magnetic force and electric force alignment
Started by lancaIV, June 04, 2021, 01:31:25 PM
Floor
Given that we are considering the displacements caused by permanent
magnet forces as energy.....
We can label  either of these two as energy density (in that context).
The greatest magnitude of magnetic force / field density (of record) has been
arrived at through the use of electromagnets.
The greatest magnitude of magnetic force / field density per unit of
mass and or weight (of record), has been arrived at through the use of permanent
magnets (considering also, the electric supply source for electromagnets).
Rotating devices conserve energy as momentum.
Linear devices must expend energy to cause acceleration over and over again.
Energy expended to cause acceleration is the product of both the mass of the
accelerated object and the speed to which that object is accelerated.
Low mass and slow speed will reduce energy wasted as accelerations.
              But also....
Large displacement  (long output strokes) will reduce the number of accelerations
needed per unit of time.
High force, slow output stroke speed, low mass and long output strokes= high
efficiency and high power.
Convert this to high speed continuous rotation after the initial kinetic energy
production as desired.
The bottom line is that arriving at large Joules per second in not limited to RPM (rotations per minute).
We are able to pick and choose some things in life, other things, we cannot.[/size]To be able to have / experience life is a temporary arrangement.This is not an option.Humans are a / one of, the major forces on this planet.We are "intelligent" and optionally we may behave accordingly.Life's experiences and the universe are bigger than man's intelligence, immeasurably so.This is not optional either.That which created us and sustains and holds us is ultimately in charge.Our choices matter.People are often frustrated and feel ineffective.Every moment holds the potential for any individual to bring forthsomething of great value. Each one of us has far more effect upon those around us than we generally are inclinedto acknowledge.  It's big.  it's significant. It matters. We matter.  We are effective andaffecting.This is not optional.No matter "where one is coming from"  it is legitimate and has value, whenit is expressed honestly / when we acknowledge our own responsibility for theeffects, our expression will have.But we all too often are in denial of this fact, and / or may feel as if we are powerless.We aren't.
:o  ,wie :  8)  erfahrungsgeschwaengert !
1.Hochschule von Alexandria https://de.wikipedia.org/wiki/Alexandrinische_Schule
2. STAR TREK,"DUNE" :          ? / !?
3. Gott ist tot (F.N.) ,Ueber-ES (H.R.)
4. https://rationalwiki.org/wiki/Alex_Chiu
5. https://www.spiegel.de/ausland/nigeria-boko-haram-chef-soll-sich-in-die-luft-gesprengt-haben-a-c2c31399-f462-4c1d-ad0f-90a2b08d3c5f
                        good : good   good  : bad     bad : bad
6. https://genius.com/Monty-python-meaning-of-life-lyrics
7. https://translate.google.com/translate?sl=hu&tl=en&u=https://www.bz-berlin.de/klassiker/op-erfolgreich-kopf-auf-fremden-koerper-transplantiert
8. https://en.wikipedia.org/wiki/Actroid
Model(l) : "Mini"-Golf https://upload.wikimedia.org/wikipedia/commons/thumb/1/16/Actroid-DER_01.jpg/800px-Actroid-DER_01.jpg
                 Maxi-Golf = 18-Loch/holes          Mini= hole in 1                 Loch-Karten-Schlitz,where ? Or wire-less payments ?
                       https://www.youtube.com/watch?v=eogpIG53Cis
alignment : natural (active/passive) or synthetical(active/passive)
we,as creature =Lebewesen,with anima=animal/s and eventually mamma=mammal/s wish/es to overcome situations :
            barriers,frontiers : https://www.youtube.com/watch?v=MCCAaAso5VU
                                                              too much,too less
                                                              in small(mind sphere),in great(body sphere)
                    By this we use experience,experiments :learning by other/s,by doing/mimikry/simulation to reach our target:
                                                             the right balance and satisfaction(temporal,local,object-related)
                                                              X : maximum to minimum,minimum to maximum
                                                            line track :    V  or U  or their physical invers movement or ----- plan,flat
modelling cars :                  https://www.modellbau-berlinski.de/rc-fahrzeuge-und-zubehoer
modelling: race track           https://carrera-toys.com/de/44/rennbahn
opto/inductive track,small    https://www.youtube.com/watch?v=TcBnSp0SpcM
inductive track,great :          https://en.wikipedia.org/wiki/Induction_loop
                                          https://www.schlader.at/wp/wp-content/uploads/Autodrom.jpg
modelling free 4D track        https://www.rc-network.de/   for free flying planes/jets,free swimming boats ,......
                                          by wireless induction
autonomous induction experiment : https://ieeexplore.ieee.org/document/5618092
test field :
https://i0.wp.com/motonewsworld.com/wp-content/uploads/2021/04/worldsbk-czech-autodrom-most-2.jpg?fit=1200%2C800&ssl=1
target :
   https://spectrum.ieee.org/transportation/advanced-cars/6-key-connectivity-requirements-of-autonomous-driving
   sourced by autonomous energy generator dynamic circuit
about speed/velocity track specific records ,efficiency-independent :
https://en.wikipedia.org/wiki/Bonneville_Speedway
this records more efficiency related :
https://en.wikipedia.org/wiki/Shell_Eco-marathon
in the german version (more informative than english version)
https://de.wikipedia.org/wiki/Shell_Eco-Marathon
translated :
Akkumulator /Batterie
Prototype: 2014 wurde vom Team TERA TU Graz ein neuer Rekord aufgestellt mit 1091,6 km/kWh.[7]
Urban Concept: Hier kam das französische Team Electricar Solutions 2012 auf eine Reichweite von 262,6 km/kWh – eine Steigerung um 29,6 km/kWh zum alten Rekord.[1]
accumulator
Prototype: In 2014 the TERA TU Graz team set a new record with 1091.6 km / kWh. [7]
Urban Concept: The French team Electricar Solutions achieved a range of 262.6 km / kWh in 2012 - an increase of 29.6 km / kWh to the old record. [1]
                                                               MARATHON  RULES/CONDITIONING
The aim of the Shell Eco-Marathon is to drive as long as possible with as little energy as possible.
Each vehicle must cover a distance of 25 kilometers in a maximum of 50 minutes (this corresponds to an average speed of at least 30 km / h).
During this trip, the fuel consumption is measured.
In order to make the results of the different categories comparable, it is calculated how many (milli-) liters of super gasoline contain the same amount of energy as the fuel consumed.
Finally, it is extrapolated how many kilometers the vehicle could theoretically cover with the amount of energy from a whole liter of super gasoline.
To compare electrically powered and fuel-powered vehicles, the required amount of fuel in liters or the amount of energy in kWh is converted into the other unit.
The URBAN COMMUTER specifications :
Horn, rearview mirror and seat belt are just as mandatory in the Urban Concept category as fire extinguishers and roll bars.
The maximum width of the vehicles is limited to 1.3 m, [5] whereby the ratio between height and width must not exceed 1.25.
There are no restrictions on the design and use of materials for the vehicles.
let us look and listen to experimenter :
https://www.youtube.com/watch?v=UICxLbNRIgw
0:28 vid  accompanying moto-bike tachometer shows 45-48 Km/h for modified rated 350 W e-bike motorized speed velocity comparison
                                 by flat street (back-/forward wind ?) and away moto-bike wind-shadow
let us assume :
(rated 350 W)  500 VA per hour electricity consume and by average 40 Km/h ( flat track) this means : 100/40 x 500 = 1250 VAh/100 Km
compared above listen world-record :
Indian modification  1250 Wh/100 Km =   80 Km/KWh                           to WR : 262,6 km/kWh
                  means, theoretical : indian bike modifying with Li Yng micro-motors transmission = WR - level !
        modifying with Ferreira cap-windings motor         = WR - level !
But : related second listen WR :   indian modified 80 Km/KWh                           to   WR : 1091,6 km/kWh
            anymore the Li Yng micro-motors transmission,only more the Ferreira cap-windings e-drive reach OVER-WR-unity !
       Mr. Li Yng,do not worry : micro-motors transmission and Henri Trilles capacitive windings amplifier : back to OVER-WR-unity track !
        U2  :)
                                max speed,    average velocity ? vehicle weight/electric motor rated power  ? max allowed weight ?
                                              energy (recuperation) sourced/delivered for example
https://www.youtube.com/watch?v=xV9y7lFOKNA&t=106s   https://www.youtube.com/watch?v=NcQFRXriVDc
                                  and/or e-pedalling
https://www.google.com/search?rlz=1C1AVFC_enPT930PT930&source=univ&tbm=isch&q=electric+car+generative+pedalling&sa=X&ved=2ahUKEwjayuCngojxAhWHN8AKHZ3bBmcQjJkEegQIAhAB&cshid=1623154715965106&biw=1366&bih=605
Why/not answer/question : https://docs.google.com/document/d/1u3Dr5Ey9PrMiSHmqQs61aLFsZQYxW51wHDamm8vF3bY/mobilebasic
https://www.explainthatstuff.com/how-regenerative-brakes-work.html
                    from e-bike to trike ,how many rated W need for average 40 Km/h ( + allowed weight)
                    catalog :                         https://german.alibaba.com/g/trike.html
let us take : https://german.alibaba.com/product-detail/eu-warehouse-free-shipping-cheap-adult-big-wheel-48v-1500w-brushless-motorized-electric-drift-trike-ce-approved-60830784454.html?spm=a2700.7724857.normal_offer.d_title.54042635EiwUKs
                                                       900 W           or             1500 W rated power
                                                    25 Km/h max                    55 Km/h max
A. I do not see street legality !                      B. it is for R&D interests about consume/recuperation : the lowest possible  !
btw: https://german.alibaba.com/product-detail/new-e-trike-1000w-2000w-3000w-enclosed-4-wheel-electric-trike-scooter-electric-tricycle-adult-62297848912.html?spm=a2700.7724857.normal_offer.d_title.54042635MAwrUY
                                                            4 rad Electric  ::)  Trike Scooter
                                                        3 wheels = trike   4 wheels/rad = quad
                                                  AUTODROME experiments,autonomous drive,( unmanned )
        for
https://www.google.com/search?q=autonomous+city+shuttle&rlz=1C1AVFC_enPT930PT930&oq=autonomous+city+shuttle&aqs=chrome..69i57j33i160.9530j0j7&sourceid=chrome&ie=UTF-8
                                                          steering wheel free
                                  Beyond Tesla Inc.,Toyoda/Toyota,VW,MB,GM aera thinking
                                  Beyond human self-driver
for the global tachometer > 100 Km/h fraction :
( diabolic thinking,I  :-[  : https://german.alibaba.com/product-detail/new-eec-300cc-trike-cvt-60074768033.html?spm=a2700.7724857.normal_offer.d_image.54042635SlIOAm  ::) ;) :)
                                    but : Igittegitt ! : Gas/Diesel engine motorized ,stinker ! Brueller ! Verschwender ! )
https://en.wikipedia.org/wiki/Sinclair_C5
Enthusiasts have established owners' clubs and some have modified their vehicles substantially, adding bigger wheels, jet engines, and high-powered electric motors to propel their C5s at speeds of up to 150 miles per hour (240 km/h).
                                                   Rock-it !  ;D  ( An e-torpedo on 3-wheels) Safe,street legal ? :-\
                          https://www.youtube.com/watch?v=eKRD7Agdm1k  210 Km/h,bow hey,so slow ? ;D
                         IN THE CITY ??? ??    https://www.youtube.com/watch?v=isFrMU7q6OA  :o  Citydrom
Our world is based by rules and the "how to take rules"- operation manual  similar easy  https://www.youtube.com/watch?v=JYNyQcblzgI
198? : P.M.-Magazin article : bullit-like vacuum channel journing, velocity 10 000 Km/h : f.e. Europe/North-America in < 1 hour
        MACH 10
orbital pendant : https://de.wikipedia.org/wiki/S%C3%A4nger_(Raumtransportsystem)
                                https://de.wikipedia.org/wiki/Awangard_(Hyperschallwaffe
                                https://en.wikipedia.org/wiki/Avangard_(hypersonic_glide_vehicle)
        MACH 20+
nix85
Often forgotten fact is that each magnetic field line wants to get away from all others, magnet literally wants to explode, but the force is, of course, too weak to explode it.
