Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
onepower
Jo-EL
QuoteBECAUSE it is EVER an open SYSTEM !!!
Even so called  "SOLID STATE CIRCUITS" !
I am 50 years old and more than 30 years in electronics !!! German title Master Ing. Electronics !
Good to have an experienced hand you on board.
I agree and we can never create a truly closed system because 99% of matter is a perfect vacuum full of EM energy. What we call matter is an illusion we have created in our mind and is only 1% material moving about near the speed of light.
As an electronics guy here's something you may like. I broke the rules regarding Faraday's cage which claims that no EM waves can penetrate it. I did this by producing Tesla's radiant impulses which act faster than the cage metal can conduct. In fact the only reason any energy can be blocked by a Faraday cage is if the conductor induces an opposing field faster than the energy which induced it. If the energy is acting faster than conduction/induction there is no opposition.
So we should understand the notion of open and closed systems has limitations.
In fact the strange notion of closed systems and loops came from Faraday and his fellow scientists of the time who found there were an infinite number of variables in every system. As such it was impossible to quantify all the possible number of interacts and do any calculations. So they started generalizing and lumping things together so they could do the math. They never meant for anyone to take these concepts or forms of notation literally but apparently many did by mistake.
AC
pix
While you guys do fighting over ambitional matters  ;D  I found another inteesting patent connected to Strebkov resonant amplifier. Positive feedback to primary side of transformer enchances gain.
RU2600097C1 - Method of increasing of electric signal power - Google Patents
And latest from Stepanov. Nearly all Stepanov patents deal with converting  reactive power into active.
RU197031U1 - HALF-GENERATOR - Google Patents
Cheers,
Pix
PS. Stivep. I am not going to go into political/philosophical disputes. I cut discussion to absolute minimum and technical topics only. This forum is already diluted by tons of BS talk.
nix85
I agree let's keep it technical.
But before we get back to transformers,
since stivep denies ether, i just want him to say is Trevor James Constable a liar/hoaxer,
if not and if he still denies ether by which mechanism is rain produced.
Why i got a hunch he is never going to, even if he does it will be some dodgy,
water mudding reply, never clear and concrete answer.
https://www.youtube.com/watch?v=MjeUhQJp5WE
Not even going to go into all the other etheric engineers of which there are many.
A summary of TJC's work
Etheric weather discoveries of Trevor J. Constable
The Earth is a living organism, and like all living things it breathes. The major etheric force involved in the breathing processes is the chemical ether. The planet Earth exhales the chemical ether into the atmosphere at sunrise, and inhales it into the mantle at sunset. "The moisture-producing, fluid-influencing chemical ether is responsible for such seemingly disparate phenomena as morning and evening fogs and mist, fluctuations in soil humidity, barometric pressure changes, increases and diminutions of potential gradient, and the rising and falling of plant sap." (7)
Wilhelm Reich (1897-1957) discovered the chemical ether as a physical force in 1939-1940, and called it orgone energy. He empirically found out many properties of orgone energy; the blue color, affinity to the fluid state of matter and the ability to produce thermic, barometric, electrostatic and biological effects. In his discovery of the atmospheric orgone energy, Reich also determined the presence of its basic west to east movement. (7)
The chemical ether flows from low potential to high potential - to the opposite direction than conventional energy potentials. The main etheric flows in the temperate zones run from west to east, and in the equator, the main flow is from east to west. There are large differences in temperate zone etheric densities and response times compared to (faster) equator. The west to east flow of ether in the northern hemisphere is strongest at full moon, and weakest at new moon. There is also south to north terrestrial flow of ether in the northern hemisphere spring and summer, and in the winter this flow reverses. The west to east flow and the south to north flow are separate functions of the ether, but to some degree they mutually influence each other. (12)
Fig. 3. Etheric weather engineering device
Geometric forms and structures have a long history of involvement with etheric force. Pyramids and cones focus etheric force in a coherent beam from the cone apex. When rotation is added, the devices become more effective as vortical movement is generated in the ether. Additionally when the devices are mounted on a moving vessel, their action is greatly enhanced. In the picture is Mark 5 Spider: The rotating cones induce vortical movement into the ether, which increase the local etheric potential and attract atmospheric moisture, and eventually produce rain. (12)
Etheric potential and barometric pressure have an inverse relationship. As etheric potential and humidity rises, barometric pressure goes down, clouds are formed and eventually it rains. When the etheric potential becomes sufficient, it discharges via lightning. High etheric potentials are antagonists to high electric potentials. Very high etheric potential (for example in tropical cyclones and in tornadoes) flows towards high electric potential sources such as high voltage transformers and breaks them with great force. (12, 13)
There are two kids of etheric vortices: implosive and explosive. Conventional technology depends upon explosive forces, which are hot, dry, and destructive. Implosive forces, on the other hand, are cooling, contractive, and constructive to life. Their activity is harmoniously ordered and based on the golden section ratios, which manifest in all life. (12)
pix
Quote from: nix85 on July 11, 2022, 05:18:54 PM
Please stop this aether thread.
This topic is about reactive power and ways to convert it to active power.
Cheers,
Pix
nix85
Quote from: pix on July 11, 2022, 06:18:38 PM
Cheers,
Pix
Why would i stop it and let him disinform people.
It's a simple question, let him answer it altho i doubt he will.
EDIT:
Ok, nevermind. I don't want him to answer, what could he answer anyway,
it would be naive to expect anything but further denial or dodging.
I shared enough on the subject, who was supposed to get it got it.
Movin' on with the main thread.
