Free Energy Super Pack! 5 in 1!
Started by dxer_87, January 22, 2022, 01:07:54 AM
dxer_87
You may check also this information :).
dxer_87
Revision made :-).
Add heater for IC, add 200 turns on toroid 0,35mm2 after 35mH choke on plus. Change C10 100nF to 330nF/100V. Will be cool to see PCB for this. Diode 13V or 13,6V suits best.
Yours sincerely Kleo.
e2matrix
Thanks for sharing all the interesting circuits.   I assume your home language is Polish and have a couple questions about terms in the diagrams.
What is paulos ?
What is Carat Trax ?
I assume a 'heater' is a heat sink for keeping parts from overheating - thus maybe a 'cooler' would be a better term if not heat sink.
Is 'mass' the same as ground or neutral?  or is it the hot line ? or ?
Floor
None of these device produce free energy.
Do you claim that they do ?
dxer_87
And this little guy should do its work with the brother I think :-).
Gives both AC and Dc. Sth like 2 Amps on AC line and 5-7Amps on DC line you may achieve making every coil right and giving the right chokes (from filters...).
