Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
ramset
Nix
It is not his video
It is a presentation of another's claims
And this holds zero weight to replicators without disclosure of the gain mechanism!
As mentioned
No replications to date !
Also as mentioned
Hopefully that is going to change soon !!
Respectfully
Chet K
Ps
Your use of friends??
All who carry water for this open source cause are friends by association to same !
And most are not even casual acquaintances to each other
But this cause does bind us !
Edit for below
No I am not kidding ...such a simple arrangement?
I will send video to a few good builders here for opinion
Thanks Grandma
nix85
I know it is not his video, but it is his video in a sense he uploaded it.
Zero value? Are you kidding. Guy shows clearly how to pass the sticky
point by putting two magnets at 90 degrees and stacking such pairs.
Or the next video, mechanism is also quite clear, one ring ferrite broken into
6 pieces spread out as stator and 16 small magnets, supposedly all same polarity
on the rotor.
https://www.youtube.com/watch?v=3oten1viGbo&list=PLS6CmWwu5VGl5al_O94rmKNiuSZs7Loz1&index=3&t=221s
Etc
ramset
Please pick one you feel is simplest and undeniable evidence
I will solicit input from ten open source builders these next few days
And report back !
Many I have been wanting to touch base with anyway!
Respectfully
Chet K
Thanks Grandma
nix85
Like i said i don't encourage anyone to build these, they work but they are toys.
I doubt they can be scaled up efficiently.
For high power what everyone wants as you know and as everyone here knows
you would need some kind of Perendev or Yildiz replica or something similar which
would be anything but easy to make.
As such
https://www.youtube.com/watch?v=VydeDvOOSQs&list=PLS6CmWwu5VGl5al_O94rmKNiuSZs7Loz1&index=9&ab_channel=HalimAbdul
ramset
Well I went to your link and it highlighted this one with "request of challenge to the engineers "
Problem is ... that one got prime time attention here few years back
And astute engineer observed spring connecting device to Erh... generator
Was indeed torquing spring the wrong way for claimed demonstration ?
Spring twist showed Generator was actually driving the device ( as motor)I believe TinselKoala was first to point that out!
Perhaps
You should pick another ?
Thanks Grandma
