Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
Quote from: nix85 on June 11, 2021, 02:30:30 PM
Not as entertaining as you.
"The system COP is > 10, depending on the conditions."
A C.O.P. ,
"coefficient of work performance" depends ,by conventional heat-pump technology,
https://en.wikipedia.org/wiki/Coefficient_of_performance
The COP usually exceeds 1, especially in heat pumps, because, instead of just converting work to heat (which, if 100% efficient, would be a COP of 1), it pumps additional heat from a heat source to where the heat is required. Less work is required to move heat than for conversion into heat, and because of this, heat pumps, air conditioners and refrigeration systems can be more than 100% efficient.
https://learnmetrics.com/coefficient-of-performance/
Theoretical maximum COP is calculated like this:
COP  heat pump = 298K/(298K-287K) = 27,09
So, in theory, a heat pump can have a COP even above 20. Nonetheless, the real COP of a heat pump in practice is a lot lower.
from internal thermo-cryo dynamical circuit temperature/pressure
and outside circuit/space/ambient temperature,pressure !
heating out-in /reverse: cooling in-out   process parts :
to see here
                https://theengineeringmindset.com/wp-content/uploads/2018/11/Heat-pump-schematic-how-a-heat-pump-works.png
             Have You a fridge: the above circuit is in these cooling box/chamber integrated ,look and understand !
In the NL,there they have in summer up to 30°C positive and in winter up to 20°C negative , 50 °K temperature amplitude/spread !
                                         physical state change =                   condition-dependence !
nix85
"The COP usually exceeds 1, especially in heat pumps, because, instead of just converting work to heat (which, if 100% efficient, would be a COP of 1), it pumps additional heat from a heat source to where the heat is required. Less work is required to move heat than for conversion into heat, and because of this, heat pumps, air conditioners and refigeration systems can be more than 100% efficient."
Great, but why did you mention heat pumps, fridges, they just move heat around, they are no OU devices.
Was it just in your style of crumble everything in, related and unrelated.
Also  https://infinitysav.com/centrifugalboiler/ even with C.O.P. 80 ( up to  333) is not OU !
TARGET/MAXIME : the greatest possible return with the least possible effort
Why mentioned ?
Because this technology,in use as refridgerator = mostly common, will be one from the future existent low-e reaching techniques !
Before : how many Wh per annum 2021 each world-habitant non-renewable use ?
After   : how many renewable Wh each world-habitant (preview 2100 : 11 000 Mio. citizen)  will need/use/has available  !?
Kyoto-conference,Kopenhagen,Paris contracts !
Sincere
OCWL
nix85
In the future expanding/contracting gas will not be used for cooling/heating, it will be done by night side forces as it was in days of Atlan 13,000 years ago.
ramset
Lanca
You need separate section for some of theses things !!
I will remove comment
this is on forum ( here already )??
Maybe bump answer there ( or other
What happened to them ?
Thanks Grandma
