magnetic force and electric force alignment
Started by lancaIV, June 04, 2021, 01:31:25 PM
Re: O.U. Magnet force shielding 2 and so on
What if :  (force time displacement) = kinetic energy , geral theory ,linear
                                                       kinetic energy x k = usable energy,specific theory ,translatoric
        https://en.wikipedia.org/wiki/Kinematics
        K-reis-Verschiebungs-Winkel/-Grad angular/momentum Drehung/Wechsel
about "distance" and/or "time" fine tuning
http://www.rexresearch.com/kenyon/kenyon.htm
"lumens machine" has to be electric : minimum a. for A,B, Group pm fine tuning controle
        b. for output torque x rpm (linear) controle,by translated pm force max.
Related the attraction/repulsion force difference :
http://jnaudin.free.fr/html/2magpup.htm but  the  tangential repulsive force measured is 574 g.
      the  axial repulsive force measured is 1254 g
     Did You attractive force and repulsive force difference measurements ?
                 Unruh-Principle ! unruh = restless ,the "automatic clock/watch" batteryfree work process
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Unruh_%28Uhr%29
       from spring-quenching watches to automatic to quartz to kinetic
        https://iknowwatches.com/seiko-automatic-vs-kinetic-watches/
http://www.rexresearch.com/invnindx.htm A-Z
specific magnetism related
http://www.rexresearch.com/dyke/slntwpn.htm  weapon or tool/instrument
http://www.rexresearch.com/wadle/wadle.htm
http://www.rexresearch.com/davis/davis.htm
http://www.rexresearch.com/dotto/dotto.htm
volumetric air space as "air core" for transformation
mono-coidal or helicoidal or multi-coidal (dis-/advantages)
instead air as core liquid or solid,non-/ferrous
mangnet field lines polarisation,electro field lines + magnet field lines polarisation
131 years back,publication,relatively unknown,zero citations :
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=427606A&KC=A&FT=D&ND=3&date=18900513&DB=EPODOC&locale=en_EP
description : row 22 +
( experiments : one coil charging or both ,direct current or alternating current or pulsed or mixed )
ERICH Kaifler,Ex-SIEMENS-er :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=kaifler&CPC=&IC=&Submit=Search
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=27&ND=3&adjacent=true&locale=en_EP&FT=D&date=20011129&CC=DE&NR=10025289A1&KC=A1
                                                         Patten and Kaifler,but micro-/nano
electro-/magnetism and temperature/pressure
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/thercond.html
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8502303A1&KC=A1&FT=D&ND=3&date=19850523&DB=EPODOC&locale=en_EP
http://www.chenyang.de/hauptseite.htm Magnet Arrangement and Magnetic Circuits of Magnetic Assemblies
because each topic by me has archive function :
https://www.youtube.com/watch?v=dOyYYoPIAlM
https://magstar.eu/wp-content/uploads/2021/01/Tesla-oscillator-july-1919-electrical-experimenter.pdf
"...circuits ..." = phase/s
" 85% can be recovered = can be efficiently transform-ed/-ated : input/primary and output/secondary
           ???  vibrating spring    Diapason function ? harmonics/resonance
           Helmholtz    Hohlraum       cavitator/resonator  Hohlraum = Vakuum/Vacuum   cavitator= chamber/Roehre/tube
                          Otto v.Guericke
In public he demonstrated the power of air pressure with spectacular experiments. He achieved special attention in 1654 when he was on the Haidplatz in Regensburg on the occasion of a Reichstag in the presence of Emperor Ferdinand III. and had spectacular experiments performed by many princes on the effect of air pressure. [3] In the summer of 1657, Guericke had put two large hemispheres (¾ Magdeburger Elle) made of copper (Magdeburg hemispheres) together using a seal and pumped the air out of the interior. Then eight horses were harnessed to each hemisphere, one after the other, which they were supposed to tear apart, but this did not succeed. When the balls were filled with air again, they fell apart on their own. In another attempt, Guericke had a cylinder with a movable piston set up. A rope was attached to the piston, which ran over a pulley and was held by 50 men. When Guericke sucked the air out of the cylinder, the men could not prevent the piston from lowering because the atmospheric air pressure was stronger against a vacuum. That was the momentous invention of his hoist.
With his experiments, Guericke confirmed conclusions that Blaise Pascal had drawn ten years earlier from the experiment Void in the Void. Furthermore, his experiments and inventions showed that nature knows a vacuum. The "horror of the void" (Horror Vacui) postulated by Aristotle was thus refuted.
                                         https://de.wikipedia.org/wiki/Umformer
In electrical power engineering, a converter is a mechanical combination of rotating electrical machines that convert one type of current into another, for example direct current into alternating current. A conversion between alternating currents with different frequencies is also possible; frequency converters are used for this.
Converters and, in particular, frequency converters have a similar area of application, but in contrast to converters they represent a power electronic device without mechanically moving components.
                      we call this today DC/AC inverter +frequency converter ,german Wechsel(strom)Richter und Frequenzumrichter
                      or time-/function-/pulse-/frequency- generator = oscillator https://en.wikipedia.org/wiki/Electronic_oscillator
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.udo-leuschner.de/basiswissen/SB123-05.htm
https://en.wikipedia.org/wiki/Polyphase_system
https://www.yourelectricalguide.com/2017/04/purely-resistive-inductive-capacitive.html
https://en.wikipedia.org/wiki/Scott-T_transformer
Interconnection[edit]
At the time of the invention, two-phase motor loads also existed and the Scott connection allowed connecting them to newer three-phase supplies with the currents equal on the three phases.[3] This was valuable for getting equal voltage drop and thus feasible regulation of the voltage from the electric generator (the phases cannot be varied separately in a three-phase machine). Nikola Tesla's original polyphase power system was based on simple-to-build two-phase four-wire components. However, as transmission distances increased, the more transmission-line efficient three-phase system became more common. (Three phase power can be transmitted with only three wires, where the two-phase power systems required four wires, two per phase.) Both 2 φ and 3 φ components coexisted for a number of years and the Scott-T transformer connection allowed them to be interconnected.
https://en.wikipedia.org/wiki/Polyphase_coil
2D/3D monitor dimension
Floor
Quote from LankaIV
END of that quote
Not of that design.
Lumen's / Telecom's design does not need an electric component in order to
arrive at more kinetic energy output than kinetic energy input.
                                        although
It might be improved by controlling  or adjusting  one or more of the field
intensities as distances change ?  Maybe electrically ?
Floor
Permanent magnet interactions are more simple than
electro magnet interactions.
1. Field fluctuations occur mostly outside of the permanent magnets.
2. Inductance and reactance, need a conductor.
A conductor is absent from the permanent magnets (mostly)
3. capacitance and its aspects, need a dielectric and electric
charge environment, also absent from the permanent magnets (mostly).
It should be interesting to begin to establish correlations between the two
in an O.U. context
   best wishes
            floor
Floor,I could constate your argument,if we have not specific use  targets : rotative,linear ,both,converting,et cet.
Yes,a ready to use permanent magnet (undefined,ARNOLD : 4000 pm configuration variations ) is easier looking than an electro-magnet and its process !
force per gram/cbcm :
https://patents.google.com/patent/US8847720B2/en
How big an equivalent permanent magnet ?
Wmbr
OCWL
Floor
yes, of course and I agree.
Establish a goal or set of goals ? Specifics ?
A particular design or class of designs ?
What would you like to approach ?
   floor
