This one is intresting.
Started by Cherryman, January 19, 2022, 08:54:02 AM
pix
Quote from: Ufopolitics on January 28, 2022, 01:59:13 PM
@Pix,
In a Generator, the Inducing Magnetic Field width sould be around the size of the Wire Loops width on Stator...
Ufopolitics
Can't be this way.  Magnet width has to be calculated individually to particular stator windings configuration,around size of distance between neighbouring grooves. All depends how your windings are done.
In my case I've spent all day to firure out my motors winding configuration. It is 4 pole 36 grooves  motor. Given rotor diameter and windings layout  I know already number and sizes of magnets I have to use.
24 magnets, width max 8mm, slotted 8 mm. Opposite magnet poles has to cut coil loop at the same time.
Cheers,
Pix
Ufopolitics
Quote from: pix on January 29, 2022, 02:54:58 PM
Cheers,
Pix
I did not write "magnet width"...I wrote Magnetic Field width
Magnetic Field is actually what penetrates the loop causing the induced current...
You should first study an Alternator Stator Windings configuration, which is what the video you have uploaded is based on...then realize the Magnetic FIELD that is created replacing all the cut claws per wire winding (not looped)
But then again, it is your time and money, I was just trying to render my point of views.
Good luck on your project!!
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
pix
This is another one. :)
Very crude but works.
How to generate homemade infinite energy with a washing machine motor and an engine ⚡💡💡⚡ - YouTube
I hope this week to make progress with my project. Ordering magnets, rotor diameter has to be reduced on the turning machine.
Cheers,
Pix
Ufopolitics
By the way...
Yesterday I found this video, and I laughed out loud...not because of its veracity...but because this guy does not even have tools to do this job...I mean, he takes off the main alternator shaft Nut....with a Chisel and a carpenter hammer...destroy the nut at end, but takes it off...LOL
Video is not edited...
However, he gets it finished, roughly built like hell, ...but it works!!
And if you look closely, those Bulbs are not LED's...but Incandescent Bulbs.
...and not "associated" at all to "Tecnología Oculta website"...
I turned Car Dynamo into 230V Generator
Cheers
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: pix on January 30, 2022, 11:38:27 AM
Cheers,
Pix
I would like to see any of these "generators" powering an Air Compressor...or even a small refrigerator...or a wall, small Air Conditioner...
From what I see, it is fine powering small loads, like drills, electric saws and light bulbs...but how about big loads like I mentioned?
IMHO, I believe these generators will crash down trying to power an Air Compressor, for example.
I mean, that is the way to really test the real output of any generator at Peak Output.
However, if they all are real, then they set a point of looping Energy and still some extra to power other components, and that is just great advantage!!
I will try myself a simple setup...I do have it all to do it...but not at this time though...very busy.
Cheers
Ufopolitics
―Leonardo da Vinci
