Build 2
Started by Johnsmith, December 22, 2021, 08:33:09 PM
Johnsmith
 I've done more design work. As the drawing shows, the hub will go into the retraction disc. While it's not
shown in this design, I did chamfer the outside edges of the hub core 45º. The amount of chamfer will keep
the retraction lines between the 2 sides of the retraction disc.
When I can see how the weight wheel assembly sits in its channel I can think about how to fit it. Basically I
can make the weight wheel assemblies and then when I rout to the 45º chamfers of the guides it will roll on,
I will rout as needed.
And with this design drawing, I need to add the brackets between the arms and the pulleys and their mounts.
Considering I started on this yesterday evening, I'd say I'm making good time in getting the design worked
towards completion. This is because I'll need to know how the kicker assemblies will be mounted. Then I can
rout the hole location for the peg the kicker will strike.
This is where having better tools to work with is allowing me to work much more quickly. What I will need to add
are spars just as used on sailing ships to guide the retraction lines and the lines that will allow for them to be
released when a weight is shot outwards.
This is where this coming weekend I'll just make unfinished assemblies. The weight wheels need to be finished as
well as the retraction discs. Then I'll be able to finish the arms and the braces that go from one arm to the other (not shown).
What I'll most likely do is position the braces where pulley mounts will be placed. The picture of the prototype shows
where pulleys and their mounts are positioned for using 4 weight wheels.
I'll also need to be cleaning up the stand so it will be finished. It's just that when the frame for the wheel is finished, I'll
want to place it on the stand and leave it there.
kolbacict
Johnsmith
Quote from: kolbacict on April 22, 2022, 05:15:31 AM
https://youtu.be/rnKjv9hnepE
fake ?
  The veproject tries to get people interested in things. With my build, sometime after May 15th I should be finished.
The build is going pretty good so no worries there.
Johnsmith
 I am ahead of schedule as far as my build goes. Usually I will be at least 1 month behind schedule. I got done everything I hoped to this weekend.
During the week I should be able to make my new weight wheels. This time I will use an assembly jig so they will all be the same. This will matter
for when I rout the 45º chamfers for the tracks for the weight wheels to ride on. And this detail will also be a part of al arms and braces.
I usually prefer to call the arms "spars". I like both boats and ships and have been on plenty. Why I want the weight wheels finished first is so I can
test fit them on the spars to ensure a quality fit. This will help the wheel work better.
It's odd but next weekend I might only be making a piece to go around the hub core, do the chamfers and then do the same for boards that can fit
into those chamfers. I'll need a lot of pieces to secure the braces to the spars. And before I assemble the spars and the braces I'll need to drill a lot
of holes. I'm thinking Jules Verne meets Johan Bessler. And because of why that detail will matter, that will need to be finished before assembly.
If everything works out the way I hope, people need to ask themselves what they want a Bessler Wheel for. An example is a challenge that I will
issue to Orpheus.org and their friends. And what is that challenge?
   Das Triumphirende Perpetuum Mobile Orffyreanum
  Except for a small change in the external dimensions of the wheel for raising weights (or so-called "running wheel"), I have organized everything together in accordance with those structures of the previous machine which I had broken to pieces. These small changes occurred by chance and do not need to be defended.
Around the firmly placed horizontal axis is a rotating disc (low or narrow cylinder) which resembles a grindstone. This disc can be called the principle piece of my machine. Accordingly, this wheel consists of an external wheel (or drum) for raising weights which is covered with stretched linen. The base of the cylinder is 12 Rhenish feet in diameter. The height (or thickness) is between 15 and 18 inches. The axle (or shaft) passing through the center is 6 feet long and 8 inches thick cross-sectionally.
While in motion it is supported by two almost one-inch-thick tapered steel pegs, whose two bearings (or sockets) with two curves around the axle provide the rotational motion of the whole vertically suspended wheel through application of pendula, which can be somewhat modified, as the attached figures at the end of this treatise clearly show.
https://besslerwheel.com/writings/das_triumphans.html
After all, the attached image is a challenge, right? After all, I am not building Bessler's Wheel but my interpretation of Bessler's Wheel. Watch the TV show Face Off. In it, you are given a challenge.
You are literally told what to build. How you interpret what you are told is up to you. Joining Peacock is free. https://www.peacocktv.com/signin?return=%2Fwatch%2Fasset%2Ftv%2Fface-off%2F5187152827644028112
With Scott Ellis, in the thread where AB Hammer said I am the ultimate fraud, Scott Ellis told him it's not easy to stop someone who is motivated. Yet I am allowed to be attacked.
And yet if the title is in German and it says "How I, Johann Bessler Was Successful", why do they not understand this? And then for him to explain it as well? How do they not
understand Engleske? Or is the translation from Deutsche to Engleske flawed?
Just an FYI, I asked many times, why repeat the history that Bessler went through? In 300 years, somethings have not changed. With Russia and Ukraine, the name Ukraine might
come from the Russian word for "at the extreme". Kiev is where the original Russia was founded by Vikings. Rüs (Roos) is what the Vikings were called. And Rüs ee Ya (Руссия (Рус и Я))
would mean the Viking and myself or the Viking and I. Why Россия ис нот Руссия. They simply did not want to be extreme like Kiev. It's in the language and the names.
Of course I am 1/2 Norwegian and know why the Vikings were in Kiev. Basically to take what we have today and instead establish a government that allows for trade and commerce.
This almost like going back 1,000 years in time and saying "Really, do we need to go through this again?".
And to show a more recent understanding of how Norway and the slavs of Russia and Norway have interacted, the group is named after a language spoken by Norwegians and Russians.
This language would've been spoken by those who fished the Arctic.
https://www.youtube.com/watch?v=bqAbk6K_U_I
This is a toxic subject. I am a fraud. I have always been banned for working at Bessler's Wheel. When it is my money, my time and my work, why should I work for someone
who refuses to work with me? Some examples of their work. They are well respected while I am not.
I accidentally spelled "is not"  "ис нот" using the Cyrillic alphabet. That's funny 😂🤣
Johnsmith
  This is about what it will look like when finished. All of the dimensions are very accurate. I'll be making a video next
week to show what I've done over the years. I started pursuing this concept in 2013. I had to take a break for a couple
of years because of medical issues.
What slowed everything up was also being attacked for being 1/2 Norwegian. Some native English speakers thought
I should give it to them because they're simply better people. And considering that John Collins was a part of that
problem along with his orpheus.org group, that basically makes it white supremacy.
It reminded me of the stories my father told me about when the 3rd Reich occupied Norway. He almost got sent to a
Nazi death camp for not thinking and talking the right way. Over 13 million non-Jews died that way just as my father's
friend did. Nazis caught him but not my dad.
