This one is intresting.
Started by Cherryman, January 19, 2022, 08:54:02 AM
floodrod
Quote from: pix on January 28, 2022, 12:12:01 PM
I think opposite.
Other videos are BS, but this one I find plausible. I was thinking about similiar setup but never did anything real about it.
That's why I started my own project.
Cheers,
Pix
I've been wrong more times than I've been right..  I'll be watching and I hope you prove me wrong..
Ufopolitics
Quote from: floodrod on January 28, 2022, 12:05:57 PM
I am leaning towards this video being fake.  As Floor pointed out- this person also has a video claiming free energy by putting spoons on a speaker.  Any credibility this video has is negated by the fact that the channel is proven to spew fake news.
It is not the "same person"...this Chanel just uploads videos from different sources...and yes, I agree there is also a lot of BS Fake stuff.
I agree with Pix, this video here looks pretty good...plus, why spent so much time building all this project, then adding videos to explain and show there is no hidden wires in  HD...plus all other possibilities of fraud asked by random people?
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
@Pix,
Since you are starting your calculations of magnets size and strength...I will share this tip, even tough am pretty sure you know it.
In a Generator, the Inducing Magnetic Field width sould be around the size of the Wire Loops width on Stator...
Cheers and good build!!
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: bistander on January 27, 2022, 02:42:42 PM
Hi Ufo & all,
It's called a Lundell or claw rotor
https://www.researchgate.net/figure/Exploded-view-of-a-Lundell-alternator-3_fig3_237464668
And replacing it with PMs cannot increase voltage X10 unless RPM is increased X10.
bi
Edit, ps.  Skew of magnets or pole face edge is done to reduce cogging. No magic there.
Hello Bistander,
Like I said before, I am very familiar with these type  of Alternators...
If you notice, the Inducing Coil runs parallel to Shaft-Axle, and not like in a Home Generator where the Field is Directly projected into the Stator Coils Loops...
On this Alternator the Magnetic Field is REDIRECTED in the Steel Core, generating all upper Claws to be of One pole while the bottom ones are the opposite pole...so, they alternate into NSNSNSNS...etc.
The center Inducing Coil works on 12V DC, after rectified by the Diodes Bridge...and fed by continuous slip ring-brushes into the rotor.
Point here is that by setting Neo Magnets the way they did, the Fields Increase is MUCH greater than original config...plus, it projects field DIRECTLY into the stator wire loops...
These type of Alternators can not produce a Sinewave just like a typical Home one would do @ 60 Hertz typical 120V type deal...simply because of this fact of fields-loops config...
So, a Single Phase Home Generator (eg: Two Poles) is required to spin at 3600 RPM's to generate the 60 Hertz cycle...
This type of Alternator (once configured with two Neos by each Claw) does not need to go at 3600 to generate same power, but much less speed.
Ufopolitics
―Leonardo da Vinci
floodrod
Quote from: Ufopolitics on January 28, 2022, 01:51:16 PM
Are you sure?
I poked around his channel and it's full of the same voice, same intro in all the vids, and the descriptions on all of these alternator translations the uploader claims ownership of the project..
Here's one off the same channel that seems like the same guy telling us we can put a coil between 2 repelling magnets and run a playstation or 3 light bulbs from the output.  https://www.youtube.com/watch?v=gbm7vi4pP_M
And this one tells us if we jam some wires into a cucumber and label it - and +, we get continual arcing from the power locked up in a cucumber!  https://www.youtube.com/watch?v=OdiZG0gb5eg
