one object above
the other does the bottom one feel less gravity, obviously not, so this
energy is (usually) unscreenable and limitless in it's density and potential.
So, with just a simple example of gravity we have shown energy density of these streams is beyond comprehension.
And there are many other streams similar to gravity, of non-herzian spectrum, we
usually don't feel at all. One of them is antigravity superimposed over gravity
flowing in opposite direction and at higher frequency, it's E density is even higher.
NOTHING about these streams is low level. They may only appear so to one who
does not resist them or resists them only in a small degree.
Analogy of a river may suffice better. Quote from Etidorhpa
"If a series of knife blades on pivot ends be set in a frame, and turned edgewise to a rapid current of water, the swiftly moving stream flows through this sieve of metallic edges about as easily as if there were no obstructions. Slowly turn the blades so as to present their oblique sides to the current, and an immediate pressure is apparent upon the frame that holds them; turn the blades so as to shut up the space, and they will be torn from their sockets, or the entire frame will be shattered into pieces."
nix85
Quote from: alan on June 24, 2022, 10:46:49 AM
Yep, pic also screams VIC and Floyd Sweet.
My hypothesis:
Scalar potential of V/m on a conductor/resistor/load, electrons are pumped through it because that's what a EMF scalar potential does, the partnered coils  through mutual inductance prevent this current that is pumped through the load to be part of the circuit that generates the potential, no magnetic feedback to primary, no Lenz back-emf, so no increase of input current. aka asymmetrical regauging of the potential and 'don't destroy the dipole'.
Needs resonance to shake the electrons in the load because they're not being part of a closed current loop.  Open system.
If an electret self-oscillated, could it drive a load???
Yes, definitely reminds of Sweet's device which is essentially a copy paste of
Daniel Cook's device patented in 1871.
Any time we got fields in confrontation or complete annihilation aka
neutralization of herzian waves, we give rise to scalar component.
This is the basic rule, call it bucking coils if you like or any other
name. This is nature's principle neutralize the secondary energies
and you will get subtler ones, like collision of two gamma rays
produces electrons and positrons...
How do we relate the electron flow with this scalar component
associated with the A field aka Vector Potential, this article gives
a nice perspective on it, depicting magnetic field as axis of a toroid
etheric "smoke ring" around an moving electron.
http://creatorguy.com/files/Ortho1.pdf
nix85
of course you need:
Indeed it is possible to amplify power and energy as already shown.
All kind of resonance are in-play, LC, ferro, acoustic.. or combination of.
It all comes down to RESISTANCE, that is, resisting the subtler energy forms and
slowing them down into electricity (be it hot or cold).
ATREE did it most elegantly with no electricity whatsoever, by two parallel paths of
different resistance, but no one has been able to replicate it sadly.
So we use resonance in many forms.
People cannot accept what they have not yet personally observed so we
get silly comments like tap the low grade ambient EM sources or thunderbolts..
Instead they should realize we are immersed in streams of infinite potential and
gravity we feel so strongly is one of them.
May i remind that Floyd Sweet's device lost all it's weight when fully loaded and
larger Steven Mark's TPU units lost part of the weight when in operation.
TPU weight loss was disclosed here https://www.youtube.com/watch?v=W_fRKxz_UNo
pix
@Stivep
Thanks for explanation about Corums and tapping into Schumann resonance .
Another thing.
In Stepanov resonant transformer what we see is a large 3 phase inductance, a lot of capacitors and a DIODES .
It is still make me thinking what would be a reason for that diodes.
I assume they are on the output.
I am considering two possibilities.
1. It is a flyback setup.
2. If not flyback, what would be a reason to put half wave rectifier on the output of resonant circuit?
What is your opinion?
Regards,
Pix
